查看: 2087|回復(fù): 1
有一段display函數(shù)在lcd上不顯示,其他都正常,why?
ID:210889 發(fā)表于 2017-7-3 10:41 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
display()采集的數(shù)據(jù)都能在lcd上顯示了,可是display2(是按鍵調(diào)節(jié)數(shù)值(電壓))卻不能顯示在lcd上.顯示程序我感覺(jué)沒(méi)有出錯(cuò)啊,為何display可以顯示,但display2就顯示不了
   #include<reg52.h>
#include"lcd.h"
#define uint unsigned int
#define uchar unsigned char
#define ulong unsigned long
sbit P1_6 = P1^6;
sbit P1_7 = P1^7;
sbit ADC_CS=P1^0;
sbit ADC_CLK=P1^1;
sbit ADC_DIN=P1^2;
sbit ADC_DOUT=P1^3;
sbit ADC_DRDY=P1^4;
uchar t = 0,c = 0,k,v =53;//k為脈沖周期
sbit S1 = P3^5;
sbit S2 = P3^4;
uchar date[3]={0,0,0};
uint result0[8]={0,0,0,0,0,0,0,0};
uint result1[8]={0,0,0,0,0,0,0,0};
void Display(uint AD_data);
void Display1(uint AD_data);
void Display2();
void PWM_Control1( uchar Width, uchar DutyCycle,uchar count,uchar partern);
void PWM_Control2( uchar Width, uchar DutyCycle,uchar count,uchar partern);
void Delay_1ms(uint c)
        uchar a,b;
        for(;c>0;c--)
                for(b=199;b>0;b--)
                        for(a=1;a>0;a--);
void WriteToReg_ADC(uint byteword )                //發(fā)送控制字
        uint AD16bit,Token;
        uchar i;
        ADC_CLK=1;
        ADC_CS=0;
        Token=0x80;
        AD16bit=byteword;
        for(i=0;i<8;i++)
                if(AD16bit&Token) // 逐一取出各位上的數(shù)據(jù)
                        ADC_DIN=1;
                        ADC_DIN=0;
                ADC_CLK=1;
                ADC_CLK=0; //為發(fā)送數(shù)據(jù)做準(zhǔn)備
                ADC_CLK=1;
                Token=Token>>1;
        ADC_CLK=1;
        ADC_DIN=1;
uint ReadADC_16BitValue(uchar channel)        //發(fā)送控制字準(zhǔn)備讀取的通道,接著讀取數(shù)據(jù)
        uint AD16bit;
        uchar i;
        WriteToReg_ADC(0x38|channel);
        while(ADC_DRDY==1);          // 等待DRDY下降沿讀數(shù)據(jù)
        ADC_CLK=1;
        ADC_CS=0;
        AD16bit=0x00;
        for(i=0;i<16;i++)  //巡歷
                AD16bit=AD16bit<<1;
                ADC_CLK=0;
                if(ADC_DOUT==1)          //等待DRDY低電平時(shí)間
                        AD16bit=AD16bit|0x01; //最低位開(kāi)始
                ADC_CLK=1;
        ADC_CLK=1;
        ADC_DIN=1;
        return(AD16bit);        //返回?cái)?shù)據(jù)
void InitADC()
        uchar i;
        ADC_CLK=1;
        ADC_DIN=1;
        ADC_CS=0;
        for(i=0;i<40;i++)                  //自校驗(yàn)
                ADC_CLK=0;
                ADC_CLK=1;
        WriteToReg_ADC(0x20);           //先寫(xiě)通信寄存器,下一步時(shí)鐘寄存器
        WriteToReg_ADC(0x02);                  //100HZ   CLKIDS=0 CLKDIV=0(器件內(nèi)部頻率)
        WriteToReg_ADC(0x10);           //設(shè)置寄存器
        WriteToReg_ADC(0x44);           //自校準(zhǔn)
        WriteToReg_ADC(0x21);           //通道2
        WriteToReg_ADC(0x11);
        Delay_1ms(50);
void PWM_Control1( uchar Width, uchar DutyCycle,uchar count,uchar partern)  //1ms為最小單位
{        uchar i,j;
   //脈寬設(shè)置  Wdith
   //占空比 X0% DutyCycle
  //脈沖個(gè)數(shù)  count
  // pin = ;
   k = (Width*10)/DutyCycle; //PWM整個(gè)周期
           if(partern == 6)
     for(i=0;i<k*count;i++)
             P1_6= 0;
                 delay(Width);
                 P1_6= 1;
                 delay(k-Width);
    if(partern == 7)
         for(j=0;j<k*count;j++)
            P1_7 = 0;
                delay(Width);
                P1_7 = 1;
                delay(k-Width);
void PWM_Control2( uchar Width, uchar DutyCycle,uchar count,uchar partern)  //1ms為最小單位
{         uchar i,j;
   //脈寬設(shè)置  Wdith
   //占空比 X0% DutyCycle
  // pin = ;
   if(partern == 6)
             P1_6= 0;
