查看: 21834|回復(fù): 30
STM8 SHT30庫函數(shù)(溫濕度傳感器)
ID:212884 發(fā)表于 2017-6-20 11:05 | 顯示全部樓層 |閱讀模式
SHT30是盛世瑞最新出品的低端低價溫濕度傳感器,在精度和尺寸上都優(yōu)于SHT20.
附件是SHT30的STM8驅(qū)動,用的是庫函數(shù),自己寫的,可行。
  1. //==============================================================================
  2. //    S E N S I R I O N   AG,  Laubisruetistr. 44, CH-8712 Staefa, Switzerland
  3. //==============================================================================
  4. // Project   :  SHT3x Sample Code (V1.0)
  5. // File      :  sht3x.c (V1.0)
  6. // Author    :  RFU
  7. // Date      :  16-Jun-2014
  8. // Controller:  STM32F100RB
  9. // IDE       :  礦ision V4.71.2.0
  10. // Compiler  :  Armcc
  11. // Brief     :  Sensor Layer: Implementation of functions for sensor access.
  12. //==============================================================================
  13. //-- Includes ------------------------------------------------------------------
  14. #include "sht3x.h"
  15. #include "iic.h"
  16. //-- Defines -------------------------------------------------------------------
  17. // CRC
  18. #define POLYNOMIAL  0x131 // P(x) = x^8 + x^5 + x^4 + 1 = 100110001
  19. //------------------------------------------------------------------------------
  20. // IO-Pins                             /* -- adapt the defines for your uC -- */
  21. //------------------------------------------------------------------------------
  22. // Reset on port B, bit 12
  23. #define RESET_LOW()  (GPIOB->BSRR = 0x10000000) // set Reset to low
  24. #define RESET_HIGH() (GPIOB->BSRR = 0x00001000) // set Reset to high
  25. // Alert on port B, bit 10
  26. #define ALERT_READ   (GPIOB->IDR  & 0x0400)     // read Alert
  27. //------------------------------------------------------------------------------
  28. //-- Global variables ----------------------------------------------------------
  29. u8t _i2cWriteHeader=0x88;
  30. u8t _i2cReadHeader=0x89;
  31. //==============================================================================
  32. void SHT3X_Init(u8t i2cAdr){              /* -- adapt the init for your uC -- */
  33. //==============================================================================
  34. /*
  35.   // init I/O-pins
  36.         RCC->APB2ENR |= 0x00000008;  // I/O port B clock enabled
  37.
  38.   // Alert on port B, bit 10
  39.         GPIOB->CRH   &= 0xFFFFF0FF;  // set floating input for Alert-Pin
  40.   GPIOB->CRH   |= 0x00000400;  //
  41.
  42.   // Reset on port B, bit 12
  43.         GPIOB->CRH   &= 0xFFF0FFFF;  // set push-pull output for Reset pin
  44.   GPIOB->CRH   |= 0x00010000;  //
  45.         RESET_LOW();
  46. */
  47. //  I2c_Init(); // init I2C
  48.   SHT3X_SetI2cAdr(i2cAdr); //
  49.
  50.         // release reset
  51. //        RESET_HIGH();
  52. }
  53. //==============================================================================
  54. void SHT3X_SetI2cAdr(u8t i2cAdr){
  55. //==============================================================================
  56.   _i2cWriteHeader = i2cAdr << 1;
  57.   _i2cReadHeader = _i2cWriteHeader | 0x01;
  58. }
  59. //==============================================================================
  60. u8t SHT3x_ReadSerialNumber(u32t *serialNbr){
  61. //==============================================================================
  62.   u8t error; // error code
  63.   u16t serialNumWords[2];
  64.   error = SHT3X_StartWriteAccess();
  65.   // write "read serial number" command
  66.   error |= SHT3X_WriteCommand(CMD_READ_SERIALNBR);
  67.   // if no error, start read access
  68.   if(error == NO_ERROR) error = SHT3X_StartReadAccess();
  69.   // if no error, read first serial number word
  70.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&serialNumWords[0], ACK, 100);
  71.   // if no error, read second serial number word
  72.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&serialNumWords[1], NACK, 0);
  73.   SHT3X_StopAccess();
  74.
