查看: 12740|回復: 7
最近搞了一個OLED的字庫程序
ID:218264 發(fā)表于 2017-7-9 15:04 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
* OLED屏測試程序
* msp430g2553
* 調用方法:
*                LCD_Init();  //        OLED 初始化
*                LCD_Fill(0x00);  // 全屏填充 0x00
*                LCD_GBK16(0, 2, "1.鋤禾日當午,\r2.汗滴禾下土。\r3.誰知盤中餐,");
*                LCD_P6x8Str (0,4,"OLED"); // 顯示6*8  字符串
*                = HowMuchWidth(Num);// 獲取某數有幾位
*                LCD_IntNum(x, y, HowMuchWidth(v), v); // 顯示數字
*                LCD_16Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char dat[]);//16像素高度圖片
*                LCD_8Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char ch[]);//8像素高度圖片
*                LCD_AllPic(unsigned char dat[]);//全局圖像顯示
* 說明:圖像取模:縱向取模,字節(jié)倒序
* 作者:星希望(已校驗)
* 日期:2016年7月25日
#include "msp430f149.h"
#include "OLED.h"
#include "OLED_Font.h"
#define LCD_SCL_1        P2OUT |=  BIT0
#define LCD_SCL_0        P2OUT &= ~BIT0
#define LCD_SDA_1        P2OUT |=  BIT1
#define LCD_SDA_0        P2OUT &= ~BIT1
#define LCD_RST_1        P2OUT |=  BIT2
#define LCD_RST_0        P2OUT &= ~BIT2
#define LCD_DC_1        P2OUT |=  BIT3
#define LCD_DC_0        P2OUT &= ~BIT3
#define XLevelL                0x00
#define XLevelH                0x10
#define XLevel                ((XLevelH&0x0F)*16+XLevelL)
#define Max_Column        128
#define Max_Row                64
#define        Brightness        0xCF
#define X_WIDTH 128
#define Y_WIDTH 64
unsigned int hz16_num = 0; // 漢字個數
void LCD_WrDat(unsigned char dat)
        unsigned char i=8;
        LCD_DC_1;
        LCD_SCL_0;
        while(i--)
                if(dat&0x80)        {LCD_SDA_1;}
                else                        {LCD_SDA_0;}
                LCD_SCL_1;
                dat<<=1;
                LCD_SCL_0;
void LCD_WrCmd(unsigned char cmd)
        unsigned char i=8;
        LCD_DC_0;
        LCD_SCL_0;
        while(i--)
                if(cmd&0x80)        {LCD_SDA_1;}
                else                        {LCD_SDA_0;}
                LCD_SCL_1;
                cmd<<=1;
                LCD_SCL_0;
void LCD_Set_Pos(unsigned char x, unsigned char y)
        LCD_WrCmd(0xb0+y);
        LCD_WrCmd(((x&0xf0)>>4)|0x10);
        LCD_WrCmd((x&0x0f)|0x00);
void LCD_Fill(unsigned char bmp_dat)
        unsigned char y, x;
        for(y=0;y<8;y++)
                LCD_WrCmd(0xb0+y);
                LCD_WrCmd(0x01);
                LCD_WrCmd(0x10);
                for(x=0;x<X_WIDTH;x++)
                        LCD_WrDat(bmp_dat);
void LCD_DLY_ms(unsigned int ms)
        while(ms--)
                __delay_cycles(100);
        return;
* OLED 初始化
void LCD_Init(void)
        P2DIR |= BIT0 | BIT1 | BIT2 | BIT3;
          LCD_SCL_1;
        //LCD_CS=1;        //預制SLK和SS為高電平
        LCD_RST_0;
        LCD_DLY_ms(50);
        LCD_RST_1;
        /* 計算漢字庫的大小 */
        hz16_num = sizeof hz16 / sizeof (struct typFNT_GB162);
        //從上電到下面開始初始化要有足夠的時間,即等待RC復位完畢
        LCD_WrCmd(0xae);//--關閉OLED面板
        LCD_WrCmd(0x00);//---set low column address置低列地址
        LCD_WrCmd(0x10);//---set high column address設置高列地址
        LCD_WrCmd(0x40);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)設置起始行地址設置映射RAM顯示起始行(0×00?0x3F之間)
        LCD_WrCmd(0x81);//--set contrast control register設置對比度控制寄存器
        LCD_WrCmd(0xcf);// Set SEG Output Current Brightness設置SEG輸出電流亮度
        LCD_WrCmd(0xa1);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常 設置SEG/列映射0XA0左右反置0xa1正常
        LCD_WrCmd(0xc8);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常 設置COM/行掃描方向為0xC0上下反置0xc8正常
        LCD_WrCmd(0xa6);//--set normal display        設置正常顯示
        LCD_WrCmd(0xa8);//--set multiplex ratio(1 to 64) 設置復用率(1~64)
        LCD_WrCmd(0x3f);//--1/64 duty         1/64責任
        LCD_WrCmd(0xd3);//-set display offset Shift Mapping RAM Counter (0x00~0x3F)         置顯示失調漂移映射RAM計數器(為0x00?0x3F之間)
