查看: 3420|回復(fù): 7
求大神解釋一下PM2.5程序
ID:207993 發(fā)表于 2017-6-5 13:21 | 顯示全部樓層 |閱讀模式
#include <REGX52.H>
#include "LCD1602.h"
#include "dht11.c"
#include "BH1750.c"
float dis_temp;
uint dis_temp1;
uchar ms=0;
bit s0=0;
uchar UART_Upload[9];  // Upload上傳  accord主動(dòng)
uint pm_rateH,pm_rateL,pm_particle,pm_density,pm_URV;//低脈沖率高位。低脈沖率低位, 比率,顆粒,濃度  PM_URV  pm上限值
uchar  accord=0;
void  Multiple_Read_BH1750();      //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
void display()
   LCD1602_write(0,0x80);
   LCD1602_writebyte("PM2.5:");
   LCD1602_write(1,0x30+pm_density/1000%10);
   LCD1602_write(1,0x30+pm_density/100%10);
   LCD1602_write(1,0x30+pm_density/10%10);
    LCD1602_writebyte(".");
   LCD1602_write(1,0x30+pm_density%10);
   LCD1602_writebyte("ug/m3");
   LCD1602_write(0,0xC0);
   dis_temp1=(uint)(dis_temp);
   if(dis_temp1>9999)
   LCD1602_write(1,0x30+dis_temp1/10000);
   else LCD1602_write(1,' ');
   if(dis_temp1>999) LCD1602_write(1,0x30+dis_temp1%10000/1000);
   if(dis_temp1>99)   LCD1602_write(1,0x30+dis_temp1%1000/100);
   if(dis_temp1>9)   LCD1602_write(1,0x30+dis_temp1%100/10);
   LCD1602_write(1,0x30+dis_temp1%10);
   LCD1602_writebyte("Lx ");
   LCD1602_write(1,0x30+U8RH_data_H/10%10);
   LCD1602_write(1,0x30+U8RH_data_H%10);
   LCD1602_writebyte("% ");
   LCD1602_write(1,0x30+U8T_data_H/10%10);
   LCD1602_write(1,0x30+U8T_data_H%10);
   LCD1602_write(1,0xdf);
   LCD1602_writebyte("C");
ID:207993 發(fā)表于 2017-6-5 16:15 | 顯示全部樓層
快來個(gè)大神幫幫忙啊
ID:151348 發(fā)表于 2017-6-5 16:43 | 顯示全部樓層
程序似乎不全、、、
ID:82765 發(fā)表于 2017-6-5 16:51 | 顯示全部樓層
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
ID:207993 發(fā)表于 2017-6-5 18:31 | 顯示全部樓層
cjjcjj1 發(fā)表于 2017-6-5 16:51
你好!你的程序里面沒有 PM2.5 的代碼,從頭文件來看,這個(gè)程序是溫濕度和光照度顯示的
#include <REGX52.H>
#include "dht11.c"
#include "BH1750.c"
float dis_temp;
uint dis_temp1;
uchar ms=0;
bit s0=0;
uchar  accord=0;
void display()
   if(dis_temp1>9999)
void UART_Init(void)
T2CON = 0x34;
RCAP2H = 0xFF;
RCAP2L = 0xDC;
TH2 = 0xFF;
TL2 = 0xDC;
TR2 = 1;
SCON = 0x50;
ES = 1;
    UART_Init();
        Init_BH1750();      //初始化BH1750
        TMOD=0x01;
        TH0=0x3C;
        TL0=0xb0;
        ET0=1;
        TR0=1;
        EA=1;
    LCD1602_cls();
           RH();
           display();
void time0() interrupt 1
   TH0=0x3C;
   TL0=0xb0;
   ms++;
   if(ms>=20)
        ms=0;
              Single_Write_BH1750(0x01);   // power on
                Single_Write_BH1750(0x10);   // H- resolution mode
                delay_nms(80);               //延時(shí)180ms