  75.   // if no error, calc serial number as 32-bit integer
  76.   if(error == NO_ERROR)
  77.   {
  78.     *serialNbr = (serialNumWords[0] << 16) | serialNumWords[1];
  79.   }
  80.   return error;
  81. }
  82. //==============================================================================
  83. u8t SHT3X_ReadStatus(u16t *status){
  84. //==============================================================================
  85.   u8t error; // error code
  86.   error = SHT3X_StartWriteAccess();
  87.   // if no error, write "read status" command
  88.   if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_READ_STATUS);
  89.   // if no error, start read access
  90.   if(error == NO_ERROR) error = SHT3X_StartReadAccess();
  91.   // if no error, read status
  92.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(status, NACK, 0);
  93.   SHT3X_StopAccess();
  94.   return error;
  95. }
  96. //==============================================================================
  97. u8t SHT3X_ClearAllAlertFlags(void){
  98. //==============================================================================
  99.   u8t error; // error code
  100.   error = SHT3X_StartWriteAccess();
  101.   // if no error, write clear status register command
  102.   if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_CLEAR_STATUS);
  103.   SHT3X_StopAccess();
  104.   return error;
  105. }
  106. //==============================================================================
  107. u8t SHT3X_GetTempAndHumi(ft         *temp,
  108.                              ft         *humi,
  109.                              etRepeatab repeatab,
  110.                              etMode     mode,
  111.                              u8t        timeout){
  112. //==============================================================================
  113.   u8t error;
  114.
  115.   switch(mode)
  116.   {
  117.     case MODE_CLKSTRETCH: // get temperature with clock stretching mode
  118.       error = SHT3X_GetTempAndHumiClkStretch(temp, humi, repeatab, timeout); break;
  119.     case MODE_POLLING:    // get temperature with polling mode
  120.       error = SHT3X_GetTempAndHumiPolling(temp, humi, repeatab, timeout); break;
  121.     default:
  122.       error = PARM_ERROR; break;
  123.   }
  124.
  125.   return error;
  126. }
  127. //==============================================================================
  128. u8t SHT3X_GetTempAndHumiClkStretch(ft         *temp,
  129.                                        ft         *humi,
  130.                                        etRepeatab repeatab,
  131.                                        u8t        timeout){
  132. //==============================================================================
  133.   u8t error;        // error code
  134.   u16t    rawValueTemp; // temperature raw value from sensor
  135.   u16t    rawValueHumi; // humidity raw value from sensor
  136.   error = SHT3X_StartWriteAccess();
  137.   // if no error ...
  138.   if(error == NO_ERROR)
  139.   {
  140.     // start measurement in clock stretching mode
  141.     // use depending on the required repeatability, the corresponding command
  142.     switch(repeatab)
  143.     {
  144.       case REPEATAB_LOW:    error = SHT3X_WriteCommand(CMD_MEAS_CLOCKSTR_L); break;
  145.       case REPEATAB_MEDIUM: error = SHT3X_WriteCommand(CMD_MEAS_CLOCKSTR_M); break;
  146.       case REPEATAB_HIGH:   error = SHT3X_WriteCommand(CMD_MEAS_CLOCKSTR_H); break;
  147.       default:              error = PARM_ERROR; break;
  148.     }
  149.   }
  150.   // if no error, start read access
  151.   if(error == NO_ERROR) error = SHT3X_StartReadAccess();
  152.   // if no error, read temperature raw values
  153.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&rawValueTemp, ACK, timeout);
  154.   // if no error, read humidity raw values
  155.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&rawValueHumi, NACK, 0);
  156.   SHT3X_StopAccess();
  157.   // if no error, calculate temperature in 癈 and humidity in %RH
  158.   if(error == NO_ERROR)
  159.   {
  160.     *temp = SHT3X_CalcTemperature(rawValueTemp);
  161.     *humi = SHT3X_CalcHumidity(rawValueHumi);
  162.   }
  163.   return error;
  164. }
  165. //==============================================================================
  166. u8t SHT3X_GetTempAndHumiPolling(ft         *temp,
  167.                                     ft         *humi,
  168.                                     etRepeatab repeatab,
  169.                                     u8t        timeout){
  170. //==============================================================================
  171.   u8t error;           // error code
  172.   u16t    rawValueTemp;    // temperature raw value from sensor
  173.   u16t    rawValueHumi;    // humidity raw value from sensor
  174.   error  = SHT3X_StartWriteAccess();
  175.   // if no error ...
