查看: 7890|回復: 9
基于proteus的16*16點陣LED屏仿真及源程序
基于proteus的16*16LED點陣屏的仿真
含有proteus的原理圖
keil c的源程序
8*8點陣屏是通過分解重新封裝的
可以實現滾動顯示
16×16點陣(滾動顯示)仿真原理圖:
單片機源程序:
  1. #include <reg52.h>
  2. #define int8 unsigned char
  3. #define int16 unsigned int
  4. #define int32 unsigned long
  5. int8 flag;
  6. int8 n;
  7. int8 code table[][32]={
  8.                           {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/* "  " */
  9.                           {0x04,0x28,0x08,0x24,0x32,0x22,0xC2,0x21,0xC2,0x26,0x34,0x38,0x04,0x04,0x08,0x18,0x30,0xF0,0xC0,0x17,0x60,0x10,0x18,0x10,0x0C,0x14,0x06,0x18,0x04,0x10,0x00,0x00},/*"歡",0*/
  10.                           {0x02,0x02,0x04,0x82,0xF8,0x73,0x04,0x20,0x02,0x00,0xE2,0x3F,0x42,0x20,0x82,0x40,0x02,0x40,0xFA,0x3F,0x02,0x20,0x42,0x20,0x22,0x20,0xC2,0x3F,0x02,0x00,0x00,0x00},/*"迎",1*/
  11.                           {0x00,0x01,0x04,0x02,0x1C,0x0C,0xC0,0x3F,0x1C,0xC0,0x02,0x09,0x02,0x16,0x92,0x60,0x4A,0x20,0x82,0x2F,0x02,0x20,0x0E,0x24,0x00,0x22,0x90,0x31,0x0C,0x20,0x00,0x00},/*"您",2*/
  12.                           {0x44,0x10,0x44,0x14,0x88,0x54,0x88,0x54,0xD0,0x5F,0x30,0x50,0x60,0x50,0xFE,0x7F,0x40,0x50,0x20,0x90,0xB0,0x9F,0x98,0x92,0x8C,0x94,0x88,0x34,0x80,0x11,0x00,0x00},/*"乘",3*/
  13.                           {0x82,0x00,0x02,0x01,0x22,0x06,0x22,0x38,0x22,0x04,0x22,0x03,0x22,0x00,0xFE,0xFF,0xA2,0x00,0x22,0x01,0x22,0x02,0x22,0x3C,0x22,0x02,0x02,0x01,0x02,0x00,0x00,0x00},/*"坐",4*/
  14.                           {0x02,0x00,0x0C,0x00,0xF0,0x3F,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0xA0,0x00,0x60,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00},/*"廣",5*/
  15.                           {0x80,0x00,0x01,0x07,0x06,0x00,0x18,0x00,0xE0,0xFF,0x00,0x04,0x00,0x03,0x00,0x00,0xFE,0x7F,0x00,0x08,0x00,0x06,0x80,0x01,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00},/*"州",6*/
  16.                           {0x00,0x00,0x04,0x20,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x20,0x04,0x00,0x00,0x00},/*"三",7*/
  17.                           {0x20,0x08,0x20,0x86,0x7F,0x60,0x80,0x0F,0x00,0x04,0x00,0x1A,0x00,0xEA,0x00,0x2A,0x00,0x2A,0x00,0x2A,0x00,0x2A,0xF0,0x2B,0x0C,0x28,0x02,0x20,0x0F,0x00,0x00,0x00},/*"汽",8*/
  18.                           {0x00,0x00,0x80,0x00,0x04,0x01,0x0E,0x02,0x14,0x0C,0x24,0x70,0xC4,0x21,0x8C,0x00,0x08,0x00,0x08,0x70,0x28,0x08,0x1E,0x06,0x0C,0x03,0x80,0x01,0x00,0x01,0x00,0x00},/*"公",9*/
  19.                           {0x00,0x00,0x00,0x08,0xF8,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0xF0,0x49,0x00,0x48,0x04,0x40,0x02,0x40,0xFC,0x7F,0x00,0x00,0x00,0x00},/*"司",10*/
  20.                           {0x00,0x00,0x80,0x00,0x04,0x01,0x0E,0x02,0x14,0x0C,0x24,0x70,0xC4,0x21,0x8C,0x00,0x08,0x00,0x08,0x70,0x28,0x08,0x1E,0x06,0x0C,0x03,0x80,0x01,0x00,0x01,0x00,0x00},/*"公",11*/
  21.                           {0x40,0x00,0x40,0x08,0x41,0x08,0x42,0x08,0x4C,0x08,0xF8,0x7F,0x50,0x08,0x40,0x08,0x40,0x08,0x60,0x08,0xD0,0x7F,0x4C,0x08,0x47,0x08,0x42,0x08,0x40,0x00,0x00,0x00},/*"共",12*/
