查看: 2436|回復: 0
自己編的一段代碼,怎么樣可以加一段鬧鐘,求大神
ID:193544 發表于 2017-4-25 20:01 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
        uchar code table0[]=" 2017-4-25  TUE ";
        uchar code table1[]="    00:00:00";
        uchar code table2[]="  201405204106  ";
        uchar code table3[]="DianXin GaoXiang";
        uchar code table4[]="MONTUEWEDTHUFRISATSUN";
        uchar count,s1num;
        char miao,fen,shi,ri,yue,flag,flag_di,flag1,amiao,afen,ashi;
        uint nian;
        sbit lcd_rs = P2^5;
        sbit lcd_rw = P2^6;
        sbit lcd_en = P2^7;
        sbit s1=P3^0;        //主按鍵
        sbit s2=P3^1;        //加
        sbit s3=P3^2;        //減
        sbit s4=P3^3;        //開啟鬧鐘
        sbit beep=P2^0;   //
        sbit Output_squ=P3^6;
        void delay(uint z)//延時子函數
                uint x,y;
                for(x=z;x>0;x--)
                        for(y=110;y>0;y--);
        void write_com(uchar com)//寫命令函數
                lcd_rs = 0;
                P0= com;
                delay(5);
                lcd_en=1;
                delay(5);
                lcd_en=0;
        void write_date(uchar date)//寫數據函數
                lcd_rs = 1;
                P0= date;
                delay(5);
                lcd_en=1;
                delay(5);
                lcd_en=0;
        void init()//初始化函數
            int num;
                shi=0;
                fen=0;
                miao=0;
                ri=25;
                yue=4;
                nian=2017;
                lcd_en=0;
                lcd_rw=0;
                write_com(0x38);//顯示設置模式
                write_com(0x0c);//00001100開顯示,不顯示光標,光標不閃爍
            write_com(0x06);//00000110地址指針加一,整屏不移動
                write_com(0x01);//清屏
                write_com(0x80);
                for(num=0;num<16;num++)//顯示數字201405204106
                        write_date(table2[num]);
                        delay(100);
                write_com(0x80+0x40);
                for(num=0;num<16;num++)//顯示DianXin GaoXiang
                        write_date(table3[num]);
                        delay(100);
                delay(500);
                write_com(0x01);
                write_com(0x80);
                for(num=0;num<16;num++)//顯示日期
                        write_date(table0[num]);
                        delay(5);
                for(num=0;num<12;num++)//顯示時間
                        write_date(table1[num]);
                        delay(5);
                TMOD=0x51;//啟動定時器中斷
                TH0=0X3C; //50ms
                TL0=0XB0;
                TH1=0X00;
                TL1=0X00;
                EA=1;
                ET0=1;
                TR0=1;//打開定時器0
                TR1=1; //打開定時器0
        void write_sfm(uchar add,uchar date)//寫時分秒函數
                uchar shi,ge;
                shi=date/10;
                ge=date%10;
                write_com(0x80+0x40+add);
                write_date(0x30+shi);
                write_date(0x30+ge);
        void write_nyr(uint add,uint date)//寫年月日函數,此處若用uchar范圍只有0-255
        {        //不夠,改用uint(0-65535)
                uint qian,bai,shi,ge;
                qian=date/1000;
                bai=date%1000/100;
                shi=date%100/10;
                ge=date%10;
                write_com(0x80+add);
                write_date(0x30+qian);
                write_date(0x30+bai);
        void write_yr(uchar add,uchar date)//寫月日函數
                uchar shi,ge;
                shi=date/10;
                ge=date%10;
        void keyscan()//按鍵掃描函數
                int m,n;
                if(s1==0)
                        delay(5);
                        if(s1==0)//按鍵1光標移位掃描
                                s1num++;
                                if(s1num==1)
                                    while(!s1);//等待按鍵松手
                                        write_com(0x80+0x40+10);
                                        TR0=0;//關閉定時器
                                        write_com(0x0f);  //開顯示,顯示光標,光標閃爍
                                if(s1num==2)
                                        while(!s1);
                                        write_com(0x80+0x40+7);
                                if(s1num==3)
                                        while(!s1);
                                        write_com(0x80+0x40+4);
                                if(s1num==4)
                                        while(!s1);
                                        write_com(0x80+3);
                                if(s1num==5)
                                        while(!s1);
                                        write_com(0x80+6);
                                if(s1num==6)
                                        while(!s1);
                                        write_com(0x80+9);
                                if(s1num==7)
                                        while(!s1)
                                        write_com(0x80+13);
                                if(s1num==8)
                                        while(!s1);
                                        s1num=0;
                                        write_com(0x0c);
                                        TR0=1;//開定時器
                if(s1num!=0)
                        if(s2==0)//按鍵2加功能
                                delay(5);
                                if(s2==0)
                                        while(!s2);
                                        if(s1num==1)//秒加
                                                miao++;
                                                if(miao==60)
                                                        miao=0;
                                                write_sfm(10,miao);
                                        if(s1num==2)//分加
                                                fen++;
                                                if(fen==60)
                                                        fen=0;
                                                write_sfm(7,fen);
                                        if(s1num==3)//時加
                                                shi++;
                                                if(shi==24)
                                                        shi=0;
                                                write_sfm(4,shi);
                                        if(s1num==4)//年加
                                                nian++;
                                                if(nian==10000)
                                                        nian=2000;
                                                write_nyr(1,nian);
                                                write_com(0x80+3);
                                        if(s1num==5)//月份加
                                                yue++;
                                                if(yue==13)
                                                        yue=1;
                                                write_yr(6,yue);
