查看: 2883|回復: 4
求答疑,不知道問題出在哪里
ID:208422 發表于 2017-6-6 15:37 | 顯示全部樓層 |閱讀模式
本帖最后由 a13995960 于 2017-6-6 15:40 編輯
1602 超聲波測距的,代碼在下面
問題是1602 是顯示兩個數據,但是只有一個超聲波模塊可以用,測出來的結果也是相同的,不知道錯在哪= =
#include <reg52.H>    //器件配置文件#include <intrins.h>sbit P2_6=P2^6;sbit P2_5=P2^5;sbit P2_7=P2^7;sbit P1_1=P1^1;sbit P1_2=P1^2;sbit P3_2=P3^2;sbit P2_0=P2^0;sbit P1_3=P3^6;sbit P1_4=P3^7;#define  RX1  P1_1#define  TX1  P1_2 #define  RX  P1_3#define  TX  P1_4 #define LCM_RW  P2_6 //定義LCD引腳#define LCM_RS  P2_5#define LCM_E   P2_7#define LCM_Data  P0 #define Key_Data P2_0 //定義Keyboard引腳#define Key_CLK  P3_2 #define Busy    0x80 //用于檢測LCM狀態字中的Busy標識 void LCMInit(void);void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);void Delay5Ms(void);void Delay400Ms(void);void Decode(unsigned char ScanCode);void WriteDataLCM(unsigned char WDLCM);void WriteCommandLCM(unsigned char WCLCM,BuysC); unsigned char ReadDataLCM(void);unsigned char ReadStatusLCM(void);unsigned char code mcustudio[] ={"C1:"  } ;unsigned char code mcustudio1[] ={"C2:" } ;unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'}; static unsigned char DisNum = 0; //顯示用指針unsigned int  time=0,time1=0;unsigned long S=0,S1;bit      flag =0,flag1=0;unsigned char disbuff[4]    ={ 0,0,0,0,}; //寫數據void WriteDataLCM(unsigned char WDLCM){ReadStatusLCM(); //檢測忙LCM_Data = WDLCM;LCM_RS = 1;LCM_RW = 0;LCM_E = 0; //若晶振速度太高可以在這后加小的延時LCM_E = 0; //延時LCM_E = 1;} //寫指令void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC0時忽略忙檢測{if (BuysC) ReadStatusLCM(); //根據需要檢測忙LCM_Data = WCLCM;LCM_RS = 0;LCM_RW = 0;LCM_E = 0;LCM_E = 0;LCM_E = 1;} //讀數據unsigned char ReadDataLCM(void){LCM_RS = 1;LCM_RW = 1;LCM_E = 0;LCM_E = 0;LCM_E = 1;return(LCM_Data);} //讀狀態unsigned char ReadStatusLCM(void){LCM_Data = 0xFF;LCM_RS = 0;LCM_RW = 1;LCM_E = 0;LCM_E = 0;LCM_E = 1;while (LCM_Data & Busy); //檢測忙信號return(LCM_Data);} void LCMInit(void) //LCM初始化{LCM_Data = 0;WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號Delay5Ms();WriteCommandLCM(0x38,0);Delay5Ms();WriteCommandLCM(0x38,0);Delay5Ms(); WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號WriteCommandLCM(0x08,1); //關閉顯示WriteCommandLCM(0x01,1); //顯示清屏WriteCommandLCM(0x06,1); // 顯示光標移動設置WriteCommandLCM(0x0F,1); // 顯示開及光標設置} //按指定位置顯示一個字符void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData){Y &= 0x1;X &= 0xF; //限制X不能大于15Y不能大于1if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;X |= 0x80; //算出指令碼WriteCommandLCM(X, 1); //發命令字WriteDataLCM(DData); //發數據} //按指定位置顯示一串字符void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData){unsigned char ListLength; ListLength = 0;Y &= 0x1;X &= 0xF; //限制X不能大于15Y不能大于1while (DData[ListLength]>0x19) //若到達字串尾則退出{if (X <= 0xF) //X坐標應小于0xF{DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符ListLength++;X++;}}} //5ms延時void Delay5Ms(void){unsigned int TempCyc = 5552;while(TempCyc--);} //400ms延時void Delay400Ms(void){unsigned char TempCycA = 5;unsigned int TempCycB;while(TempCycA--){TempCycB=7269;while(TempCycB--);};}/********************************************************/void Conut(void)///COUNT1{time=TH0*256+TL0;TH0=0;TL0=0; S=(time*1.7)/100;     //算出來是CMif((S>=700)||flag==1) //超出測量范圍顯示“-{flag=0; DisplayOneChar(5, 0, ASCII[11]);DisplayOneChar(6, 