  22.                           {0x20,0x08,0x20,0x86,0x7F,0x60,0x80,0x0F,0x00,0x04,0x00,0x1A,0x00,0xEA,0x00,0x2A,0x00,0x2A,0x00,0x2A,0x00,0x2A,0xF0,0x2B,0x0C,0x28,0x02,0x20,0x0F,0x00,0x00,0x00},/*"汽",13*/
  23.                           {0x20,0x00,0x20,0x20,0x20,0x21,0x20,0x23,0x20,0x25,0x20,0x39,0x20,0xE1,0x20,0x21,0xFF,0x2F,0x20,0x21,0x20,0x21,0x20,0x21,0x20,0x21,0x20,0x21,0x20,0x00,0x00,0x00},/*"車",14*/
  24.                           {0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",15*/
  25.                           {0x00,0x04,0x01,0x04,0x02,0x04,0x04,0x04,0x08,0x04,0x30,0x04,0xC0,0x05,0x00,0xFE,0x80,0x05,0x60,0x04,0x10,0x04,0x0C,0x04,0x06,0x04,0x03,0x04,0x02,0x04,0x00,0x00},/*"大",16*/
  26.                           {0x00,0x02,0x40,0x0C,0x40,0x08,0x40,0x48,0x40,0x3A,0x40,0x2A,0x42,0x0A,0x41,0x8A,0xFE,0x7A,0x40,0x2B,0x40,0x0A,0x40,0x18,0x40,0xEA,0x40,0x4C,0x40,0x08,0x00,0x00},/*"學",17*/
  27.                           {0x20,0x08,0x30,0x08,0xE0,0xFF,0x42,0x08,0x4C,0x08,0xF0,0x1F,0x10,0x12,0x1A,0x12,0xF2,0x13,0x04,0x10,0xC8,0xFF,0x30,0x10,0xCC,0x50,0x02,0x37,0x1C,0x12,0x00,0x00},/*"城",18*/
  28.                           {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x0E,0x14,0x10,0x24,0x10,0x44,0x10,0x84,0x11,0x0C,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"2",0*/
  29.                           {0x04,0x02,0x44,0x06,0xC4,0x1A,0x48,0xE3,0x48,0x46,0x48,0x00,0x04,0x09,0x04,0x09,0x08,0x09,0xC8,0xFF,0x30,0x09,0x28,0x49,0x44,0x39,0x02,0x29,0x1F,0x01,0x00,0x00},/*"線",19*/
  30.                           {0x00,0x02,0x02,0x42,0x04,0x42,0x08,0x42,0x30,0x42,0xC0,0x7F,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x42,0xFE,0x7F,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x00},/*"開",20*/
  31.                           {0x40,0x04,0x80,0x08,0x00,0x11,0xFF,0xEF,0x00,0x44,0x02,0x10,0x82,0x10,0x82,0x10,0x82,0x90,0xFE,0x7F,0x82,0x50,0x82,0x10,0x82,0x10,0x82,0x10,0x02,0x10,0x00,0x00},/*"往",21*/
  32.                           {0x00,0x04,0x01,0x04,0x02,0x04,0x04,0x04,0x08,0x04,0x30,0x04,0xC0,0x05,0x00,0xFE,0x80,0x05,0x60,0x04,0x10,0x04,0x0C,0x04,0x06,0x04,0x03,0x04,0x02,0x04,0x00,0x00},/*"大",22*/
  33.                           {0x00,0x02,0x40,0x0C,0x40,0x08,0x40,0x48,0x40,0x3A,0x40,0x2A,0x42,0x0A,0x41,0x8A,0xFE,0x7A,0x40,0x2B,0x40,0x0A,0x40,0x18,0x40,0xEA,0x40,0x4C,0x40,0x08,0x00,0x00},/*"學",23*/
  34.                           {0x20,0x08,0x30,0x08,0xE0,0xFF,0x42,0x08,0x4C,0x08,0xF0,0x1F,0x10,0x12,0x1A,0x12,0xF2,0x13,0x04,0x10,0xC8,0xFF,0x30,0x10,0xCC,0x50,0x02,0x37,0x1C,0x12,0x00,0x00},/*"城",24*/
  35.                           {0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",25*/
  36.                           {0x00,0x02,0x00,0x42,0x00,0x32,0xFE,0x23,0x04,0x00,0x08,0x44,0xFF,0x55,0x50,0x55,0x50,0x55,0x50,0xFD,0x52,0x55,0x51,0x55,0xFE,0x55,0x00,0x44,0x00,0x04,0x00,0x00},/*"請",26*/
  37.                           {0x00,0x01,0x04,0x02,0x1C,0x0C,0xC0,0x3F,0x1C,0xC0,0x02,0x09,0x02,0x16,0x92,0x60,0x4A,0x20,0x82,0x2F,0x02,0x20,0x0E,0x24,0x00,0x22,0x90,0x31,0x0C,0x20,0x00,0x00},/*"您",27*/
