查看: 3852|回復(fù): 5
求助 單片機(jī)計(jì)時和定時再增加按鍵和跳轉(zhuǎn) 功能,各位,急急急!
求助大神,現(xiàn)在這個單片機(jī)代碼只實(shí)現(xiàn)了計(jì)時和定時功能,就key 0,1, 2三個有用,我現(xiàn)在想實(shí)現(xiàn)key3(功能待定鍵)按下,就跳轉(zhuǎn)到自己設(shè)定規(guī)定時間,再按下key3又回到初始計(jì)時顯示,當(dāng)計(jì)時到規(guī)定時間,蜂鳴器一直響。只有按下key4整個程序重新開始。以下就是代碼,求大家?guī)兔狱c(diǎn)程序?qū)崿F(xiàn)我這個功能,愿意送出我全部黑幣,萬分感謝!
#include<reg51.h>
#include"DS18B20.h"
#define uchar unsigned char
#define uint unsigned int
void delayms(uint xms); // Ñóê±oˉêy
void beep();            // ·äÃùÆ÷Ïì
void display();        // êyÂë1üÏÔê¾¼Æêy
void key_scan();       // ¼üÅìé¨Ãè
void timer_init();   // ÖD¶Ï3õê¼»ˉ
sbit key0 = P1^0;   // μ÷êÔ¿ØÖư′¼ü
sbit key1 = P1^1;   // Ôö¼ó°′¼ü
sbit key2 = P1^2;   // ¼õD¡
sbit key3 = P1^3;   // 1|Äü′y¶¨
sbit buzzer = P1^4; // ·äÃùÆ÷¶Ë¿ú
uchar  tab[];
uchar code w[] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20};    // êyÂë1üλѡ
// êyÂë1ü¶ÎÑ¡ 12òõ
uchar code table[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                        0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};   */
// 12ÑôêyÂë1ü¶ÎÂë±í
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
                        0x80,0x90,0x98,0x83,0xc6,0xa1,0x86,0x8e};
uchar count, set_place;  // count óÃóú¶¨ê±Æ÷1sÖD¶Ï  set_placeóÃóú¼ÆËã°′¼üμÄ′Îêy ±ãóúÑ¡Ôñμ÷½úÄÇ2¿·Öê±¼ä
uchar second = 0, minute = 0, hour = 0;   //3õê¼»ˉ ê±¼ä
    timer_init();
    for(; ;)
       key_scan();
        display();
void beep()
    buzzer = 1;
    delayms(2);
    buzzer = 0;
    delayms(2);
// ¼üÅìé¨Ãèoˉêy
void key_scan()
    if(key0 == 0)
        delayms(5);
        if(key0 == 0)
            set_place++;
            while(!key0);
            beep();
            if(set_place == 1)  //°′ÏÂò»′Î Ôò¶¨ê±Æ÷ÖD¶Ï
                TR0 = 0;
            if(set_place == 4)  // °′ÏÂá½′Î ¶¨ê±Æ÷′óéÏ′Î×′쬻ָ′1¤×÷
               set_place = 0;
                TR0 = 1;
    if(set_place != 0)
        if(key1 == 0)
            delayms(5);
            if(key1 == 0)
                while(!key1);   // °′¼üêí·Å
                beep();
                if(set_place == 1)
                    second++;
                    if(second == 60)
                        second = 0;
                if(set_place == 2)
                    minute++;
                    if(minute == 60)
                        minute = 0;
                if(set_place == 3)
                    hour++;
                    if(hour == 24)
                        hour = 0;
    if(set_place != 0)
     if(key2 == 0)
            delayms(5);
            if(key2 == 0)
                while(!key2);   // °′¼üêí·Å
                 beep();
                if(set_place == 1)
                    second--;
                    if(second == -1)
                        second = 59;
                if(set_place == 2)
                    minute--;
                    if(minute == -1)
                        minute = 59;
                if(set_place == 3)
                    hour--;
                    if(hour == -1)
                        hour = 23;
// êyÂë1üÏÔê¾ê±¼ä
void display()
    uchar j;
    P2 = 0x01;
    P0 = table[hour / 10];
    j = 60;
    while(j--);
    P2 = 0x02;
    P0 = table[hour % 10];
    j = 60;
    while(j--);
    P2 = 0x04;
    P0 = table[minute / 10];
    j = 60;
    while(j--);
    P2 = 0x08;
    P0 = table[minute % 10];
    j = 60;
    while(j--);
    P2 = 0x10;
    P0 = table[second / 10];
    j = 60;
    while(j--);
    P2 = 0x20;
    P0 = table[second % 10];
    j = 60;
    while(j--);
