查看: 3849|回復: 1
安卓藍牙與藍牙模塊通信程序
ID:218769 發表于 2017-7-11 12:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
public class BluetoothLeService extends Service {
    private final static String TAG = "aaa";
    private BluetoothManager mBluetoothManager;
    private BluetoothAdapter mBluetoothAdapter;
    private BluetoothGattService myGattService;
    private BluetoothGattCharacteristic notification_characteristic;
    private String mBluetoothDeviceAddress;
    private BluetoothGatt mBluetoothGatt;
    private int mConnectionState = STATE_DISCONNECTED;
    private static final int STATE_DISCONNECTED = 0;
    private static final int STATE_CONNECTING = 1;
    private static final int STATE_CONNECTED = 2;
    private static final UUID service_uuid = UUID
            .fromString(SampleGattAttributes.SERVICE);
    private static final UUID notification1_uuid = UUID.fromString(SampleGattAttributes.NOTIFICATION_1);
    private final BluetoothGattCallback mGattCallback = new BluetoothGattCallback() {
        @Override
        public void onConnectionStateChange(BluetoothGatt gatt, int status, int newState) {
//            String intentAction;
            if (newState == BluetoothProfile.STATE_CONNECTED) {
                mConnectionState = STATE_CONNECTED;
                mBluetoothGatt.getServices();
                mBluetoothGatt.discoverServices();
                Log.i("aaa", "onConnectionStateChange.");
                EventBus.getDefault().post("connected");
            } else if (newState == BluetoothProfile.STATE_DISCONNECTED) {
                Log.d(TAG, "Disconnected from GATT server.");
                EventBus.getDefault().post("disconnect");
//                music.play(1, 0);
                mBluetoothGatt.close();
                mBluetoothDeviceAddress = null;
        @Override
        public void onServicesDiscovered(BluetoothGatt gatt, int status) {
            Log.i("aaa","onServicesDiscovered");
            if (status == BluetoothGatt.GATT_SUCCESS) {
                if (mBluetoothGatt != null) {
                    myGattService = mBluetoothGatt.getService(service_uuid);
                if (myGattService != null) {
                    String aaa = myGattService.getUuid().toString();
//                    Log.i("aaa", aaa+"success");
                    notification_characteristic = myGattService.getCharacteristic(notification1_uuid);
                if (notification_characteristic != null) {
//                    Log.i("aaa","notification_characteristic success");
                    setCharacteristicNotification(notification_characteristic, true);
        @Override
        public void onCharacteristicRead(BluetoothGatt gatt,
                                         BluetoothGattCharacteristic characteristic,
                                         int status) {
//                broadcastUpdate(ACTION_DATA_AVAILABLE, characteristic);
                final byte[] data = characteristic.getValue();
//                Log.i("aaa", "Readdata:"+DataUtil.getStringByBytes(data));
        @Override
        public void onCharacteristicChanged(BluetoothGatt gatt,
                                            BluetoothGattCharacteristic characteristic) {
            ReceiverUtil.analysis(data);
//            Log.i("aaa", "data:"+DataUtil.getStringByBytes(data));
        @Override
        public void onReadRemoteRssi(BluetoothGatt gatt, int rssi, int status) {
            super.onReadRemoteRssi(gatt, rssi, status);
    public class LocalBinder extends Binder {
        public BluetoothLeService getService() {
            return BluetoothLeService.this;
    @Override
    public IBinder onBind(Intent intent) {
        return mBinder;
    @Override
    public boolean onUnbind(Intent intent) {
        // After using a given device, you should make sure that BluetoothGatt.close() is called
        // such that resources are cleaned up properly.  In this particular example, close() is
        // invoked when the UI is disconnected from the Service.
        return super.onUnbind(intent);
    private final IBinder mBinder = new LocalBinder();
     * Initializes a reference to the local Bluetooth adapter.