  176.   if(error == NO_ERROR)
  177.   {
  178.     // start measurement in polling mode
  179.     // use depending on the required repeatability, the corresponding command
  180.     switch(repeatab)
  181.     {
  182.       case REPEATAB_LOW:    error = SHT3X_WriteCommand(CMD_MEAS_POLLING_L); break;
  183.       case REPEATAB_MEDIUM: error = SHT3X_WriteCommand(CMD_MEAS_POLLING_M); break;
  184.       case REPEATAB_HIGH:                error = SHT3X_WriteCommand(CMD_MEAS_POLLING_H); break;
  185.       default:                                 error = PARM_ERROR; break;
  186.     }
  187.   }
  188.   // if no error, wait until measurement ready
  189.   if(error == NO_ERROR)
  190.   {
  191.     // poll every 1ms for measurement ready until timeout
  192.     while(timeout--)
  193.     {
  194.       // check if the measurement has finished
  195.       error = SHT3X_StartReadAccess();
  196.       // if measurement has finished -> exit loop
  197.       if(error == NO_ERROR) break;
  198.       // delay 1ms
  199.       DelayMicroSeconds(1000);
  200.     }
  201.
  202.                 // check for timeout error
  203.                 if(timeout == 0) error = TIMEOUT_ERROR;
  204.   }
  205.
  206.         // if no error, read temperature and humidity raw values
  207.   if(error == NO_ERROR)
  208.   {
  209.     error |= SHT3X_Read2BytesAndCrc(&rawValueTemp, ACK, 0);
  210.     error |= SHT3X_Read2BytesAndCrc(&rawValueHumi, NACK, 0);
  211.   }
  212.   SHT3X_StopAccess();
  213.   // if no error, calculate temperature in 癈 and humidity in %RH
  214.   if(error == NO_ERROR)
  215.   {
  216.     *temp = SHT3X_CalcTemperature(rawValueTemp);
  217.     *humi = SHT3X_CalcHumidity(rawValueHumi);
  218.   }
  219.   return error;
  220. }
  221. //==============================================================================
  222. u8t SHT3X_StartPeriodicMeasurment(etRepeatab  repeatab,
  223.                                       etFrequency freq){
  224. //==============================================================================
  225.   u8t error;        // error code
  226.   error = SHT3X_StartWriteAccess();
  227.         // if no error, start periodic measurement
  228.         if(error == NO_ERROR)
  229.         {
  230.     // use depending on the required repeatability and frequency,
  231.           // the corresponding command
  232.                 switch(repeatab)
  233.                 {
  234.                         case REPEATAB_LOW: // low repeatability
  235.                                 switch(freq)
  236.                                 {
  237.                                         case FREQUENCY_HZ5:  // low repeatability,  0.5 Hz
  238.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_05_L); break;
  239.                                         case FREQUENCY_1HZ:  // low repeatability,  1.0 Hz
  240.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_1_L); break;
  241.                                         case FREQUENCY_2HZ:  // low repeatability,  2.0 Hz
  242.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_2_L); break;
  243.                                         case FREQUENCY_4HZ:  // low repeatability,  4.0 Hz
  244.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_4_L); break;
  245.                                         case FREQUENCY_10HZ: // low repeatability, 10.0 Hz
  246.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_10_L); break;
  247.                                         default:
  248.                                                 error |= PARM_ERROR; break;
  249.                                 }
  250.                           break;
  251.
  252.                         case REPEATAB_MEDIUM: // medium repeatability
  253.                                 switch(freq)
  254.                                 {
  255.                                         case FREQUENCY_HZ5:  // medium repeatability,  0.5 Hz
  256.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_05_M); break;
  257.                                         case FREQUENCY_1HZ:  // medium repeatability,  1.0 Hz
  258.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_1_M); break;
  259.                                         case FREQUENCY_2HZ:  // medium repeatability,  2.0 Hz
  260.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_2_M); break;
  261.                                         case FREQUENCY_4HZ:  // medium repeatability,  4.0 Hz
  262.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_4_M); break;
  263.                                         case FREQUENCY_10HZ: // medium repeatability, 10.0 Hz
  264.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_10_M); break;
  265.                                         default:
  266.                                                 error |= PARM_ERROR; break;
  267.                                 }
  268.                           break;
  269.