// ¶¨ê±Æ÷3õê¼»ˉ
void timer_init()
    TMOD = 0x01;    //¶¨ê±Æ÷T0 1¤×÷·½ê½1
    TH0 = (65536 - 45872) / 256;    // ×°3õÖμ 50ms
    TL0 = (65536 - 45872) % 256;
    EA = 1; //¿a·Å×üÖD¶Ï
    ET0 = 1;    //¿aÆô¶¨ê±Æ÷0ÖD¶Ï
    TR0 = 1;    //¿aÆô¶¨ê±Æ÷0
// 50msÖD¶Ï
void t0_timer() interrupt 1
    TH0 = (65536 - 45872) / 256;    // ×°3õÖμ ′Ëê±¾§ÕñÎa 11.0592MHz
    count++;
    if(count == 20) //1s ê±¼äμ½
        count = 0;
        second++;
        if(second == 60)    // ÃëÎa60 Çåáã ·Ö½øò»
            second = 0;
            minute++;
            if(minute == 60)    // ·ÖÎa60 Çåáã ê±½øò»
                minute = 0;
                hour++;
                if(hour == 24)  // ê±Îa 24 Çåáã
                    hour =0;
void delayms(uint xms)  // Ñóê±xms
    uchar i, j;
    for(i = xms; i > 0; i--)    // ¸Ä±äxmsμÄÖμ ¿éòÔμ÷½úÑóê±ê±¼ä
    for(j = 110; j > 0; j--);
ID:149988 發(fā)表于 2017-5-26 16:54 | 只看該作者
RE: 求助 單片機(jī)計(jì)時和定時再增加按鍵和跳轉(zhuǎn) 功能,各位,急急急!
你的軟件設(shè)定還有問題,注解部分還是亂碼,解決方法:點(diǎn)擊Edit、點(diǎn)擊Colors&Fonts、點(diǎn)擊8051:Editor C Files、右側(cè)列表中點(diǎn)擊Text、將右側(cè)選項(xiàng)Use Color in Comments前勾選去掉,再試試,正確了在進(jìn)行編程,否則別人看不懂你做了些什么,就不會幫你修改程序。
ID:82765 發(fā)表于 2017-5-26 23:16 | 只看該作者
提示: 作者被禁止或刪除 內(nèi)容自動屏蔽
ID:198696 發(fā)表于 2017-5-27 08:57 | 只看該作者
不倒翁.WZT 發(fā)表于 2017-5-26 16:54
你的軟件設(shè)定還有問題,注解部分還是亂碼,解決方法:點(diǎn)擊Edit、點(diǎn)擊Colors&Fonts、點(diǎn)擊8051:Editor C Fil ...
不好意思是這樣!
#include<reg51.h>
#include"DS18B20.h"
void delayms(uint xms); // 延時函數(shù)
void beep();            // 蜂鳴器響
void display();        //數(shù)碼管顯示計(jì)數(shù)
void key_scan();       // 鍵盤掃描
void timer_init();   // 中斷初始化ˉ
sbit key0 = P1^0;   // 調(diào)試控制按鍵
sbit key1 = P1^1;   // 增加控制
sbit key2 = P1^2;   // 減小控制
sbit key3 = P1^3;   // 功能待定
sbit buzzer = P1^4; // 蜂鳴器端口
uchar  tab[];
uchar code w[] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20};    //數(shù)碼管位選
// 數(shù)碼管段選 共陰
//共陽數(shù)碼管段碼表
uchar count, set_place;  // count 用于定時器1s中斷 set_place 用于計(jì)算按鍵的次數(shù) 便于選擇調(diào)節(jié)那部分時間
uchar second = 0, minute = 0, hour = 0;   //初始化時間
    timer_init();
    for(; ;)
       key_scan();
        display();
void beep()
    buzzer = 1;
    delayms(2);
    buzzer = 0;
    delayms(2);
// 鍵盤掃描函數(shù)
void key_scan()
    if(key0 == 0)
        delayms(5);
        if(key0 == 0)
            set_place++;
            while(!key0);
            beep();
            if(set_place == 1)  //按下一次 則定時器中斷
                TR0 = 0;
            if(set_place == 4)  // 按下兩次 定時器從上次狀態(tài)恢復(fù)工作
               set_place = 0;
                TR0 = 1;
    if(set_place != 0)
        if(key1 == 0)
            delayms(5);
            if(key1 == 0)
                while(!key1);   // 按鍵釋放
                beep();
                if(set_place == 1)
                    second++;
                    if(second == 60)
                        second = 0;
                if(set_place == 2)
                    minute++;
                    if(minute == 60)
                        minute = 0;
                if(set_place == 3)
                    hour++;
                    if(hour == 24)
                        hour = 0;
    if(set_place != 0)
     if(key2 == 0)
            delayms(5);
            if(key2 == 0)
                while(!key2);   // 按鍵釋放
                 beep();
                if(set_place == 1)
                    second--;
                    if(second == -1)
                        second = 59;
                if(set_place == 2)
                    minute--;
