if(PWM)
PWM=0;
PWM=1;
為什么不直接寫成PWM=!PWM;??
還有就是你把P1^0聲明做PWM時(shí),下面用"if(PWM)"如果P1.0腳外面接了負(fù)載約1K下地時(shí),
可能會(huì)導(dǎo)致下次檢測if(PWM)時(shí)PWM讀出狀態(tài)一直保持為0.
你要改頻率的話,
#include"reg52.h"
#define uchar unsigned char
#define uint unsigned int
sbit PWM=P1^0;
sbit KEY1=P1^1;
sbit KEY2=P1^2;
uint mun;
void Delayms(unsigned int ms) //1mS@11.0592MHz
{unsigned char i, j;
while(ms--)
i = 11;
j = 190;
do
while (--j);
} while (--i);}
TMOD=0x01;
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;
EA=1;
ET0=1;
TR0=1;
if(!KEY1)
Delayms(10);
if(!KEY1)
num++;
if(!KEY2)
Delayms(10);
if(!KEY2)
num--;
void T0_time(void) interrupt 1
TH0=(65536-mun)/256;
TL0=(65536-mun)%256;
//if(PWM)
//PWM=0;
//else
//PWM=1;
PWM=!PWM;
