查看: 2669|回復: 0
基于protues的ampire12864漢字顯示
ID:192154 發表于 2017-5-7 15:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
file:///C:/Users/user1/AppData/Local/Temp/msohtml1/01/clip_image002.jpg
中文資料文庫地址:
http://wenku.baidu.com/link?url=2RskpTcACLnDJp-GdMjaTVbrq7HNjjeLZ_5Kvkz3Xld-PkmTcTwzUFbEfC_daKr0KcE57b_JYbeD2eX3VRI2qSAV7exIPvhsnWfnPw8ATSu
#include<reg52.h>
#include<intrins.h>
#define uchar unsigned char
sbit CS1=P2^4;
sbit CS2=P2^3;
sbit RS=P2^2;
sbit RW=P2^1;
sbit E=P2^0;
void check_busy();                   //忙檢測
void write_cmd(ucharinst);          //寫命令
void write_data(uchardat);             //寫數據
void set_xy(ucharx,uchar y);            //設置顯示坐標
void LCD_Init();                        //lcd初始化
//  字摸軟件提取出的數據,提取字模時要注意參數設置,縱向取模,字節倒序。
uchar code HZ0[6][32]={//;--  文字:    --
//;-- 宋體12;  此字體下對應的點陣為:寬x=16x16   --
{0x80,0x90,0x8C,0x84,0x84,0x84,0xF5,0x86,0x84,0x84,0x84,0x84,0x94,0x8C,0x80,0x00,0x00,0x80,0x80,0x84,0x46,0x49,0x28,0x10,0x10,0x2C,0x23,0x40,0x80,0x00,0x00,0x00},
//;-- 文字:    --
{0x10,0x88,0xC4,0x23,0xAE,0x68,0x2F,0x28,0xAE,0x20,0xD8,0x17,0x10,0xF0,0x10,0x00,0x01,0x00,0xFF,0x48,0x29,0x8D,0xFB,0x09,0xAC,0x48,0x37,0x08,0x36,0x41,0x80,0x00},
//;-- 文字:    --
{0x00,0x04,0x04,0x04,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0x04,0x04,0x04,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x20,0x20,0x00},
//;-- 文字:    --
{0x00,0x10,0x60,0x80,0x00,0xFF,0x00,0x00,0x00,0xFF,0x00,0x00,0xC0,0x30,0x00,0x00,0x40,0x40,0x40,0x43,0x40,0x7F,0x40,0x40,0x40,0x7F,0x42,0x41,0x40,0x40,0x40,0x00},
//;-- 文字:    --
{0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x80,0x00},
//;-- 文字:    --
{0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,0x90,0x90,0x98,0x14,0x13,0x50,0x30,0x00,0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7E,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x00}
uchar code FZ0[10][32]={
/*-- 文字:  I  --*/
/*-- 宋體12;  此字體下對應的點陣為:寬x=8x16   --*/
{0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},
/*-- 文字:     --*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
/*-- 文字:  L  --*/
{0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00},
/*-- 文字:  O  --*/
{0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00},
/*-- 文字:  V  --*/
{0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00},
/*-- 文字:  E  --*/
{0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00},
/*-- 文字:     --*/
/*-- 文字:  Y  --*/
{0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00},
/*-- 文字:  O  --*/
/*-- 文字:  U  --*/
{0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00}
/************************延時函數**************************/
voiddelayus(uchar delay)
uchar i;
for(i=0;i<=delay;i++)
_nop_();
/********************忙檢查*********************************/
voidcheck_busy()
uchar a=0;
for(a=0;a<200;a++);                  //此處為延時,一段時間后確保處于空閑狀態
/*                                      //此處為狀態查詢,查詢忙狀態,沒有使用成功,以后再調試
RW=1;
RS=0;
E=1;
     E=1;
if(!(P0&0x80))
break;
         a++;
if(a>10)
                   break;
E=1;
/********************寫命令函數*********************************/
voidwrite_cmd(ucharinst)
check_busy();
RS=0;
RW=0;
E=1;
P3=inst;
E=0;
_nop_();
/********************寫數據函數*********************************/
voidwrite_data(uchardat)
check_busy();
RS=1;
RW=0;
E=1;
P3=dat;
E=0;
_nop_();
/********************初始化函數*********************************/
voidLCD_Init()
write_cmd(0x30);//30H--基本指令操作?
delayus(4);
write_cmd(0x0c);//開顯示,關光標,不閃爍。
delayus(10);
write_cmd(0x01);//清除顯示
delayus(10);
write_cmd(0x06);//光標的移動方向左,DDRAM的地址計數器(AC)加1
delayus(10);
/*******************設置顯示坐標*********************************/
void set_xy(ucharx,uchar y)           //x為行,y為列
if(y>=64)                            //列地址大于等于64時右屏顯示?
  CS2=0;                          //低電平選擇
         CS1=1;                            //寫右屏是左屏關閉,不然兩邊會同時顯示
         y=y-64;
else                                 //列地址小于64時左屏顯示
  CS1=0;                            //同上
         CS2=1;
write_cmd(0x40|y);                      //寫列地址
_nop_();
write_cmd(0xb8|x);                         //寫行地址?
/*******************顯示中文字體*********************************/
voiddisp_hz(ucharR,ucharL,uchar *p)
uchar i;
for(i=0;i<16;i++)
set_xy(2*R,16*L+i);           //設定顯示位置,每個漢字16*16個點,顯示時每行8*16個點,所以需要兩行8*32個點,此處為第一行
write_data(p);           //寫入DDRAM
set_xy(2*R+1,16*L+i);        //第二行
write_data(p[i+16]);
voiddisp_zf(ucharR,ucharL,uchar *p)
uchar i;
for(i=0;i<8;i++)
set_xy(2*R,8*L+i);                 //設定顯示位置,每個字母16*8個點,顯示時每行8*8個點,所以需要兩行8*16個點,此處為第一行
write_data(p);
set_xy(2*R+1,8*L+i);                //第二行
write_data(p[i+8]);
uchar k=0,n=0;
LCD_Init();                  //初始化
for(k=0;k<6;k++)
disp_hz(1,1+k,HZ0[k]);          //顯示安徽工業大學
for(n=0;n<10;n++)
disp_zf(2,3+n,FZ0[n]);            //顯示 I LOVE YOU
while(1){;};
主站蜘蛛池模板: 爱爱免费网站 | 美日韩精品 | 日韩精品影视 | 日日干视频 | 中国av片 | 亚洲免费小视频 | 成人xxx| 欧美精品在线播放 | 中文在线免费看视频 | 午夜国产在线观看 | 在线日韩av| 在线看片你懂的 | 久久夜色精品国产欧美乱极品 | 国产免费视频 | 国产福利网站 | 97久久久久 | 天天色天天色 | 成人在线视频观看 | 操日本老女人 | 日本黄色免费视频 | 国产精品自在线 | 日本黄a三级三级三级 | 夜夜嗷| 久久久久久久久久久久久久 | 激情综合久久 | 人人爱人人插 | 亚洲精品视频在线观看免费 | 成年在线观看 | 国产三级做爰高清在线 | 天天干天天摸 | 黄视频免费看网站 | 日韩av毛片 | 亚洲欧美在线一区 | 亚洲激情中文字幕 | 精品国产欧美一区二区三区成人 | 日韩美女在线观看 | 在线观看亚洲 | 久久九九免费视频 | 精品视频免费在线观看 | 一区二区精品 | 精品aaa|