  270.                         case REPEATAB_HIGH: // high repeatability
  271.                                 switch(freq)
  272.                                 {
  273.                                         case FREQUENCY_HZ5:  // high repeatability,  0.5 Hz
  274.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_05_H); break;
  275.                                         case FREQUENCY_1HZ:  // high repeatability,  1.0 Hz
  276.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_1_H); break;
  277.                                         case FREQUENCY_2HZ:  // high repeatability,  2.0 Hz
  278.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_2_H); break;
  279.                                         case FREQUENCY_4HZ:  // high repeatability,  4.0 Hz
  280.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_4_H); break;
  281.                                         case FREQUENCY_10HZ: // high repeatability, 10.0 Hz
  282.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_10_H); break;
  283.                                         default:
  284.                                                 error |= PARM_ERROR; break;
  285.                                 }
  286.                           break;
  287.                         default:
  288.                                 error |= PARM_ERROR; break;
  289.                 }
  290.         }
  291.   SHT3X_StopAccess();
  292.   return error;
  293. }
  294. //==============================================================================
  295. u8t SHT3X_ReadMeasurementBuffer(ft *temp, ft *humi){
  296. //==============================================================================
  297.   u8t  error;        // error code
  298.         u16t     rawValueTemp; // temperature raw value from sensor
  299.   u16t     rawValueHumi; // humidity raw value from sensor
  300.         error = SHT3X_StartWriteAccess();
  301.         // if no error, read measurements
  302.         if(error == NO_ERROR)        error = SHT3X_WriteCommand(CMD_FETCH_DATA);
  303.         if(error == NO_ERROR)        error = SHT3X_StartReadAccess();
  304.         if(error == NO_ERROR)        error = SHT3X_Read2BytesAndCrc(&rawValueTemp, ACK, 0);
  305.         if(1)   error = SHT3X_Read2BytesAndCrc(&rawValueHumi, NACK, 0);
  306.
  307.         // if no error, calculate temperature in 癈 and humidity in %RH
  308.         //if(error == NO_ERROR)
  309.         //{
  310.                 *temp = SHT3X_CalcTemperature(rawValueTemp);
  311.                 *humi = SHT3X_CalcHumidity(rawValueHumi);
  312.         //}
  313.
  314.         SHT3X_StopAccess();
  315.
  316.         return error;
  317. }
  318. //==============================================================================
  319. u8t SHT3X_EnableHeater(void){
  320. //==============================================================================
  321.   u8t error; // error code
  322.   error = SHT3X_StartWriteAccess();
  323.   // if no error, write heater enable command
  324.   if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_HEATER_ENABLE);
  325.   SHT3X_StopAccess();
  326.   return error;
  327. }
  328. //==============================================================================
  329. u8t SHT3X_DisbaleHeater(void){
  330. //==============================================================================
  331.   u8t error; // error code
  332.   error = SHT3X_StartWriteAccess();
  333.   // if no error, write heater disable command
  334.   if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_HEATER_DISABLE);
  335.   SHT3X_StopAccess();
  336.   return error;
  337. }
  338. //==============================================================================
  339. u8t SHT3X_SoftReset(void){
  340. //==============================================================================
  341.   u8t error; // error code
  342.   error = SHT3X_StartWriteAccess();
  343.   // write reset command
  344.   error |= SHT3X_WriteCommand(CMD_SOFT_RESET);
  345.   SHT3X_StopAccess();
  346.
  347.         // if no error, wait 50 ms after reset
  348.         if(error == NO_ERROR) DelayMicroSeconds(50000);
  349.   return error;
  350. }
  351. //==============================================================================
  352. void SHT3X_HardReset(void){
  353. //==============================================================================
  354.         // set reset low
  355.         //RESET_LOW();
  356.         // wait 100 ms
  357.         DelayMicroSeconds(100000);
  358.
  359.         // release reset
  360.         //RESET_HIGH();
  361.
