查看: 14074|回復: 1
Arduino UNO 板子各引腳輸出電流詳解!
ID:205205 發表于 2017-5-27 09:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
利用Arduino做項目的時候,經常會糾結于其驅動能力,或者無法正常工作,或者浪費人力財力,下面就是關于這部分的官方內容:
縮寫定義:
VOH - 電壓輸出高電平Voltage Output High (I/O Pin "HIGH")
VOL - 電壓輸出低電平Voltage Output Low (I/O Pin " LOW")
IOH - 電流輸出高電平Current Output High (I/O Pin "HIGH")
IOL - 電流輸出低電平Current Output Low (I/O Pin " LOW")
1. ATMEL ATMEGA328 (UNO及Duemilanove) 電流規范:
極限參數- 超過端口將無法承受
IO通道對應的直流電流........... 40.0 mA
VCC和GND對應的直流電流...... 200.0 mA
1 VCC管腳: 總的拉電流(流出)能力為200mA
2 GND管腳: 總的灌電流(流入)能力為400mA
Only the 32 pin surface mount packages (UNO Surface-Mount version) have 2 VCC pins.
管腳拉電流能力:
NOTE: Although each I/O port can source more than the test conditions (20 mA at VCC = 5V, 10 mA at VCC = 3V) under steady state conditions (non-transient), the following must be observed.
The sum of all IOH, for ports C0 - C5, D0- D4, ADC7, RESET should not exceed 150 mA.
The sum of all IOH, for ports B0 - B5, D5 - D7, ADC6, XTAL1, XTAL2 should not exceed 150 mA.
If IOH exceeds the test condition, VOH may exceed the related specification. Pins are not guaranteed to source current greater than the listed test condition.
Pin SINK Current Limitations:
NOTE: Although each I/O port can sink more than the test conditions (20 mA at VCC = 5V, 10 mA at VCC = 3V) under steady state conditions (non-transient), the following must be observed:
The sum of all IOL, for ports C0 - C5, ADC7, ADC6 should not exceed 100 mA.
The sum of all IOL, for ports B0 - B5, D5 - D7, XTAL1, XTAL2 should not exceed 100 mA.
The sum of all IOL, for ports D0 - D4, RESET should not exceed 100 mA.
If IOL exceeds the test condition, VOL may exceed the related specification. Pins are not guaranteed to sink current greater than the listed test condition.
2. ATMEL ATMEGA2560-1280-640(MEGA) 電流規范:
極限參數:
This apparently is saying you get 800mA to play with as there are 4 Vcc and 4 Gnd pins, further limited by subgroups of pins for Sink (IOL) and Source (IOH) current:
管腳灌電流能力:
The sum of all IOL, for ports J0-J7, A0-A7, G2 should not exceed 200 mA.
The sum of all IOL, for ports C0-C7, G0-G1, D0-D7, L0-L7 should not exceed 200 mA.
The sum of all IOL, for ports G3-G4, B0-B7, H0-B7 should not exceed 200 mA.
The sum of all IOL, for ports E0-E7, G5 should not exceed 100 mA.
The sum of all IOL, for ports F0-F7, K0-K7 should not exceed 100 mA.
[looks like 800mA Total!]
NOTE: If IOL exceeds the test condition [(20mA at VCC = 5V, 10mA at VCC = 3V) under steady state conditions (non-transient)], VOL may exceed the related specification. Pins are not guaranteed to sink current greater than the listed test condition.
管腳拉電流能力:
The sum of all IOH, for ports J0-J7, G2, A0-A7 should not exceed 200 mA.
The sum of all IOH, for ports C0-C7, G0-G1, D0-D7, L0-L7 should not exceed 200 mA.
The sum of all IOH, for ports G3-G4, B0-B7, H0-H7 should not exceed 200 mA.
The sum of all IOH, for ports E0-E7, G5 should not exceed 100 mA.
The sum of all IOH, for ports F0-F7, K0-K7 should not exceed 100 mA.
NOTE: If IOH exceeds the test condition [(20mA at VCC = 5V, 10mA at VCC = 3V) under steady state conditions (non-transient)], VOH may exceed the related specification. Pins are not guaranteed to source current greater than the listed test condition.
NOTE: Crossroads has confirmed with ATMEL that total current is defined by the number of VCC pins per package. Here is a quote from their response:
"For 328P, the max current rating is 400mA for the TQFP package. For ATmega2560, the max current rating is 800 mA. Also, please note that this is absolute maximum rating and exposing the device to absolute maximum conditions for longer duration of time could possibly cause damage to the device."
參與人數 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
ID:205205 發表于 2017-5-27 09:58 | 只看該作者
Arduno (UNO and Duemilanove) Chip Pin#s VS Ports:
主站蜘蛛池模板: 国产一级18片视频 | www.国产精品.com| 日韩av在线免费 | 中文久久久 | 亚洲精品午夜精品 | 中文在线资源 | 精品久久一区二区 | 日韩免费视频 | 午夜黄视频| 天天色播 | 日韩免费 | 一级大片免费看 | 91久久精品日日躁夜夜躁欧美 | 亚洲性生活片 | 一区在线观看视频 | 欧美香蕉视频 | 男人添女荫道口图片 | 91综合在线| 一区二区三区国产精品 | 成人午夜免费视频 | 亚洲久久在线 | 国产网站视频 | 国产欧美在线播放 | 日韩亚洲欧美在线 | 秋霞一区二区三区 | 午夜视频在线 | 午夜精品影院 | 嫩草视频在线观看 | 久热精品在线观看 | 日韩精品免费 | 四虎影院成人 | 国产久| 色77777| www.夜夜操 | 天天干b | 色吧综合 | 超碰中文字幕 | 精品一区二区三区视频 | 免费成人毛片 | 午夜一级视频 | 在线观看亚洲视频 |