                    if(minute == -1)
                        minute = 59;
                if(set_place == 3)
                    hour--;
                    if(hour == -1)
                        hour = 23;
// 數(shù)碼管顯示時間
void display()
    uchar j;
    P2 = 0x01;
    j = 60;
    while(j--);
    P2 = 0x02;
    j = 60;
    while(j--);
    P2 = 0x04;
    j = 60;
    while(j--);
    P2 = 0x08;
    j = 60;
    while(j--);
    P2 = 0x10;
    j = 60;
    while(j--);
    P2 = 0x20;
    j = 60;
    while(j--);
// 定時器初始化
void timer_init()
    TMOD = 0x01;    //定時器T0 工作方式1
    TH0 = (65536 - 45872) / 256;    // 裝初值 50ms
    EA = 1; //開放總中斷
    ET0 = 1;    //開啟定時器中段
    TR0 = 1;    //開啟定時器0
// 50ms中斷
    TH0 = (65536 - 45872) / 256;    //裝初值 此時晶振為11.0592MHz
    count++;
    if(count == 20) //1s 時間到
        count = 0;
        second++;
        if(second == 60)    // 秒為60 清零 分進(jìn)一
            second = 0;
            minute++;
            if(minute == 60)    // 分為60 清零 時進(jìn)一
                minute = 0;
                hour++;
                if(hour == 24)  // 時為24清零
                    hour =0;
void delayms(uint xms)  //延時xms
    uchar i, j;
    for(i = xms; i > 0; i--)    // 改變xms的值 可以調(diào)節(jié)延時時間
ID:198696 發(fā)表于 2017-5-27 08:58 | 只看該作者
cjjcjj1 發(fā)表于 2017-5-26 23:16
你這僅有的點(diǎn)注釋,還是亂碼
不好意思是這樣!
#include<reg51.h>
#include"DS18B20.h"
uchar  tab[];
// 數(shù)碼管段選 共陰
//共陽數(shù)碼管段碼表
    timer_init();
    for(; ;)
       key_scan();
        display();
void beep()
    buzzer = 1;
    delayms(2);
    buzzer = 0;
    delayms(2);
// 鍵盤掃描函數(shù)
void key_scan()
    if(key0 == 0)
        delayms(5);
        if(key0 == 0)
            set_place++;
            while(!key0);
            beep();
                TR0 = 0;
               set_place = 0;
                TR0 = 1;
    if(set_place != 0)
        if(key1 == 0)
            delayms(5);
            if(key1 == 0)
                beep();
                if(set_place == 1)
                    second++;
                    if(second == 60)
                        second = 0;
                if(set_place == 2)
                    minute++;
                    if(minute == 60)
                        minute = 0;
                if(set_place == 3)
                    hour++;
                    if(hour == 24)
                        hour = 0;
    if(set_place != 0)
     if(key2 == 0)
            delayms(5);
            if(key2 == 0)
                 beep();
                if(set_place == 1)
                    second--;
                    if(second == -1)
                        second = 59;
                if(set_place == 2)
                    minute--;
                    if(minute == -1)
                        minute = 59;
                if(set_place == 3)
                    hour--;
                    if(hour == -1)
                        hour = 23;
// 數(shù)碼管顯示時間
void display()
    uchar j;
    P2 = 0x01;
    j = 60;
    while(j--);
    P2 = 0x02;
    j = 60;
    while(j--);
    P2 = 0x04;
    j = 60;
    while(j--);
    P2 = 0x08;
    j = 60;
    while(j--);
    P2 = 0x10;
    j = 60;
    while(j--);
    P2 = 0x20;
    j = 60;
    while(j--);
// 定時器初始化
void timer_init()
    EA = 1; //開放總中斷
    ET0 = 1;    //開啟定時器中段
    TR0 = 1;    //開啟定時器0
// 50ms中斷
    count++;
        count = 0;
        second++;
            second = 0;
            minute++;
                minute = 0;
                hour++;
                    hour =0;
    uchar i, j;
不好意思各位,源代碼是這樣!