  38.                           {0x82,0x00,0x02,0x01,0x22,0x06,0x22,0x38,0x22,0x04,0x22,0x03,0x22,0x00,0xFE,0xFF,0xA2,0x00,0x22,0x01,0x22,0x02,0x22,0x3C,0x22,0x02,0x02,0x01,0x02,0x00,0x00,0x00},/*"坐",28*/
  39.                           {0x01,0x08,0xC2,0x08,0x44,0x0F,0x28,0xF8,0x30,0x08,0xCE,0x0F,0x04,0x01,0x00,0x41,0x02,0x41,0x01,0x41,0xFE,0x4F,0x00,0x51,0x00,0x61,0x00,0x41,0x00,0x01,0x00,0x00},/*"好",29*/
  40.                           {0x42,0x08,0x81,0x08,0xFE,0xFF,0x00,0x09,0x01,0x0A,0x01,0x01,0x02,0x11,0x0C,0x11,0x30,0x11,0xC0,0xFF,0x30,0x11,0x08,0x11,0x06,0x11,0x03,0x11,0x02,0x01,0x00,0x00},/*"扶",30*/
  41.                           {0x20,0x08,0xC0,0x48,0x00,0x4B,0xFF,0x7F,0x00,0x89,0x9C,0x88,0x00,0x10,0xBC,0x2A,0x82,0xCA,0xC2,0x4A,0xB2,0x5A,0x82,0x6A,0xAE,0x0A,0x90,0x0F,0x0C,0x00,0x00,0x00},/*"穩",31*/
  42.                           {0x00,0x00,0x00,0x00,0x00,0x00,0xFA,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"!",32*/
  43.                           {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}/* "  " */
  44.                       };
  45. void delay(void);
  46. int16 offset;
  47. void main(void)
  48. {
  49.     int8 i;
  50.     int8 *p;
  51.     flag=0x10;
  52.     n=0;
  53.     TMOD=0x01;
  54.     TH0=0xb1;
  55.     TL0=0xe0;
  56.     ET0=1;
  57.     EA=1;
  58.     TR0=1;
  59.     p=&table[0][0];
  60.     while (1)
  61.     {
  62.         for (i=0;i<8;i++)    //顯示左半邊屏幕
  63.         {
  64.             P0=*(p+offset+2*i);
  65.             P2=i|0x08;    //P2.4=0,P2.3=1 選中U2, 輸出掃描碼給U6
  66.             delay();
  67.             P0=*(p+offset+2*i+1);
  68.               P2=i|0x10;   //P2.4=1,P2.3=0 選中U3, 輸出掃描碼給U7
  69.             delay();
  70.         }
  71.         for (i=8;i<16;i++)     //顯示右半邊屏幕
  72.         {
  73.             P0=*(p+offset+2*i);
  74.              P2=(i-8)|0x20;   //P2.5=1 P2.4=0, P2.3=0 選中U4,輸出掃描碼U8
  75.             delay();
  76.             P0=*(p+offset+2*i+1);
  77.              P2=(i-8)|0x40;   //P2.6=1 P2.5=0, P2.4=0 選中U5,輸出掃描碼U9
  78.             delay();
  79.         }
  80.     }
  81. }
  82. …………限于本文篇幅 余下代碼請從51黑下載附件…………
下載:
16×16點陣(滾動顯示).zip (88.42 KB, 下載次數: 81)
參與人數 2黑幣 +10 收起 理由
qshappy + 5 共享資料的黑幣獎勵!
云蝸牛 + 5 絕世好帖!
收藏收藏3 分享淘帖 頂 踩
ID:207788 發表于 2017-6-4 21:36 | 只看該作者
你好,我想問下你的程序我改了一下文字,結果仿真出來還是你的文字是什么原因
ID:207385 發表于 2017-6-8 00:02 | 只看該作者
很實用,謝謝樓主!
樓主寫的很好,很實用!
ID:215879 發表于 2017-6-29 17:57 | 只看該作者
你好,這個字怎么修改啊
ID:298462 發表于 2018-5-17 16:08 | 只看該作者
學習了
ID:368859 發表于 2018-7-10 17:17 | 只看該作者
好,挺好的,韓不錯
不錯的頂頂頂頂頂
ID:218113 發表于 2018-7-14 10:33 | 只看該作者
好,感謝分享
ID:397354 發表于 2018-9-14 09:25 來自觸屏版 | 只看該作者
問一下,連線是用了一個138譯碼器和P0口接到RP1嗎?
主站蜘蛛池模板: 在线观看av不卡 | 亚洲高清免费视频 | 日本特级淫片 | 一区二区三区视频在线 | 一区二区三区在线免费观看 | 色综合久久久久 | 日韩中文字幕视频 | 视频一区在线观看 | 日本亚洲欧美 | 日韩视频在线观看免费 | 能看的av| 97在线免费观看视频 | 青草导航 | 综合网久久 | 99精品色 | 福利视频网址 | h片在线免费观看 | 精品理论片 | 欧美一级做性受免费大片免费 | 亚洲性视频| www.操| 亚洲视频二区 | 99视频在线观看免费 | 1级黄色片 | 黄色a一级片 | www.日本高清 | 亚洲精品影院 | 国产伦理一区 | www.欧美在线 | 天天综合天天做天天综合 | 亚洲精品二区 | 欧美日韩视频一区二区 | 99国产精品99久久久久久 | 久久一二三区 | 在线中文字幕 | 国产一区精品视频 | 亚洲免费视频观看 | 亚洲丝袜av| 亚洲午夜18毛片在线看 | 日本国产一区 | 免费91网站 |