     * @return Return true if the initialization is successful.
    public boolean initialize() {
        // For API level 18 and above, get a reference to BluetoothAdapter through
        // BluetoothManager.
        if (mBluetoothManager == null) {
            mBluetoothManager = (BluetoothManager) getSystemService(Context.BLUETOOTH_SERVICE);
                Log.e(TAG, "Unable to initialize BluetoothManager.");
                return false;
        mBluetoothAdapter = mBluetoothManager.getAdapter();
        if (mBluetoothAdapter == null) {
            Log.e(TAG, "Unable to obtain a BluetoothAdapter.");
            return false;
        return true;
    public void writeStringToGatt(byte[] data) {
        Log.i("aaa",DataUtil.getStringByBytes(data));
        if (notification_characteristic == null || mBluetoothGatt == null) {
        } else if (data != null) {
            notification_characteristic.setValue(data);
            mBluetoothGatt.writeCharacteristic(notification_characteristic);
            Log.i("aaa", "write_to_gatt");
    public boolean connect(final String address) {
            Log.w(TAG, "BluetoothAdapter not initialized");
            return false;
        if (mBluetoothAdapter == null || address == null) {
            Log.w(TAG, "BluetoothAdapter not initialized or unspecified address.");
            return false;
        // Previously connected device.  Try to reconnect.
        if (mBluetoothDeviceAddress != null && address.equals(mBluetoothDeviceAddress)
                && mBluetoothGatt != null) {
            Log.d(TAG, "Trying to use an existing mBluetoothGatt for connection.");
            if (mBluetoothGatt.connect()) {
                mConnectionState = STATE_CONNECTING;
                return true;
            } else {
                return false;
        final BluetoothDevice device = mBluetoothAdapter.getRemoteDevice(address);
        if (device == null) {
            Log.w(TAG, "Device not found.  Unable to connect.");
            return false;
        // We want to directly connect to the device, so we are setting the autoConnect
        // parameter to false.
        mBluetoothGatt = device.connectGatt(this, false, mGattCallback);
        Log.d(TAG, "Trying to create a new connection.");
        mBluetoothDeviceAddress = address;
        return true;
    public void disconnect() {
        if (mBluetoothAdapter == null || mBluetoothGatt == null) {
            return;
        mBluetoothGatt.disconnect();
    public void close() {
        if (mBluetoothGatt == null) {
            return;
        mBluetoothGatt = null;
    public void readCharacteristic() {
            return;
        mBluetoothGatt.readCharacteristic(notification_characteristic);
    public void setCharacteristicNotification(BluetoothGattCharacteristic characteristic,
                                              boolean enabled) {
            return;
        mBluetoothGatt.setCharacteristicNotification(characteristic, enabled);
        if (notification1_uuid.equals(characteristic.getUuid())) {
            BluetoothGattDescriptor descriptor = characteristic
                    .getDescriptor(UUID
                            .fromString(SampleGattAttributes.CLIENT_CHARACTERISTIC_CONFIG));
            descriptor
                    .setValue(BluetoothGattDescriptor.ENABLE_NOTIFICATION_VALUE);
            mBluetoothGatt.writeDescriptor(descriptor);
    public void getRssi() {
        if(mBluetoothGatt != null) {
            mBluetoothGatt.readRemoteRssi();
ID:383374 發表于 2019-1-20 11:07 | 只看該作者
可以發工程包上來嗎
主站蜘蛛池模板: 午夜免费观看视频 | 网站av | 亚洲色在线视频 | 久久怡红院 | 日韩一区二区三 | 国产精品视频久久久 | 性色av蜜臀av浪潮av老女人 | 中文字幕亚洲精品 | av一区二区三区在线观看 | 婷婷97| 国产一级生活片 | 日韩精品三区 | 日本视频在线播放 | 中文字幕丰满人伦在线 | 国产日韩精品视频 | 亚洲黄色一级 | 涩涩视频免费看 | 超碰com| 国产美女视频网站 | 午夜视频免费 | 日韩精品视频网站 | 九色在线观看 | 亚洲精品欧美 | 国产三区四区 | 婷婷97| 黄色大片在线 | 欧美日韩在线免费 | 黄色小视频在线观看 | 天天爽夜夜爽 | 欧美 日韩 国产 成人 在线 | 成人深夜福利视频 | 欧美激情在线播放 | 中文字幕永久 | 日本亚洲欧美 | 国产一区精品视频 | a级片在线观看 | 亚洲乱码在线观看 | www.麻豆av| 一级片久久 | 国产理论片在线观看 | 天天干夜夜|