                 delay(Width);
                 P1_6= 1;
                 delay(k-Width);
         if(partern == 7)
             P1_7= 0;
                 delay(Width);
                 P1_7= 1;
                 delay(k-Width);
/***************按鍵S1,S2調(diào)節(jié)電壓************/
unsigned int Set()
   if( S1 == 0)
          delay(5);
          if(S1 == 0)
            v++;
         if(S2 == 0)
                   delay(5);
                if(S2 == 0)
                   v--;
          return v;
/*******************設(shè)定值與檢測(cè)值比較****************/
void compare()
   if(v<50)PWM_Control1(7,7,1,7);else PWM_Control2(7,7,1,6);
uchar i;
        ulong sum=0;
        uint result;
        float h;
        lcd1602init();
        InitADC();
//        v = Set();
        lcd_pos(0x00);
        lcd1602writedata('V');
        lcd1602writedata('=');
        lcd1602writedata(5+0x30);
        lcd1602writedata(0x2e);
        lcd1602writedata(0x30);
        lcd_pos(0x08);
        lcd1602writedata('S');
        lcd1602writedata('e');
        lcd1602writedata('t');
/*        lcd1602writedata((v/10)+0x30);
        lcd1602writedata((v%10)+0x30);         */
        lcd_pos(0x40);
        lcd1602writedata('T');
        lcd1602writedata('s');
                WriteToReg_ADC(0x44);          //自校準(zhǔn)后DRDY返回低電平
                Delay_1ms(60);
                for(i=0;i<8;i++)   //讀取數(shù)據(jù)并轉(zhuǎn)換成電壓
                  result0[i]=ReadADC_16BitValue(0);
                  sum=sum+result0[i];
                sum=sum/8;
                result=(uint)sum;
                sum=0;
                h=result;
                result=h*5000/65536;
                Display(result);
                result=0;
                Delay_1ms(50);
/**********************就是這個(gè)函數(shù)********************/
/*******************同樣在主循環(huán)中,display正常,但這個(gè)display2不顯示***********/
                v = Set();
                        Display2();           //Display2函數(shù)寫(xiě)在主循環(huán)中但LCD卻不顯示
                Delay_1ms(5);
                compare();// 判定設(shè)定值與檢測(cè)值大小,從而輸出PWM1或PWM2 (P1^6或P1^7)
                Delay_1ms(5);
        //        Delay_1ms(500);
        /*        WriteToReg_ADC(0x21);
                Delay_1ms(60);
                 for(i=0;i<8;i++)
                  result1[i]=ReadADC_16BitValue(1);
                  sum=sum+result1[i];
                sum=sum/8;
                result=(uint)sum;
                sum=0;
                h=result;
                Display1(result);
                result=0;
        //        Delay_1ms(500);          */
        date[2]= (AD_data)/1000;
        date[1]= (AD_data)/100%10;
        date[0]= (AD_data)/10%10;
lcd_pos(0x45);
        lcd1602writedata(0x30+date[2]);
        lcd1602writedata(0x30+date[1]);
        lcd1602writedata(0x30+date[0]);
/*void Display1(uint AD_data)
lcd_pos(0x49);
/****************就是這個(gè)Display2函數(shù)*********************/
void Display2()
{  v = Set();
    lcd_pos(0x13);
評(píng)分
參與人數(shù) 1黑幣 +5 收起 理由
xiaoguo666 + 5 很給力!
查看全部評(píng)分
ID:210889 發(fā)表于 2017-7-3 11:11 | 只看該作者
靠找到了. 寫(xiě)了lcd_pos(0x13)這是錯(cuò)的位置, 應(yīng)該是在lcd_pos(0x0d),真是被自己蠢哭
主站蜘蛛池模板: 日韩激情一区二区 | 天天操夜夜爽 | 亚洲福利专区 | 亚洲午夜一区 | 黄色大片在线免费观看 | 中文字幕高清 | 亚洲福利片| 高跟肉丝丝袜呻吟啪啪网站av | 成人三级晚上看 | 久久香蕉精品 | 亚洲经典av | 欧美黄色一区二区 | 日韩欧美中文 | 国产精品一区在线播放 | 美女久久久 | 欧美在线激情 | 在线观看免费av网站 | 国产亚洲在线 | 久久久精品 | 国产无遮挡又黄又爽免费网站 | 久久亚洲免费视频 | 国产区在线观看 | 天天视频国产 | 人人艹人人 | 免费一区二区三区 | 在线看av网址| 久久精品在线播放 | av高清在线观看 | 在线天堂av | 激情视频网址 | 国产精品日日摸天天碰 | 国产69精品久久久久久 | 国产成人在线视频 | 日产久久视频 | 麻豆成人91精品二区三区 | 天堂成人 | 亚洲天堂久久久 | 91综合在线 | 九九热视频在线 | 国产福利久久 | 日韩视频免费 |