        LCD_WrCmd(0x00);//-not offset         不能抵消
        LCD_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency        設置顯示時鐘分頻比/振蕩器頻率
        LCD_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec                設置的分頻比,設置時鐘為100幀/秒
        LCD_WrCmd(0xd9);//--set pre-charge period          組預充電期間
        LCD_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock         設置預充電為15時鐘和放電為1時鐘
        LCD_WrCmd(0xda);//--set com pins hardware configuration                                   組COM插針的硬件配置
        LCD_WrCmd(0x12);
        LCD_WrCmd(0xdb);//--set vcomh
        LCD_WrCmd(0x40);//Set VCOM Deselect Level         設置VCOM取消等級
        LCD_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)   設置頁面尋址模式(0×00/0×01/0X02)
        LCD_WrCmd(0x02);//
        LCD_WrCmd(0x8d);//--set Charge Pump enable/disable                設置電荷泵啟用/禁用
        LCD_WrCmd(0x14);//--set(0x10) disable                                        設置(0x10)后關閉
        LCD_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)   禁用整個顯示屏(0xa4/到0x55)
        LCD_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)    禁用逆顯示(0xa6/ A7)
        LCD_WrCmd(0xaf);//--turn on oled panel
        LCD_Fill(0x00);  //初始清屏
        LCD_Set_Pos(0,0);
* 函數名:LCD_P6x8Str(unsigned char x,unsigned char y,unsigned char *p)
* 功能描述:寫入一組標準ASCII字符串
* 參數:顯示的位置(x,y),y為頁范圍0~7,要顯示的字符串
* 返回:無
void LCD_P6x8Str(unsigned char x, unsigned char y, unsigned char ch[])
        unsigned char c=0,i=0,j=0;
        while (ch[j]!='\0')
                c =ch[j]-32;
                if(x>126 || c==13)        // 下一行
                {x=0;y++;}
                LCD_Set_Pos(x,y);
                for(i=0;i<6;i++)
                  LCD_WrDat(F6x8[c][i]);
                x+=6;
                j++;
* 函數名:LCD_8Pic(unsigned char x,unsigned char y,unsigned char *p)
* 功能描述:寫入一組高度為8像素的圖標
* 返回:無
void LCD_8Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char ch[])
        unsigned char j=0;
        LCD_Set_Pos(x,y);
        while (width)
                LCD_WrDat(ch[j]);
                j++;
                width--;
* 顯示漢字 及 8x16 ascii碼
* 坐標x,坐標y,內容
* 查找 hz16[] 結構體數組
void LCD_GBK16(unsigned int x, unsigned int y, unsigned char *s)
        unsigned char j;
        unsigned short k,x0;
        x0=x;
        while(*s)
                if((*s) < 128) // ASC段
                        k = *s;
                        if (k==13) //回車
                                x = x0;
                                y += 2;
                                if (k>32)        k-=32; //從有效字符開始編碼,避開前面的非字符區(qū)
                                else                k=0;
                                LCD_Set_Pos(x, y);
                                for(j=0; j<8; j++)
                                        LCD_WrDat(F8X16[k*16+j]);
                                LCD_Set_Pos(x, y+1);
                                for(j=0; j<8; j++)
                                        LCD_WrDat(F8X16[k*16+j+8]);
                                x += 8;
                        s++;
                else         // 漢字段
                        for(k=0; k<hz16_num; k++)
                                if( (hz16[k].Index[0]==*(s)) && (hz16[k].Index[1]==*(s+1)) )
                                        LCD_Set_Pos(x, y);
                                        for(j=0; j<16; j++)        //高8位
                                                LCD_WrDat(hz16[k].Msk[j]);
                                        for(j=0; j<16; j++)        //低8位
                                                LCD_WrDat(hz16[k].Msk[j+16]);
                                        break;
                        if( k==hz16_num )// 沒有找到該漢字
                                LCD_Set_Pos(x, y);
                                        LCD_WrDat(UnknowFont[j]);