  362.         // wait 50 ms after reset
  363.         DelayMicroSeconds(50000);
  364. }
  365. //==============================================================================
  366. u8t SHT3X_StartWriteAccess(void){
  367. //==============================================================================
  368.   u8t error; // error code
  369.   // write a start condition
  370.   I2C_START();
  371.   // write the sensor I2C address with the write flag
  372.   error = I2C_TX(_i2cWriteHeader);
  373.   return error;
  374. }
  375. //==============================================================================
  376. u8t SHT3X_StartReadAccess(void){
  377. //==============================================================================
  378.   u8t error; // error code
  379.   // write a start condition
  380.   I2C_START();
  381.   // write the sensor I2C address with the read flag
  382.   error = I2C_TX(_i2cReadHeader);
  383.   return error;
  384. }
  385. //==============================================================================
  386. void SHT3X_StopAccess(void){
  387. //==============================================================================
  388.   // write a stop condition
  389.   I2C2_Stop();
  390. }
  391. //==============================================================================
  392. u8t SHT3X_WriteCommand(etCommands cmd){
  393. //==============================================================================
  394.   u8t error; // error code
  395.   // write the upper 8 bits of the command to the sensor
  396.   error  = I2C_TX(cmd >> 8);
  397.   // write the lower 8 bits of the command to the sensor
  398.   error |= I2C_TX(cmd & 0xFF);
  399.   return error;
  400. }
  401. //==============================================================================
  402. u8t SHT3X_Read2BytesAndCrc(u16t *data, etI2cAck finaleAckNack, u8t timeout){
  403. //==============================================================================
  404.   u8t error;    // error code
  405.   u8t     bytes[2]; // read data array
  406.   u8t     checksum; // checksum byte
  407.   // read two data bytes and one checksum byte
  408.   /*
  409.                               error = I2c_ReadByte(&bytes[0], ACK, timeout);
  410.         if(error == NO_ERROR) error = I2c_ReadByte(&bytes[1], ACK, 0);
  411.
  412.
  413.   if(error == NO_ERROR) error = I2c_ReadByte(&checksum, finaleAckNack, 0);
  414.   */
  415.
  416.   bytes[0]=I2C_RX(ACK);
  417.   bytes[1]=I2C_RX(ACK);
  418.   checksum=I2C_RX(finaleAckNack);
  419.   // verify checksum
  420.   if(error == NO_ERROR) error = SHT3X_CheckCrc(bytes, 2, checksum);
  421.
  422.   // combine the two bytes to a 16-bit value
  423.   *data = (bytes[0] << 8) | bytes[1];
  424.
  425.   return error;
  426. }
  427. //==============================================================================
  428. u8t SHT3X_Write2BytesAndCrc(u16t data){
  429. //==============================================================================
  430.   u8t error;    // error code
  431.   u8t     bytes[2]; // read data array
  432.   u8t     checksum; // checksum byte
  433.
  434.         bytes[0] = data >> 8;
  435.         bytes[1] = data & 0xFF;
  436.         checksum = SHT3X_CalcCrc(bytes, 2);
  437.         // write two data bytes and one checksum byte
  438.                               error = I2C_TX(bytes[0]); // write data MSB
  439.         if(error == NO_ERROR) error = I2C_TX(bytes[1]); // write data LSB
  440.         if(error == NO_ERROR) error = I2C_TX(checksum); // write checksum
  441.
  442.   return error;
  443. }
  444. //==============================================================================
  445. u8t SHT3X_CalcCrc(u8t data[], u8t nbrOfBytes){
  446. //==============================================================================
  447.         u8t bit;        // bit mask
  448.   u8t crc = 0xFF; // calculated checksum
  449.   u8t byteCtr;    // byte counter
  450.
  451.   // calculates 8-Bit checksum with given polynomial
  452.   for(byteCtr = 0; byteCtr < nbrOfBytes; byteCtr++)
  453.   {
  454.     crc ^= (data[byteCtr]);
  455.     for(bit = 8; bit > 0; --bit)
  456. ……………………
  457. …………限于本文篇幅 余下代碼請從51黑下載附件…………
SHT3X.zip (6.78 KB, 下載次數(shù): 338)
參與人數(shù) 3黑幣 +60 收起 理由
jipinxlm + 5 共享資料的黑幣獎勵!
liuxin549521 + 5 很給力!
ID:242049 發(fā)表于 2017-10-23 11:49 | 顯示全部樓層
感謝分享,就是黑幣不夠 下載不了
ID:239391 發(fā)表于 2017-10-31 14:07 | 顯示全部樓層
扣除了我5個 然后服務(wù)器內(nèi)部錯誤 再下載就沒幣了!
