查看: 38600|回復: 77
stm32驅動lcd1602液晶方式 程序調試成功
ID:190471 發表于 2017-4-17 15:48 | 顯示全部樓層 |閱讀模式
最近在搞DIY小玩意 用到了lcd1602液晶顯示 最后調試成功,希望對有需要的人有所幫助!
1602液晶驅動程序的主要部分:
  1. #include "lcd1602.h"
  2. #include "delay.h"
  3. #include "stdio.h"
  4. void GPIO_Configuration(void)
  5. {
  6.         GPIO_InitTypeDef        GPIO_InitStructure;
  7.
  8.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOD,ENABLE);//使能PB,PD端口時鐘
  9.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  10.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //普通輸出模式
  11.     GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽輸出
  12.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //IO口速度為50MHz
  13.         GPIO_Init(GPIOD, &GPIO_InitStructure);                                //初始化GPIOD0~7
  14.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
  15.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //普通輸出模式
  16.     GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽輸出
  17.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //IO口速度為50MHz
  18.         GPIO_Init(GPIOB, &GPIO_InitStructure);                                //初始化GPIB15,14,13
  19. }
  20. /* 等待液晶準備好 */
  21. void LCD1602_Wait_Ready(void)
  22. {
  23.         u8 sta;
  24.
  25.         DATAOUT(0xff);
  26.         LCD_RS_Clr();
  27.         LCD_RW_Set();
  28.         do
  29.         {
  30.                 LCD_EN_Set();
  31.                 delay_ms(5);        //延時5ms,非常重要
  32.                  sta = GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_7);//讀取狀態字
  33.                 LCD_EN_Clr();
  34.         }while(sta & 0x80);//bit7等于1表示液晶正忙,重復檢測直到其等于0為止
  35. }
  36. /* 向LCD1602液晶寫入一字節命令,cmd-待寫入命令值 */
  37. void LCD1602_Write_Cmd(u8 cmd)
  38. {
  39.         LCD1602_Wait_Ready();
  40.         LCD_RS_Clr();
  41.         LCD_RW_Clr();
  42.         DATAOUT(cmd);
  43.         LCD_EN_Set();
  44.         LCD_EN_Clr();
  45.     //printf("%d",cmd);
  46. }
  47. /* 向LCD1602液晶寫入一字節數據,dat-待寫入數據值 */
  48. void LCD1602_Write_Dat(u8 dat)
  49. {
  50.         LCD1602_Wait_Ready();
  51.         LCD_RS_Set();
  52.         LCD_RW_Clr();
  53.         DATAOUT(dat);
  54.         LCD_EN_Set();
  55.         LCD_EN_Clr();
  56. }
  57. /* 清屏 */
  58. void LCD1602_ClearScreen(void)
  59. {
  60.         LCD1602_Write_Cmd(0x01);
  61. }
  62. /* 設置顯示RAM起始地址,亦即光標位置,(x,y)-對應屏幕上的字符坐標 */
  63. void LCD1602_Set_Cursor(u8 x, u8 y)
  64. {
  65.         u8 addr;
  66.
  67.         if (y == 0)
  68.                 addr = 0x00 + x;
  69.         else
  70.                 addr = 0x40 + x;
  71.         LCD1602_Write_Cmd(addr | 0x80);
  72. }
  73. /* 在液晶上顯示字符串,(x,y)-對應屏幕上的起始坐標,str-字符串指針 */
  74. void LCD1602_Show_Str(u8 x, u8 y, u8 *str)
  75. {
  76.         LCD1602_Set_Cursor(x, y);
  77.         while(*str != '\0')
  78.         {
  79.                 LCD1602_Write_Dat(*str++);
  80.         }
  81. }
  82. /* 初始化1602液晶 */
  83. void LCD1602_Init(void)
  84. {
  85.     GPIO_Configuration();
  86.         LCD1602_Write_Cmd(0x38);        //16*2顯示,5*7點陣,8位數據口
  87.         LCD1602_Write_Cmd(0x0c);        //開顯示,光標關閉
  88.         LCD1602_Write_Cmd(0x06);        //文字不動,地址自動+1
  89.         LCD1602_Write_Cmd(0x01);        //清屏
  90. //    LCD1602_Write_Cmd(0X02);
  91. //    LCD1602_Write_Cmd(0X06);
  92. //        LCD1602_Write_Cmd(0X00);
  93. //        LCD1602_Write_Cmd(0X0C);
  94. //        LCD1602_Write_Cmd(0X38);
  95. //        LCD1602_Write_Cmd(0x01);
  96.
  97. }
下載:
lcd1602顯示.7z (294.08 KB, 下載次數: 1492)
參與人數 4黑幣 +20 收起 理由
z72287 + 5 很給力!
zqs222 + 5 很給力!
sdfasfsdfsdf + 5 很給力!
cheeselala + 5 很給力!
ID:220748 發表于 2018-12-12 21:27 | 顯示全部樓層
祝賀stm32驅動lcd1602液晶方式程序調試成功!
但沒有看見電路圖,所以不知液晶顯示什么?輸入什么信號?看標題好像是檢測指紋,對么?
1602液晶數據端口接到STM32d的什么引腳?
ID:220748 發表于 2018-12-13 20:50 | 顯示全部樓層
編譯時出現兩個錯誤,請幫助解決!
謝謝!!
ID:105355 發表于 2017-4-17 20:22 | 顯示全部樓層
f407...................................