0, ASCII[10]);  //顯示點DisplayOneChar(7, 0, ASCII[11]);DisplayOneChar(8, 0, ASCII[11]);DisplayOneChar(9, 0, ASCII[12]);  //顯示M}else{disbuff[0]=S%1000/100;disbuff[1]=S%1000%100/10;disbuff[2]=S%1000%10 %10;DisplayOneChar(5, 0, ASCII[disbuff[0]]);DisplayOneChar(6, 0, ASCII[10]);  //顯示點DisplayOneChar(7, 0, ASCII[disbuff[1]]);DisplayOneChar(8, 0, ASCII[disbuff[2]]);DisplayOneChar(9, 0, ASCII[12]);  //顯示M}}void Conut1(void)///COUNT1{time1=TH1*256+TL1;TH1=0;TL1=0; S1=(time1*1.7)/100;     //算出來是CMif((S1>=700)||flag1==1) //超出測量范圍顯示“-{flag1=0; DisplayOneChar(5, 1, ASCII[11]);DisplayOneChar(6, 1, ASCII[10]);  //顯示點DisplayOneChar(7, 1, ASCII[11]);DisplayOneChar(8, 1, ASCII[11]);DisplayOneChar(9, 1, ASCII[12]);  //顯示M}else{disbuff[0]=S%1000/100;disbuff[1]=S%1000%100/10;disbuff[2]=S%1000%10 %10;DisplayOneChar(5, 1, ASCII[disbuff[0]]);DisplayOneChar(6, 1, ASCII[10]);  //顯示點DisplayOneChar(7, 1, ASCII[disbuff[1]]);DisplayOneChar(8, 1, ASCII[disbuff[2]]);DisplayOneChar(9, 1, ASCII[12]);  //顯示M}}/********************************************************/void zd0() interrupt 1      //T0中斷用來計數器溢出,超過測距范圍{flag=1;              //中斷溢出標志}void zd1() interrupt 3      //T0中斷用來計數器溢出,超過測距范圍{flag1=1;               //中斷溢出標志}/********************************************************/void  StartModule()             //啟動模塊{TX=1;//啟動一次模塊_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();TX=0;}void  StartModule1()             //啟動模塊{TX1=1;//啟動一次模塊_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();TX1=0;}/********************************************************/void delayms(unsigned int ms){unsigned char i=100,j;for(;ms;ms--){while(--i){j=10;while(--j);}}}/*********************************************************/ void main(void){unsigned char TempCyc;Delay400Ms(); //啟動等待,等LCM講入工作狀態LCMInit(); //LCM初始化Delay5Ms(); //延時片刻(可不要)DisplayListChar(0, 0, mcustudio);DisplayListChar(0, 1, mcustudio1);ReadDataLCM();//測試用句無意義for (TempCyc=0; TempCyc<10; TempCyc++)Delay400Ms(); //延時//DisplayListChar(0, 1, Cls);while(1){TMOD=0x11;      //T0為方式1GATE=1TH0=0;TL0=0;TH1=0;TL1=0;ET0=1;             //允許T0中斷ET1=1;             //允許T0中斷EA=1;         //開啟總中斷 while(1){StartModule();// DisplayOneChar(0, 1, ASCII[0]);while(!RX);    //RX為零時等待TR0=1;         //開啟計數while(RX);     //RX1計數并等待TR0=0;       //關閉計數Conut();     //計算delayms(80);   //80MS StartModule1();while(!RX1);   //RX為零時等待TR1=1;          //開啟計數while(RX1);      //RX1計數并等待TR1=0;       //關閉計數 Conut1();delayms(80);    //80MS/**/ }}}
ID:1 發表于 2017-6-6 16:33 | 顯示全部樓層
樓主,重新編輯一下代碼吧,在谷歌瀏覽器 電腦上
ID:208477 發表于 2017-6-6 17:08 | 顯示全部樓層
推薦使用visual studio code或者notepad++里面的npp export插件,能夠把代碼導出成高亮形式。
ID:111634 發表于 2017-6-7 22:40 | 顯示全部樓層
問題首先出在那一大塊東東,你都不知c程序的書寫要求,編譯器不認識了。
ID:47286 發表于 2017-6-7 22:57 | 顯示全部樓層
我去 這是什么啊
主站蜘蛛池模板: 香蕉视频导航 | 超碰免费在线播放 | 欧美午夜精品一区二区三区 | 久久精品黄色 | 人人九九精 | 狠狠操天天操 | 哦┅┅快┅┅用力啊┅aps | 国产小视频在线播放 | 午夜激情网 | 97超碰在线播放 | 亚洲一区二区三区四区在线 | 日本成人一区二区 | 色综合久久久 | 国产高清视频在线观看 | 日本国产视频 | 视频一二区 | a天堂在线观看 | 欧美日韩综合在线 | 成人av一区二区三区在线观看 | 人人干人人草 | 久久99精品久久久久久 | 羞羞网站在线观看 | 最新国产精品 | 日本a视频 | 日本在线看 | 欧美夜夜操 | 欧美中文字幕在线观看 | 中文字幕在线观看不卡 | 久久久久一区 | 久久精品网 | 九九热在线视频 | 成人亚洲精品 | 免费色片 | 日韩免费在线播放 | 伊人精品久久 | 成人欧美一区二区三区黑人孕妇 | 激情五月婷婷综合 | 午夜精品久久 | 日韩欧美专区 | 永久在线 | 国产精品一区二区av |