                                                write_com(0x80+6);
                                        if(s1num==6)//日期加
                                                ri++;
                                                if(ri==29&&yue==2&&!((nian%4==0&&nian%100!=0)||nian%400==0))
                                                        ri=1;//平年
                                                if(ri==30&&yue==2&&((nian%4==0&&nian%100!=0||nian%400==0)))
                                                        ri=1;//閏年
                                                if(ri==31&&(yue==4||yue==6||yue==9||yue==11))
                                                        ri=1;
                                                if(ri==32)
                                                        ri=1;
                                                write_yr(9,ri);
                                                write_com(0x80+9);
                                        if(s1num==7)//星期加
                                                m=m+3;
                                                if(m==21)
                                                        m=0;
                                                write_com(0x80+12);
                                                for(n=m;n<m+3;n++)
                                                        write_date(table4[n]);
                                                        delay(5);
                                                write_com(0x80+13);
                        if(s3==0)//按鍵3減功能
                                delay(5);
                                if(s3==0)
                                        while(!s3);
                                        if(s1num==1)//秒減
                                                miao--;
                                                if(miao==-1)
                                                        miao=59;
                                                write_sfm(10,miao);
                                        if(s1num==2)//分減
                                                fen--;
                                                if(fen==-1)
                                                fen=59;
                                                write_sfm(7,fen);
                                        if(s1num==3)//時減
                                                shi--;
                                                if(shi==-1)
                                                        shi=23;
                                                write_sfm(4,shi);
                                        if(s1num==4)//年減
                                                nian--;
                                                if(nian==1999)
                                                        nian=2000;
                                                write_nyr(1,nian);
                                                write_com(0x80+3);
                                        if(s1num==5)//月份減
                                                yue--;
                                                if(yue==0)
                                                        yue=12;
                                                write_yr(6,yue);
                                                write_com(0x80+6);
                                        if(s1num==6)//日減
                                                ri--;
                                                if(ri==0)
                                                        if(yue==2&&!((nian%4==0&&nian%100!=0)||nian%400==0))
        ri=28;//平年
                                                        if(yue==2&&((nian%4==0&&nian%100!=0||nian%400==0)))
        ri=29;//閏年
                                                        if(yue==4||yue==6||yue==9||yue==11)
        ri=30;
                                                        if(yue==1||yue==3||yue==5||yue==7||yue==9||yue==11)
        ri=31;
                                                write_yr(9,ri);
                                                write_com(0x80+9);
                                        if(s1num==7)//星期減
                                                m=m-3;
                                                if(m==0)
                                                        m=21;
                                                write_com(0x80+12);
                                                for(n=m;n-3<m;n++)
                                                        write_date(table4[n-3]);
                                                        delay(5);
                                                write_com(0x80+13);
                int i,j;
                init();
                         keyscan();
                        if(TL1==8)
                        {        TH1=0X00;
                                TL1=0X00;
                                miao++;
                                if(miao==60)
                                        miao=0;
                                        fen++;
                                        if(fen==60)
                                                fen=0;
                                                shi++;
                                                if(shi==24)
                                                        shi=0;
                                                        ri++;
                                                        j=j+3;
                                                        if(j==21)
        j=0;
                                                        write_com(0x80+12);
                                                        for(i=j;i<j+3;i++)
        write_date(table4[i]);
        delay(5);
        ri=1;yue++;//平年
        ri=1;yue++;//閏年
        ri=1;yue++;
                                                        if(ri==32)
        ri=1;yue++;
                                                        if(yue==13)
        yue=1;
        nian++;
        if(nian==10000)
        nian=2000;
        write_nyr(1,nian);
                                                        write_yr(6,yue);
                                                write_yr(9,ri);
                                                write_sfm(4,shi);
                                        write_sfm(7,fen);
                                write_sfm(10,miao);
        void timer() interrupt 1
                TH0=0X3C;
                TL0=0XB0;
                Output_squ=~Output_squ;
主站蜘蛛池模板: 久久这里只有 | 国产在线黄色 | 国产精品视频在线观看 | 999在线视频 | 又黄又爽又刺激的视频 | 国产黄色在线播放 | 欧美在线天堂 | 国产精品99久久久久久久久久久久 | 久久99深爱久久99精品 | 亚洲国产精品久久久久 | 中文字幕免费看 | 中国特级毛片 | 在线视频日韩 | 色妞网站 | 欧美成人综合 | 日韩精品免费视频 | 亚洲高清免费 | 亚洲欧美日韩国产 | 激情导航 | 午夜黄色影院 | 亚洲久久久久 | 99视频网站| 久久精品福利 | 成人免费视屏 | 日韩中文字幕一区二区三区 | 最新av在线| 亚洲一区在线看 | 日韩色综合 | 精品久久久久久久久久 | 欧美日韩亚洲一区二区三区 | 国产福利在线观看 | 亚洲成人av在线 | 天天看天天干 | 亚洲一区在线观看视频 | 亚洲一区二区三区在线视频 | 成人激情在线观看 | 一区在线视频 | 久久综合伊人 | 18视频在线观看 | 欧美在线一区二区三区 | 日韩不卡在线 |