ID:190672 發表于 2017-4-17 23:51 | 顯示全部樓層
謝謝分享,學習了!
ID:148108 發表于 2017-5-25 21:19 | 顯示全部樓層
謝謝樓主。幫了大忙
ID:221735 發表于 2017-7-23 15:15 | 顯示全部樓層
謝謝樓主!!
ID:91163 發表于 2017-7-23 20:19 | 顯示全部樓層
stm32這么快,搞1602怪浪費的
ID:241124 發表于 2017-10-19 22:55 | 顯示全部樓層
謝謝分享!!!
ID:242484 發表于 2017-10-24 16:46 | 顯示全部樓層
剛剛好用到
ID:233664 發表于 2017-12-9 13:09 | 顯示全部樓層
顯示一個變量行嗎?
ID:259891 發表于 2017-12-11 09:33 | 顯示全部樓層
謝謝分享 正好需要
ID:275121 發表于 2018-1-13 20:24 | 顯示全部樓層
非常感謝,
ID:279429 發表于 2018-1-25 14:44 | 顯示全部樓層
謝謝樓主分享
ID:279429 發表于 2018-1-25 15:09 | 顯示全部樓層
非常感謝
ID:234038 發表于 2018-1-28 21:23 | 顯示全部樓層
謝謝啦  剛好要用 試試看
ID:283718 發表于 2018-2-11 20:08 | 顯示全部樓層
支持支持
ID:272345 發表于 2018-2-28 09:56 | 顯示全部樓層
謝謝樓主
ID:297898 發表于 2018-3-28 15:13 | 顯示全部樓層
用不了啊,我rw直接接地的,只用于顯示。就把有關rw的全注釋了,對應的腳也改了,嘗試了幾次什么都沒顯示。
ID:287482 發表于 2018-4-2 17:09 | 顯示全部樓層
謝謝樓主  幫了大忙
ID:301675 發表于 2018-4-7 12:30 | 顯示全部樓層
謝謝分享
ID:284518 發表于 2018-4-10 09:50 | 顯示全部樓層
感謝樓主分享,非常感謝
ID:305418 發表于 2018-4-10 20:25 | 顯示全部樓層
感謝樓主!
ID:306466 發表于 2018-4-12 11:16 | 顯示全部樓層
謝謝樓主分享,正好需要用到
ID:315667 發表于 2018-4-24 20:20 | 顯示全部樓層
謝謝!非常需要!
ID:326724 發表于 2018-5-10 12:31 | 顯示全部樓層
謝分享
ID:326772 發表于 2018-5-10 13:43 | 顯示全部樓層
謝謝分享,學習了!
ID:290647 發表于 2018-5-21 15:39 | 顯示全部樓層
謝謝。。。很棒
ID:319334 發表于 2018-6-5 15:07 | 顯示全部樓層
非常感謝
ID:367898 發表于 2018-7-9 13:41 | 顯示全部樓層
需要下載看看
ID:368558 發表于 2018-7-10 11:27 | 顯示全部樓層
謝謝樓主很給力
ID:375746 發表于 2018-7-20 12:40 | 顯示全部樓層
謝謝樓主
ID:376963 發表于 2018-7-21 22:39 | 顯示全部樓層
感謝樓主,好人一生平安
ID:380780 發表于 2018-7-30 11:21 | 顯示全部樓層
感謝,好用了再夸獎
ID:372701 發表于 2018-8-2 16:04 | 顯示全部樓層
很給力
ID:372701 發表于 2018-8-2 16:07 | 顯示全部樓層
感謝大佬
ID:384753 發表于 2018-8-10 20:02 | 顯示全部樓層
唉  沒黑幣啊
ID:218309 發表于 2018-9-11 13:36 | 顯示全部樓層
做一個數據是4線的
ID:390236 發表于 2018-9-11 14:45 | 顯示全部樓層
謝謝樓主
ID:403971 發表于 2018-9-29 11:37 | 顯示全部樓層
感謝樓主分享!
ID:420871 發表于 2018-11-5 09:25 | 顯示全部樓層
感謝樓主分享!
ID:259517 發表于 2018-11-8 21:16 | 顯示全部樓層
很好,資料不錯,謝謝分享
主站蜘蛛池模板: 一区二区影视 | 99久久综合| 国产精品午夜视频 | 午夜激情视频在线观看 | 日本黄色三级视频 | 97久久久久 | 美日韩一区二区 | 成人综合婷婷国产精品久久 | 97视频在线观看免费 | 黄色一集片| 久久福利视频导航 | 亚洲欧美视频在线观看 | 国产亚洲视频在线观看 | 国产传媒视频在线观看 | 天堂av网站| 国产一区二区三区在线 | 欧美精品一二三区 | 欧美视频在线观看一区 | 亚洲国产成人91精品 | 九色91popny蝌蚪| 日韩欧美黄色 | 国产免费成人 | 国产一区二区福利 | 国产一区二区三区久久 | 亚洲网在线 | 好色婷婷 | 色综合久久88色综合天天 | 日本黄色一级视频 | 五月婷婷色 | 国产精品欧美激情 | 日产久久视频 | 色婷婷丁香| 成年人视频在线播放 | 亚洲性生活片 | 国产精品伦一区二区三级视频 | www.日本在线观看 | 亚洲毛片视频 | 青青草网站 | 黄色片视频在线观看 | 国产精品区二区三区日本 | 一级a毛片 |
