查看: 5867|回復: 2
各位大神,這個是4*4矩陣鍵盤按鍵值數碼管顯示的程序 幫忙解釋一下代碼的意思(詳...
ID:217769 發表于 2017-7-8 22:29 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
#define SCANPORT P1
sbit spk=P3^0;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,
                                         0x6d,0x7d,0x07,0x7f,0x6f,
                                         0x77,0x7c,0x39,0x5e,0x79,
                                         0x71};
uchar uca_LineScan[4]={0xEF,0xDF,0xBF,0x7F};
uchar ucKeyScan()
        uchar Temp=0;
        uchar ucRow=0,ucLine=0;
        for(ucLine=0;ucLine<4;ucLine++)
                        SCANPORT=uca_LineScan[ucLine];
                        Temp=SCANPORT & 0x0F;
                        if(Temp!=0x0F)
                                switch(Temp)
                                        case 0x0E: ucRow=10;break;
                                        case 0x0D: ucRow=20;break;
                                        case 0x0B: ucRow=30;break;
                                        case 0x07: ucRow=40;break;
                                        default:   ucRow=50;break;
                                break;
        SCANPORT=0x0F;
        return ucRow+ucLine+1;
void vKeyProcess(unsigned char ucKeyCode)
        switch(ucKeyCode)
                case 11:P0=table[0];spk=1;break;                                                          //'7'
                case 12:P0=table[1];spk=1;break;                                                          //'8'
                case 13:P0=table[2];spk=1;break;
                case 14:P0=table[3];spk=1;break;
                case 21:P0=table[4];spk=1;break;                                                          //'4'
                case 22:P0=table[5];spk=1;break;                                                          //'5'
                case 23:P0=table[6];spk=1;break;
                case 24:P0=table[7];spk=1;break;
                case 31:P0=table[8];spk=1;break;                                                          //'1'
                case 32:P0=table[9];spk=1;break;                                                          //'2'
                case 33:P0=table[10];spk=1;break;
                case 34:P0=table[11];spk=1;break;
                case 41:P0=table[12];spk=1;break;                                  //'3'
                case 42:P0=table[13];spk=1;break;
                case 43:P0=table[14];spk=1;break;                                                  //'0'
                case 44:P0=table[15];spk=1;break;                                                          //'+'
                default:break;
        spk=0;
        P0=0;
                vKeyProcess(ucKeyScan());
                spk=0;
ID:211467 發表于 2017-7-10 14:11 | 顯示全部樓層
#include<reg51.h>        //頭文件
#define uchar unsigned char     //宏定義 uchar代替unsigned char
#define uint unsigned int    //宏定義 uint 代替unsigned int
#define SCANPORT P1  //宏定義SCANPORT代替P1口
sbit spk=P3^0;    //P3.0蜂鳴器輸出
                                         0x71};            //數組顯示0~F
uchar uca_LineScan[4]={0xEF,0xDF,0xBF,0x7F};  //數組定義4顯示
uchar ucKeyScan()
        uchar Temp=0;
        for(ucLine=0;ucLine<4;ucLine++)          //循環4次
                        SCANPORT=uca_LineScan[ucLine];                              //每次循環時P1依次顯示數組uca_LineScan的4個數字
Temp=SCANPORT & 0x0F;                                            //P1高4位清零,低四位不變。并把此值賦給Temp
                        if(Temp!=0x0F)                   //如果有按鍵按下,低四位會變化,進入IF語句
                                switch(Temp)             //4個按鍵按下ucRow顯示不同的值
                                break;
        SCANPORT=0x0F;                                            //P01高4位清零,使他不影響下次的按鍵顯示
return ucRow+ucLine+1;                            //3個數相加,按鍵按下 (沒有電路圖),可能是這個數字,僅寫出第一次循環的數字,共4次循環,
                                                      0001 0000+0000 0000+0000 0001=0x11
                                                      0010 0000+0000 0000+0000 0001=0x21
                                                      0011 0000+0000 0000+0000 0001=0x31
                                                      0100 0000+0000 0000+0000 0001=0x41
                                                    (。。。0x12,0x22,0x32,0x42
        switch(ucKeyCode)                         顯示一個數字,蜂鳴器響
                default:break;
        spk=0;
        P0=0;
                vKeyProcess(ucKeyScan());    //進入顯示子程序
                spk=0;                //關閉蜂鳴器
ID:213173 發表于 2017-7-10 18:05 | 顯示全部樓層
樓上注釋的很好,略做補充。
for(ucLine=0;ucLine<4;ucLine++) //行掃描1~4次,一旦行、列條件滿足立即跳出循環
        SCANPORT=uca_LineScan[ucLine]; //每次循環時P1依次置數,數組uca_LineScan的4個數字,判斷行碼
                switch(Temp)             //4個按鍵按下ucRow顯示不同的值,判斷列碼
                break;                                        //獲取有效鍵值即跳出for循環
return ucRow+ucLine+1;;                //返回鍵值=列值+行值+1(行值0~3,所以要+1)
主站蜘蛛池模板: 日本在线免费视频 | www.欧美在线 | 亚洲不卡 | 中文字幕在线观看免费 | 亚洲一区高清 | a在线视频 | 二区三区视频 | 国产福利视频在线观看 | 欧美精品一区二区三区四区 | av狠狠干 | 最新中文字幕在线 | 天天搞天天搞 | 精品国产欧美 | 九九热精品在线观看 | 亚洲欧美一区二区三区在线 | 三级网站在线 | 日韩一级二级三级 | 亚洲在线免费观看 | 免费黄色片视频 | 国产成人三级在线观看 | 欧美特黄一级片 | 中文字幕免费av | 国产日批视频 | 国产福利网站 | www.精品| 伊人网在线播放 | 在线国产小视频 | 精品日韩一区二区 | h片在线观看 | 毛片毛片毛片 | 97超碰在线免费观看 | 黄色小说视频网站 | 黄色小视频免费观看 | 国产tv| 久久免费看视频 | 超碰精品在线 | a级片在线观看 | 免费av在线网站 | 91av免费 | 日韩一区在线播放 | 日日夜夜天天操 |