#include<reg51.h>
#include"DS18B20.h"
uchar  tab[];
// 數(shù)碼管段選 共陰
//共陽數(shù)碼管段碼表
    timer_init();
    for(; ;)
       key_scan();
        display();
void beep()
    buzzer = 1;
    delayms(2);
    buzzer = 0;
    delayms(2);
// 鍵盤掃描函數(shù)
void key_scan()
    if(key0 == 0)
        delayms(5);
        if(key0 == 0)
            set_place++;
            while(!key0);
            beep();
                TR0 = 0;
               set_place = 0;
                TR0 = 1;
    if(set_place != 0)
        if(key1 == 0)
            delayms(5);
            if(key1 == 0)
                beep();
                if(set_place == 1)
                    second++;
                    if(second == 60)
                        second = 0;
                if(set_place == 2)
                    minute++;
                    if(minute == 60)
                        minute = 0;
                if(set_place == 3)
                    hour++;
                    if(hour == 24)
                        hour = 0;
    if(set_place != 0)
     if(key2 == 0)
            delayms(5);
            if(key2 == 0)
                 beep();
                if(set_place == 1)
                    second--;
                    if(second == -1)
                        second = 59;
                if(set_place == 2)
                    minute--;
                    if(minute == -1)
                        minute = 59;
                if(set_place == 3)
                    hour--;
                    if(hour == -1)
                        hour = 23;
// 數(shù)碼管顯示時間
void display()
    uchar j;
    P2 = 0x01;
    j = 60;
    while(j--);
    P2 = 0x02;
    j = 60;
    while(j--);
    P2 = 0x04;
    j = 60;
    while(j--);
    P2 = 0x08;
    j = 60;
    while(j--);
    P2 = 0x10;
    j = 60;
    while(j--);
    P2 = 0x20;
    j = 60;
    while(j--);
// 定時器初始化
void timer_init()
    EA = 1; //開放總中斷
    ET0 = 1;    //開啟定時器中段
    TR0 = 1;    //開啟定時器0
// 50ms中斷
    count++;
        count = 0;
        second++;
            second = 0;
            minute++;
                minute = 0;
                hour++;
                    hour =0;
    uchar i, j;
主站蜘蛛池模板: 亚洲 中文 欧美 日韩 在线观看 | 欧美 日韩 国产 在线 | 国产一二三视频在线观看 | 黄色大全免费看 | 欧美性生交大片免费 | 精品在线一区二区三区 | 久久精品成人热国产成 | 中文字幕一区二区三区精彩视频 | 精品久久久久久亚洲精品 | 国产特级毛片aaaaaa喷潮 | 国产伦精品一区二区三区四区视频 | 国产精品国产三级国产播12软件 | 成人午夜视频在线观看 | 欧美区日韩区 | 一区二区三区欧美在线 | 亚洲日本视频 | 天天射天天干 | 国产传媒视频在线观看 | 黄视频网站在线 | 色就干 | 日韩免费av | 国产精品美女久久久久aⅴ国产馆 | 国产精品电影在线观看 | 中文字幕日韩欧美一区二区三区 | 国产精品福利网站 | 亚洲电影一级片 | 国产精品久久久久久久模特 | 亚洲一区二区三区在线 | 一区二区三区四区在线 | 91视频在线 | 一级片免费网站 | 亚洲精品字幕 | 天天插天天操 | 国产精品日韩欧美一区二区三区 | 国产高潮av | 欧美又大粗又爽又黄大片视频 | 一级片成人 | 免费观看日韩精品 | 天天综合久久网 | 亚洲协和影视 | 国产精品视频免费看 |