                                        LCD_WrDat(UnknowFont[j+16]);
                        s += 2;
                        x += 16;
                if(x>120) {x=0; y+=2;}
* 函數名:LCD_16Pic(unsigned char x,unsigned char y,unsigned char *p)
* 參數:x,y                 顯示的位置,y為頁范圍0~7,
*                 width    圖標寬度
*                 dat[]    圖像數據
void LCD_16Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char dat[])
        unsigned char i=0;
          LCD_Set_Pos(x, y);
          for(i = 0;i < width;i++)
                  LCD_WrDat(dat[i]);
          LCD_Set_Pos(x, y + 1);
                  LCD_WrDat(dat[i+width]);
* 全屏圖像顯示
void LCD_AllPic(unsigned char dat[])
        unsigned char y, x;
        for(y=0; y<8; y++)
                LCD_Set_Pos(0, y);
                for(x=0; x<128; x++)
                         LCD_WrDat(dat[y*128+x]);
* 計算某數有幾位
unsigned char HowMuchWidth(unsigned long Num)
        unsigned char cnt=0;
        while(Num)
                Num /= 10;
                cnt++;
        return cnt;
* 顯示數字
* 參數:x,y - 坐標
*                Width- 寬度(有幾位數)
*                v         - 數字
* 說明:右對齊
void LCD_IntNum(unsigned char x, unsigned char y, unsigned char Width, unsigned long v)
        unsigned char a[11];
        unsigned char *p;
        // 數位分解
        a[10]= 0;
        a[9] = v    % 10 + '0';
        a[8] = v /10 % 10 + '0';
        a[7] = v /100 % 10 + '0';
        a[6] = v /1000 % 10 + '0';
        a[5] = v /10000 % 10 + '0';
        a[4] = v /100000 % 10 + '0';
        a[3] = v /1000000 % 10 + '0';
        a[2] = v /10000000 % 10 + '0';
        a[1] = v /100000000 % 10 + '0';
        a[0] = v /1000000000 % 10 + '0';
        p = &a[10-Width];
        // 顯示
        LCD_GBK16(x, y, p); // 顯示 8*16  字符串
* 顯示數字
* 參數:x,y - 坐標
*                Width- 寬度(有幾位數)
*                v         - 數字
* 說明:右對齊
void LCD_IntNum6x8(unsigned char x, unsigned char y, unsigned char Width, unsigned long v)
        unsigned char *p;
        // 數位分解
        a[10]= 0;
        p = &a[10-Width];
        // 顯示
        LCD_P6x8Str(x, y, p); // 顯示 8*16  字符串
#ifndef _OLED_H
#define _OLED_H
extern unsigned int hz16_num; // 漢字個數
void LCD_Init(void);
void LCD_CLS(void);
void LCD_P6x8Str(unsigned char x,unsigned char y,unsigned char ch[]);
void LCD_GBK16(unsigned int x, unsigned int y, unsigned char *s);
unsigned char HowMuchWidth(unsigned long Num);
void LCD_IntNum(unsigned char x, unsigned char y, unsigned char Width, unsigned long v);
void LCD_IntNum6x8(unsigned char x, unsigned char y, unsigned char Width, unsigned long v);
void LCD_8Pic (unsigned char x,unsigned char y,unsigned char width,unsigned char ch[]);
void LCD_16Pic(unsigned char x,unsigned char y,unsigned char width,unsigned char dat[]);
void LCD_AllPic(unsigned char dat[]);
void LCD_Fill(unsigned char dat);
#endif
收藏收藏3 分享淘帖 頂 踩
ID:708805 發(fā)表于 2020-3-15 13:13 | 只看該作者
前面的程序能不能加點文字,看不太懂!拜托
ID:260347 發(fā)表于 2019-4-12 12:45 來自觸屏版 | 只看該作者
兄弟,你這字庫不見呢?哪位可以給個完整的,謝謝!
ID:477629 發(fā)表于 2019-2-18 11:12 | 只看該作者
謝謝,學習了。
ID:305384 發(fā)表于 2019-2-17 16:01 | 只看該作者
兄弟你的不太完整我現在完善了功能,自己做了字庫,輸入自動搜索匹配!
ID:16848 發(fā)表于 2019-1-25 12:38 | 只看該作者
謝謝,學習了。
ID:371527 發(fā)表于 2018-12-27 18:10 | 只看該作者
很規(guī)整,比較完善的,不過顯示字體種類程序有些少,比如16*32 32*32 48*48 類的,并且數字也缺少小數顯示。。。
ID:305384 發(fā)表于 2018-12-4 01:21 來自觸屏版 | 只看該作者
哥可以給完整的嗎
主站蜘蛛池模板: 亚洲精品一区二三区不卡 | 欧美日韩在线精品 | 18在线观看免费入口 | 色综合欧美 | 亚洲综合在线视频 | 国产精品日日摸天天碰 | av在线免费播放 | 国产日本在线观看 | 国产一级一片免费播放放a 男男成人高潮片免费网站 精品视频在线观看 | 中文字幕在线免费视频 | 精品欧美在线 | 少妇高潮露脸国语对白 | 中文字幕网址在线 | 性色av一区 | 日韩高清一区 | 日韩欧美精品一区二区 | 欧美国产日韩一区二区 | av一区二区三区 | 亚洲欧美国产精品 | 男女啪啪免费网站 | 秋霞午夜鲁丝一区二区老狼 | 欧美一级做性受免费大片免费 | 日韩精品在线观看视频 | 亚洲人在线 | a视频在线免费观看 | 97视频在线观看免费 | 91午夜精品亚洲一区二区三区 | 一区二区三区视频在线 | 欧美日韩在线一区二区 | 成人黄色在线 | 国产伦精品一区二区三区88av | 天天干夜夜爱 | 亚洲精品视频免费在线观看 | 91爱看 | 中文字幕一二三四区 | www.婷婷| 成人深夜福利视频 | 精品在线观看视频 | 中文字幕91 | www性| av女人的天堂 |
