查看: 3135|回復: 2
Electric thermometer by using DHT11 sensor module
ID:203082 發表于 2017-5-21 10:37 | 顯示全部樓層 |閱讀模式
As you may know, Geeetech is located in Shenzhen, a southern city of China. The weather there all year long is almost hot and humid. Getting to used it is no easy, especially when you come from a northern part of this country. March in Shenzhen is getting warmer and damper. However after days of rain recently, the temperature begins to fall again. Making an electric thermometer which can measure current temperature and humidity with LCD readout using our Arduino is a good idea.
All we need is:
  • Arduino Uno or compatible
  • DHT11 temperature and humidity sensor module
  • 16×2 character LCD module
  • 10k ohm potentiometer
  • a breadboard and a bundle of jumper wires
We could build it step by step if you have no previous experience of using DHT11 sensor and 16×2 LCD display module.
First of all, we shall take a in-depth look at DHT11 temperature and humidity sensor. This sensor includes a humidity measurement component and an NTC temperature measurement component, and connects to a high-performance 8-bit microcontroller.DHT11′s power supply is 3-5.5V DC.
The interesting thing in this module is the protocol that uses to transfer data between MCU and DHT11 sensor. All the sensor readings are sent by using a single wire bus which reduces the cost and extends the distance. One communication process is about 4ms.Data consists of decimal and integral parts. A complete data transmission is 40bit, and the sensor sends higher data bit first.
Data format: 8bit integral RH data + 8bit decimal RH data + 8bit integral T data + 8bit decimal T data + 8bit check sum.
More details related to DH11 sensor module please visit our Wiki.
Because of the original code to read DHT11 sensor module is so “obscure”, we can import a DHT sensor library to make it work more obvious and more user-friendly. You can download DHT library here, then drag the DHT folder into Arduino/libraries/ folder and restart IDE.It’s fairly easy to connect up DHT11 module to Arduino, pin S is for data output.
Now load up Examples-DHT-DHTtester sketch. Since the DHT sensor library is not only for DHT11 sensor module, but also for other types of DHT sensor, such as DHT12,DHT22. Therefore, the code need to change a bit for fitting your sensor module, or else, it doesn’t work properly.
In following step we need a 16×2 character LCD module that IC controller is HD44780 or compatible, these is usually be the common found in retail stores. There are many ways to interface this LCD to Arduino board,4-bit, 8-bit parallel and so on. Here we choose the easiest method 4-bit parallel interface.
There are 16 pins on the LCD module, pin label details please visit our wiki. The pin labels of different type may have a little change, but in general it’s almost the same. Now we can connect 16×2 LCD screen to Arduino board using the diagram below.
The 10k ohm potentiometer should be connected to pin3 for adjusting the display contrast.Likewise, for convenience, we could use the LiquidCrystal library which should pre-installed in the Arduino IDE. We can load up the Examples-LiquidCrystal-Helloworld to inspect if the Lcd sreeen is working normally.
What we do on next step is more easier, just connect the DHT11 sensor module to Arduino board.Schematic is following.
Current temperature and humidity in Shenzhen, China.
Relating code
#include "DHT.h"#include #define DHTPIN 8   #define DHTTYPE DHT11 DHT dht(DHTPIN, DHTTYPE);LiquidCrystal lcd(12, 11, 5, 4, 3, 2);void setup() {Serial.begin(9600);lcd.begin(16, 2);dht.begin();}void loop() {float h = dht.readHumidity();float t = dht.readTemperature();if (isnan(t) || isnan(h)) {  Serial.println("Failed to read from DHT");  }else {  lcd.setCursor(0,0);  lcd.print("Temp=");  lcd.print(t);  lcd.print(" *C");  lcd.setCursor(0,1);  lcd.print("Humidity=");  lcd.print(h);  lcd.print("% ");  delay(500); }}
ID:203082 發表于 2017-5-21 10:39 | 顯示全部樓層
拜托,很急 我需要5黑幣  不然這門課要掛啦!!!!
ID:68692 發表于 2017-5-25 13:20 | 顯示全部樓層
請問  DHT 庫文件在哪里有下載??
主站蜘蛛池模板: 五月婷婷综合激情 | 欧美日韩成人在线观看 | 日韩精品在线免费观看 | 日韩精品欧美 | 天堂资源 | 成人高清视频在线观看 | 91久久国产综合久久 | 国产成人91| 久久草视频 | 欧美一级黄色大片 | 免费性爱视频 | 日韩一区二区三区在线播放 | 免费的黄色小视频 | 在线视频一区二区三区 | 国产一级片视频 | av影院在线| 亚洲综合五月天婷婷丁香 | 国产黄av| 中文天堂在线观看 | 欧美亚洲视频 | 人人干人人爽 | 成人免费毛片嘿嘿连载视频 | 天天综合天天做天天综合 | a毛片在线观看 | 亚洲一区二区免费视频 | 久久精品黄色 | 亚洲精品乱码久久久久久蜜桃91 | 中文字幕www | 国产精品二区一区二区aⅴ污介绍 | 国产高潮在线观看 | 亚洲天堂一区 | 秋霞一区二区三区 | 超碰免费人人 | 99热精品在线观看 | 韩日视频| 欧美黄色免费网站 | 一区不卡| 色噜噜狠狠一区二区三区 | 国产三级做爰高清在线 | 成人一级黄色片 | 亚洲精品在线视频观看 |
