這個(gè)是本人做的一個(gè)紅綠燈系統(tǒng),由12864顯示,有無線傳輸兩個(gè)道路的信息以及交通擁堵情況。
單片機(jī)發(fā)送源程序如下:
- //簡介:第一行顯示,距離時(shí)間
- //第二行顯示,還剩
- //第三行顯示,00時(shí),00分,00秒
- //第四行顯示, 周林
- //按下旋鈕開關(guān),開始設(shè)定秒,秒編輯位閃動(dòng)。左右旋轉(zhuǎn)設(shè)定數(shù)值,
- //在按下開關(guān),秒確定,設(shè)定分,分編輯位閃動(dòng)左右調(diào)數(shù)值,
- //再按下,分確定,小時(shí)位閃動(dòng)。左右轉(zhuǎn)調(diào)小時(shí),再按一下。時(shí)間確定,開始倒計(jì)時(shí)。到達(dá)定
- //時(shí)時(shí)間后停止,并閃動(dòng)。
- #include <reg52.h>
- #include <intrins.h>
- /********************* 定義 ********************************/
- #define LCD_data P0 //數(shù)據(jù)口
- sbit LCD_RS = P2 ^ 6; //寄存器選擇輸入
- sbit LCD_RW = P2 ^ 5; //液晶讀/寫控制
- sbit LCD_EN = P2 ^ 7; //液晶使能控制
- sbit LCD_PSB = P3 ^ 2; //串/并方式控制
- sbit LCD_RST = P3 ^ 4; //液晶復(fù)位端口
- sbit bz = P1 ^ 0;
- sbit hw1=P2^3;
- sbit hw2=P2^4;
- sbit sset=P3^0;//設(shè)置按鈕
- sbit spk=P3^1;
- sbit sadd=P3^3;
- sbit sdel=P1^0; //按下開始計(jì)時(shí)
- //sbit FW= RST;
- sbit d1 = P2^0;
- sbit d2 = P2^1;
- sbit d3 = P2^2;
- void TimerConfiguration();
- unsigned int Time, g, y;
- signed int second=0,minute=0,hour=0,count=0,keycount=0;
- signed char key=0;
- unsigned char code DIS1[] =
- "距離綠燈時(shí)間"
- unsigned char code DIS2[] =
- "還剩:"
- unsigned char code DIS31[] =
- "堵車距離: 50m"
- unsigned char code DIS32[] =
- "不堵車"
- }; unsigned char code DIS33[] =
- "秒"
- unsigned char code DIS4[] =
- "堵車距離: 100m"
- unsigned char code DIS5[] =
- "楊振林余偉樊曉莉"
- unsigned char code table2[]="0123456789";
- char code reserve[3]_at_ 0x3b; //保留0x3b開始的3個(gè)字節(jié)
- /*********************延時(shí)子函數(shù)**************************/
- void delayNOP()//us延時(shí)子函數(shù) (4.34us)
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- void delayms(unsigned int ms)//ms延時(shí)子函數(shù)
- unsigned char y;
- while (ms--)
- for (y = 0; y < 114; y++)
- //******************檢查LCD忙狀態(tài)**************************
- bit lcd_busy()//檢查LCD忙狀態(tài) 1忙,0閑
- bit result;
- LCD_RS = 0;
- LCD_RW = 1;
- LCD_EN = 1;
- delayNOP();
- result = (bit)(P0 &0x80);
- LCD_EN = 0;
- return (result); }
- //***********************寫指令數(shù)據(jù)***********************
- void lcd_wcmd(unsigned char cmd)//寫指令數(shù)據(jù)到LCD
- while (lcd_busy())
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_EN = 1;
- P0 = cmd;
- delayNOP();
- LCD_EN = 0;
- void lcd_wdat(unsigned char dat)//寫顯示數(shù)據(jù)到LCD
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_EN = 1;
- P0 = dat;
- delayNOP();
- LCD_EN = 0;
- void writesmh(unsigned char add,unsigned char date)//顯示個(gè)位和十位數(shù)據(jù)
- unsigned char shi,ge;
- shi=date/10;
- ge=date%10;
- lcd_wcmd(0x96);
- delayms(5);
- lcd_wdat(table2[shi]);
- delayms(5);
- lcd_wdat(table2[ge]);
- delayms(5);
- //*********************初始化設(shè)定****************************