參與人數(shù) 1黑幣 +30 收起 理由
admin + 30 補償,應(yīng)該是服務(wù)器忙 稍后就可以了
ID:239391 發(fā)表于 2017-10-31 14:08 | 顯示全部樓層
啥情況 沒回復(fù)上。。
ID:252291 發(fā)表于 2017-11-22 15:32 | 顯示全部樓層
感謝分享,然而沒有黑幣下不了
ID:252569 發(fā)表于 2017-11-23 10:12 | 顯示全部樓層
感謝分享,就是黑幣不夠 下載不了
ID:266522 發(fā)表于 2017-12-25 14:50 | 顯示全部樓層
同樣的,沒有黑幣下載不了。
ID:271543 發(fā)表于 2018-1-4 19:26 | 顯示全部樓層
感謝分享
ID:276487 發(fā)表于 2018-1-16 10:48 | 顯示全部樓層
感謝分享,可惜黑幣不夠 下載不了
ID:282582 發(fā)表于 2018-2-6 13:14 | 顯示全部樓層
感謝分享
感謝分享可惜沒法下載
ID:282582 發(fā)表于 2018-2-8 17:01 | 顯示全部樓層
感謝分享可惜沒法下載
ID:281021 發(fā)表于 2018-2-28 14:26 | 顯示全部樓層
正在找,感謝分享
ID:291387 發(fā)表于 2018-3-14 14:05 | 顯示全部樓層
謝謝分享
ID:158812 發(fā)表于 2018-4-25 18:11 | 顯示全部樓層
謝謝分享,謝謝
ID:68832 發(fā)表于 2018-5-7 10:41 | 顯示全部樓層
謝謝分享,謝謝
ID:328593 發(fā)表于 2018-5-13 00:24 | 顯示全部樓層
謝謝分享,謝謝
ID:371955 發(fā)表于 2018-7-15 14:33 | 顯示全部樓層
十分感謝分享。
ID:227986 發(fā)表于 2018-8-28 11:23 | 顯示全部樓層
謝謝分享,謝謝
ID:328148 發(fā)表于 2018-10-8 18:31 | 顯示全部樓層
感謝分享科學(xué)沒有黑幣下載
ID:406578 發(fā)表于 2018-11-1 16:33 | 顯示全部樓層
為啥只扣分,下載不了呀?都扣了2次了,就是顯示下載人數(shù)太多,要等待2分鐘才能下載?
ID:406578 發(fā)表于 2018-11-1 16:43 | 顯示全部樓層
這程序代碼就是官網(wǎng)發(fā)的。如果用在stm32L151低功耗系列上是沒辦法用的。
ID:171207 發(fā)表于 2018-11-29 13:07 | 顯示全部樓層
好東西要學(xué)習(xí)
ID:443786 發(fā)表于 2018-12-11 08:37 | 顯示全部樓層
好東西,值得分享,謝謝啦
ID:378250 發(fā)表于 2019-1-4 18:19 | 顯示全部樓層
剛好用到 拿來參考 感謝。。
ID:409991 發(fā)表于 2019-2-25 16:53 | 顯示全部樓層
多謝,給力,不錯
ID:453848 發(fā)表于 2019-12-29 16:18 | 顯示全部樓層
不錯,謝謝!!。。。。。
ID:334781 發(fā)表于 2020-3-2 16:05 | 顯示全部樓層
看了一下,感覺好復(fù)雜呢,有點蒙了。
ID:492050 發(fā)表于 2020-3-15 22:16 | 顯示全部樓層
這個資料很好    謝謝樓主分享
ID:293590 發(fā)表于 2021-4-19 10:15 | 顯示全部樓層
我也一樣,扣除了5個幣,就沒有然后了
主站蜘蛛池模板: 国产精品成人国产乱一区 | 免费不卡视频 | 久久免费看片 | 天天爽夜夜爽夜夜爽精品视频 | 久久久久久中文字幕 | 一级特黄毛片 | 日韩欧美一区在线 | 国产黄a三级三级三级看三级男男 | 亚洲国产黄色 | 免费毛片在线播放 | 男女免费视频 | 欧美一区二区三区在线视频 | 色吧综合 | 在线观看日韩av | 欧美大片18 | 国产精品美女久久久久av爽 | 国产免费成人 | 在线日韩欧美 | 国产精品自在线 | 黄色大片在线 | 日韩视频网 | 黄色影视大全 | 亚洲影音 | 黄色三级视频网站 | 俄罗斯毛片 | 成人免费观看网站 | 黑人巨大精品欧美一区二区 | 中文字幕免费观看视频 | 国产精品成人一区二区三区 | 久久怡红院| 午夜在线观看视频网站 | 国产伦精品一区二区三区在线 | 日韩小视频 | 黄色片网站免费 | 欧美色图一区 | 91精品国自产在线观看 | 亚洲小视频 | 精品国产乱码久久久久久蜜柚 | 男人操女人的网站 | 久久久黄色片 | 久久精品久久久久 |
