查看: 2067|回復: 1
【1602液晶顯示問題】
ID:204212 發(fā)表于 2017-5-29 11:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我想通過鍵盤來切換lcd的顯示界面(共四個界面),我覺得思路沒問題,可是就是實現(xiàn)不了,下面是代碼
    LcdInit();
        //key_return=Keyscan();
        Operation(Keyscan());
        Show(interface);
void T0Init()
/*void T0() interrupt 1
void Operation(uchar key)//界面切換
    switch(interface)
        case 1:if(key==10)
                    interface=2;
                    //運行界面,啟動定時器,同時切換界面
                if(key==12)
                    interface=3;//設置界面
                if(key==16)
                    interface=1;
                break;
        case 2:if(key==13)
                    interface=4;//查詢界面
                else if(key==11)
                    //TR0=0;
                    interface=1;
                else if(key==12)
                    //TR0=0;
                    interface=3;
                break;
          case 3:if(key==10)
                    //TR0=1;
                    interface=2;
                else if(key==11)
                    //TR0=0;
                    interface=1;
                break;
           case 4:if(key==11)
                    interface=2;
void Show(uchar n)
    switch(n)
        case 1:Interface_start();
               break;
        case 2:Interface_run();
               break;
        case 3:Interface_set();
               break;
        case 4:Interface_find();
               break;
void refresh_date(uchar address,uchar date)
    Write_cmd(0x80+address);
    Write_data(date);
void Interface_start()//打開電源顯示界面
    //Write_cmd(0x01);
    Write_cmd(0x80);
    for(num=0;num<16;num++)
        Write_data(table[num]);
        delay(20);
    Write_cmd(0x80+0x40);//第二行顯示
        Write_data(table1[num]);
        delay(20);
    Write_cmd(0x80+0x50);
    Write_cmd(0x0c);//開顯示,不顯示光標,不閃爍
void Interface_run()//運行界面
    LcdInit();
        Write_data(table3[num]);
        delay(20);
        Write_data(table2[num]);
        delay(20);
void Interface_set()//設置界面
     Write_cmd(0x80+5);
     Write_cmd(0x0f);
void Interface_find()//查詢界面
    refresh_date(0x40+5,table2[5]);
    refresh_date(0x40+6,table2[6]);
    refresh_date(0x40+7,table2[7]);
    refresh_date(0x40+8,table2[8]);
    refresh_date(0x40+9,table2[9]);
    refresh_date(0x40+10,table2[10]);
    refresh_date(0x40+11,table2[11]);
void LcdInit()
    wela=0;//lcd和數(shù)碼管共用P0
    dula=0;//防止數(shù)碼管干擾
    lcd_en=0;
    Write_cmd(0x38);//設置16*2顯示,5*7點陣,8位數(shù)據(jù)口
    Write_cmd(0x0f);//開顯示,顯示光標,光標閃爍
    Write_cmd(0x06);
    Write_cmd(0x01);//清除數(shù)據(jù),防止出現(xiàn)錯誤
    Write_cmd(0x80);
void Write_cmd(uchar cmd)
    rs=0;//數(shù)據(jù)/命令選擇段(h/l)
    P0=cmd;
    delay(5);
    lcd_en=1;//使能信號,高脈沖
    delay(5);
    lcd_en=0;
void Write_data(uchar data_)
    rs=1;
    P0=data_;
    delay(5);
    lcd_en=1;
    delay(5);
    lcd_en=0;
ID:7485 發(fā)表于 2017-5-29 16:00 | 只看該作者
其實這是最基本的。檢測取得按鍵值后,根據(jù)其值將程序跳轉(zhuǎn)到指定的顯示內(nèi)容即可。
主站蜘蛛池模板: 免费看黄色一级片 | 人人干人人艹 | 日韩在线免费视频 | 成人毛片100免费观看 | 欧美日韩国 | 91国在线| 国产精品乱码一区二区视频 | 亚洲精品视频免费观看 | 97超碰资源 | 久久99精品久久久久久国产越南 | 精品日韩av| 国产草草 | 日韩黄色一级 | 成人免费毛片观看 | 特级西西444www大胆免费看 | 国产主播一区二区 | 成人性生活免费视频 | 日韩激情一区 | 亚洲日本一区二区 | 青青草久久 | 日本www视频| 亚洲精品久久久久avwww潮水 | 日韩一级免费 | 六月婷婷在线 | 国产精品一区一区三区 | 激情小说在线视频 | 久草久草久草 | 日韩欧美自拍 | 深夜影院深a | 黄色成人免费视频 | 亚洲一区二区三区在线 | 午夜影院在线免费观看 | 中文字幕高清 | 解开岳的丰满奶罩bd | 91久久精品日日躁夜夜躁欧美 | 亚洲成人福利 | 黄色一级视频网站 | 欧美日韩综合网 | 中文字幕视频 | 黄色一级大片 | 亚洲综合五月 |