- void lcd_init()
- LCD_PSB = 1; //并口方式
- LCD_RST = 0; //液晶復(fù)位
- delayms(5); //液晶復(fù)位
- LCD_RST = 1; //液晶復(fù)位
- lcd_wcmd(0x34); //擴(kuò)充功能設(shè)定,擴(kuò)充指令,選8位數(shù)據(jù)
- delayms(5);
- lcd_wcmd(0x30); //功能設(shè)定,基本指令操作,選8位數(shù)據(jù)
- delayms(5);
- lcd_wcmd(0x0C); //顯示開,關(guān)光標(biāo),關(guān)光標(biāo)反白允許。
- delayms(5);
- lcd_wcmd(0x04); //光標(biāo)的移動(dòng)方向
- delayms(5);
- lcd_wcmd(0x01); //清除LCD的顯示內(nèi)容
- delayms(5);
- TMOD=0x01;
- TH0=0x3C;
- TL0=0xB0;
- EA=1;
- ET0=1;
- TR0=0;
- EX0=0; //外部中斷0允許
- IT0=1; //外部中斷0為邊沿觸發(fā)方式
- //*********************設(shè)定顯示位置子函數(shù)**********************
- void lcd_pos(unsigned char X, unsigned char Y)//設(shè)定顯示位置
- unsigned char pos;
- if (X == 1)
- X = 0x80;
- else if (X == 2)
- X = 0x90; }
- else if (X == 3)
- X = 0x88;
- else if (X == 4)
- X = 0x98;
- pos = X + Y; //確定顯示地址
- lcd_wcmd(pos); //寫顯示地址
- //*****************清屏子函數(shù)***************************
- void clr_screen()//清屏子函數(shù)
- lcd_wcmd(0x34); //擴(kuò)充指令操作
- delayms(5);
- lcd_wcmd(0x30); //基本指令操作
- delayms(5);
- lcd_wcmd(0x01); //清屏
- delayms(5);
- //******************閃爍子函數(shù)**************************
- void lcdflag()
- lcd_wcmd(0x08); //關(guān)閉顯示
- delayms(500);
- lcd_wcmd(0x0c); //開啟顯示
- delayms(500);
- lcd_wcmd(0x08);
- delayms(500);
- lcd_wcmd(0x0c);
- delayms(500);
- lcd_wcmd(0x08);
- delayms(500);
- lcd_wcmd(0x0c);
- delayms(500);
- //******************寫字符串子函數(shù)*************************
- void wr_string(unsigned char str[])//寫字符串子函數(shù)
- unsigned char num = 0;
- while (str[num])
- lcd_wdat(str[num++]); //寫數(shù)據(jù)
- //********************按鍵設(shè)置時(shí)間*************************
- void keyscan()//按鍵設(shè)置時(shí)間
- if(d1==0)
- TR0=1; //開始計(jì)時(shí)
- EX0=1;
- bz=0;
- if(d1==1)
- TR0=0; //停止計(jì)時(shí)
- EX0=0;
- if(keycount!=0)
- if(keycount==2)//編輯秒
- if(sadd==0)//數(shù)值加1
- delayms(100);
- if(sadd==0)
- second++;
- if(second==60)
- second=0;
- sadd=1;
- writesmh(0x0e,second);
- lcd_wcmd(0x8e);
- lcd_wcmd(0x0d);//秒位閃爍
- if(sdel==0)//數(shù)值減1
- delayms(10);
- if(sdel==0)
- if(second==0)
- second=60;
- second--;
- sdel=1;
- lcd_wcmd(0x8e);
- //void gzhi()
- //if(hw1==0)
- // g = 1;
- ////if(d1==1&&hw2==0&&hw1==0)
- //// g = 1;
- //if(d1==1&&hw2==0&&hw1==1)
- // g = 2;
- //if(d1==1&&hw2==1&&hw1==0)
- // g = 3;
- //if(d1==1&&hw2==1&&hw1==1)
- // g = 4;
- //if(d1==0&&hw2==0&&hw1==0)
- // g = 5;
- //if(d1==0&&hw2==0&&hw1==1)
- // g = 6;
- //if(d1==0&&hw2==1&&hw1==0)
- // g = 7;
- //if(d1==0&&hw2==1&&hw1==1)
- // g = 8;
- void init()//初始化子程序
- TMOD=0x20; //設(shè)置定時(shí)器T1為工作方式2
- TH1=0xfd;
- TL1=0xfd; //T1定時(shí)器裝初值
- TR1=1; //啟動(dòng)定時(shí)器T1
- REN=1; //允許串口接收
- SM0=0;
- SM1=1; //設(shè)置串口工作方式1