                 Multiple_Read_BH1750();      //連續(xù)讀出數(shù)據(jù),存儲(chǔ)在BUF中
                dis_data=BUF[0];
                dis_data=(dis_data<<8)+BUF[1];//合成數(shù)據(jù),即光照數(shù)據(jù)
                dis_temp=(float)dis_data/1.2;
void serial () interrupt 4
        uchar temp_pM;
        if(RI==1)
                RI=0;
                UART_Upload[accord]=SBUF; //串口接收一個(gè)數(shù)據(jù)
                accord++;
                if(UART_Upload[0]!=0xff)  //判斷接收到的第一個(gè)數(shù)據(jù)為oxff  數(shù)據(jù)錯(cuò)誤 數(shù)組指針清零
                        accord=0;
                if(UART_Upload[1]!=0x18)//判斷接收到的第2個(gè)為0x18  數(shù)據(jù)錯(cuò)誤 數(shù)組指針清零
                        accord=0;
                if(accord>8)                 //九個(gè)數(shù)據(jù)為一組
                        accord=0; //接收完一組數(shù)據(jù)的標(biāo)志,置0 校驗(yàn)
                if(accord==0)                //接收一組數(shù)據(jù)后進(jìn)行一次校驗(yàn)和
                {                                         //校驗(yàn)7為數(shù)據(jù)位的和取反加一等于校驗(yàn)值
                        if((UART_Upload[0]==0xff)&&(UART_Upload[1]=0x18)&&(UART_Upload[2]==0x00))//判斷前三位數(shù)據(jù)是否正確 是進(jìn)行校驗(yàn)
                                temp_pM=~(UART_Upload[1]+UART_Upload[2]+UART_Upload[3]+UART_Upload[4]+UART_Upload[5]+UART_Upload[6]+UART_Upload[7])+1;        //校驗(yàn)和
                                  if(temp_pM=UART_Upload[8])
                                        pm_rateH=UART_Upload[3];
                                        pm_rateL=UART_Upload[4];
                                        pm_density=(UART_Upload[3]*100+UART_Upload[4])*1.014705; //濃度數(shù)據(jù)處理          數(shù)據(jù)擴(kuò)大了十倍
                                        /*我們繪出一個(gè)檢驗(yàn)報(bào)告,比如在345ug/m3的情況下,zph01輸出占空比34%。我們理論認(rèn)為在0-34%對(duì)應(yīng)的0-345ug/m3。他們是 線性比例關(guān)系*/
ID:170270 發(fā)表于 2017-6-6 13:13 | 顯示全部樓層
從程序看 PM2.5是串口的 接受的數(shù)據(jù)按協(xié)議解析就可以
ID:207993 發(fā)表于 2017-6-6 19:51 | 顯示全部樓層
依然是你 發(fā)表于 2017-6-6 13:13
那測量光照的是什么原理  什么中斷啊 求詳解
ID:170270 發(fā)表于 2017-6-7 08:58 | 顯示全部樓層
一個(gè)被程序折磨 發(fā)表于 2017-6-6 19:51
光照是集成芯片 有特定的通訊協(xié)議
主站蜘蛛池模板: 在线亚洲精品 | 二区三区在线观看 | 欧美日韩亚洲一区二区 | 精品久久免费 | 日韩精品综合 | 国产永久免费视频 | 久久91精品| 国产在线视频网站 | 色激情网 | 免费黄色av | 爱福利视频网 | 日韩黄色在线视频 | 久久久久久久网 | 亚洲精品乱码久久久久久蜜桃91 | 日韩网站免费观看 | 99久久久国产精品 | 色婷婷视频在线观看 | 国产一区免费视频 | 亚洲三级黄色片 | 久视频在线 | 久久精品久久久久久久 | 免费的黄色大片 | 91精品国产一区二区三区 | 久久久久久一区 | 欧美xxxx网站| 日韩久久网 | 91午夜精品亚洲一区二区三区 | 久草免费福利 | 国产精品二区在线观看 | 18视频在线观看男男 | 青青青操 | 制服丝袜av在线 | 国产精品无遮挡 | 天天射天天 | 日韩精品免费观看 | 在线观看h片 | 日韩免费看片 | 91精品国产99久久久久久红楼 | www.国产精品.com | aaa成人 | 伊人久久中文字幕 |