- EA=1; //開總中斷
- ES=1; //開串口中斷
- //主函數(shù)主函數(shù)主函數(shù)主函數(shù)主函數(shù)主函數(shù)主函數(shù)主函數(shù)主函數(shù)主函數(shù)主函數(shù)主函數(shù)主函
- //數(shù)主函數(shù)
- void main()
- init();
- delayms(100); //上電,等待穩(wěn)定
- lcd_init(); //初始化LCD
- lcd_pos(1, 0); //設(shè)置“距離綠燈時(shí)間”顯示位置為第一行
- wr_string(DIS1);
- lcd_pos(2, 0); //設(shè)置“還!憋@示位置為第二行
- wr_string(DIS2);
- lcd_pos(2, 7); //設(shè)置“秒”顯示位置為第四行
- wr_string(DIS33);
- if((Time==0&&hw2==0&&hw1==0)||(Time==0&&hw2==0&&hw1==1))
- lcd_pos(3, 0); //設(shè)置“距離綠燈時(shí)間”顯示位置為第一行
- wr_string(DIS4); //堵車100m
- if(Time==0&&hw1==0&&hw2==1)
- wr_string(DIS31); //堵車50m的
- if(Time==0&&hw1==1&&hw2==1)
- wr_string(DIS32); //不堵車
- lcd_pos(4, 0); //設(shè)置“距離綠燈時(shí)間”顯示位置為第一行
- wr_string(DIS5);
- writesmh(0x0e,second); //顯示動(dòng)態(tài)時(shí)間 秒
- delayms(5);
- TimerConfiguration();
- init();//調(diào)用初始化子程序
- while (1)
- keyscan();
- // if(Time==0)
- // d1 = 0;
- // if(Time==1200) //********************************60 40
- // d1 = 1;
- // d2 = 0;
- // if (Time ==1600)
- // d2 = 1;
- // d3 = 0;
- // if (Time ==1660)
- // d3 = 1;
- // Time = 0;
- if(Time==0&&hw1==1&&hw2==1) //11 // 60 30
- d1 = 0;
- if(Time==1200)
- d1 = 1;
- d2 = 0;
- if (Time ==1800)
- d2 = 1;
- d3 = 0;
- if (Time ==1860)
- d3 = 1;
- Time = 0;
- if(Time==0&&hw1==0&&hw2==1) //01
- d1 = 0;
- if(Time==1000&&hw1==0&&hw2==1) //**************************50 50
- d1 = 1;
- d2 = 0;
- if (Time ==2000&&hw1==0&&hw2==1 )
- d2 = 1;
- d3 = 0;
- if (Time ==2060&&hw1==0&&hw2==1)
- d3 = 1;
- Time = 0;
- if((Time==0&&hw2==0&&hw1==0)||(Time==0&&hw2==0&&hw1==1)) //***********************************40 50
- d1 = 0;
- if(Time==800&&hw2==0&&hw1==0)
- d1 = 1;
- d2 = 0;
- if (Time ==1800&&hw2==0&&hw1==0)
- d2 = 1;
- d3 = 0;
- if (Time ==1860&&hw2==0&&hw1==0)
- d3 = 1;
- Time = 0;
- //**********************中斷***************************
- void time0() interrupt 1 using 0//倒計(jì)時(shí)中斷
- TH0=0x3C;
- TL0=0xB0;
- count++;
- if(count==156&&hw1==1&&hw2==1)//11
- count=0;
- second--;
- if(second<0)
- second=60;
- minute--;
- if(minute<0)
- minute=59;
- hour--;
- if(hour<0)
- hour=24;
- lcd_pos(3, 2); //設(shè)置顯示位置為第三行,第七列
- writesmh(0x0a,hour);
- } lcd_pos(3, 4); //設(shè)置顯示位置為第三行,第七列
- writesmh(0x0c,minute);
- lcd_pos(3, 6); //設(shè)置顯示位置為第三行,第七列
- if(count==155&&hw1==0&&hw2==1) // 01
- count=0;
- second--;
- if(second<0)
- second=50;
- if(d1==1)
- second=0;
- bz=1;
- if((count==155&&hw1==0&&hw2==0)||(count==155&&hw2==0&&hw1==1)) //00
- count=0;
- second--;
- if(second<0)
- second=40;
- if(d1==1)
- second=0;
- bz=1;
- void encoder(void) interrupt 0//外部中斷0 旋轉(zhuǎn)碼開關(guān)中斷程序
調(diào)皮的紅綠燈2.rar
(100.17 KB, 下載次數(shù): 19)
2017-5-16 10:09 上傳
點(diǎn)擊文件名下載附件
紅綠燈系統(tǒng)
