我還是參照相關(guān)資料寫出程序,但是不適用于STC89C51單片機(jī),需要構(gòu)造外圍電路,有大神能告訴我怎樣構(gòu)造外圍電路來調(diào)方波振幅嗎
單片機(jī)源程序如下:
- //三角波發(fā)生程序
- #include"reg51.h"
- #include <intrins.h>
- #define I2CDelay() {_nop_();_nop_();_nop_();_nop_();}
- sbit I2C_SCL = P3^7;
- sbit I2C_SDA = P3^6;
- sbit p_out=P1^0;
- unsigned char code triwave[]={0,16,32,48,64,80,96,112,
- 128,144,160,176,192,208,
- 224,240,255,240,224,208,
- 192,176,160,144,128,112,
- 96,80,64,48,32,16,};//三角波波表,選取32點(diǎn)
- unsigned char *pwave;//波表指針
- unsigned char T1RH = 1;
- unsigned char T1RL = 1;
- void I2CStart() //產(chǎn)生總線起始信號(hào)
- I2C_SDA = 1; //首先確保SDA、SCL都是高電平
- I2C_SCL = 1;
- I2CDelay();
- I2C_SDA = 0; //先拉低SDA
- I2CDelay();
- I2C_SCL = 0; //再拉低SCL
- void I2CStop() //產(chǎn)生總線停止信號(hào)
- I2C_SCL = 0; //首先確保SDA、SCL都是低電平
- I2C_SDA = 0;
- I2CDelay();
- I2C_SCL = 1; //先拉高SCL
- I2CDelay();
- I2C_SDA = 1; //再拉高SDA
- I2CDelay();
- bit I2CWrite(unsigned char dat) //I2C總線寫操作,待寫入字節(jié)dat,返回值為應(yīng)答狀態(tài)
- bit ack; //用于暫存應(yīng)答位的值
- unsigned char mask; //用于探測字節(jié)內(nèi)某一位值的掩碼變量
- for (mask=0x80; mask!=0; mask>>=1) //從高位到低位依次進(jìn)行
- if ((mask&dat) == 0) //該位的值輸出到SDA上
- I2C_SDA = 0;
- else
- I2C_SDA = 1;
- I2CDelay();
- I2C_SCL = 1; //拉高SCL
- I2CDelay();
- I2C_SCL = 0; //再拉低SCL,完成一個(gè)位周期
- I2C_SDA = 1; //8位數(shù)據(jù)發(fā)送完后,主機(jī)釋放SDA,以檢測從機(jī)應(yīng)答
- I2CDelay();
- ack = I2C_SDA; //讀取此時(shí)的SDA值,即為從機(jī)的應(yīng)答值
- I2CDelay();
- I2C_SCL = 0; //再拉低SCL完成應(yīng)答位,并保持住總線
- return (~ack); //應(yīng)答值取反以符合通常的邏輯:0=不存在或忙或?qū)懭胧。?=存在且空閑或?qū)懭氤晒?br />
- unsigned char I2CReadNAK() //I2C總線讀操作,并發(fā)送非應(yīng)答信號(hào),返回值為讀到的字節(jié)
- unsigned char dat;
- I2C_SDA = 1; //首先確保主機(jī)釋放SDA
- I2CDelay();
- if(I2C_SDA == 0) //讀取SDA的值
- dat &= ~mask; //為0時(shí),dat中對應(yīng)位清零
- else
- dat |= mask; //為1時(shí),dat中對應(yīng)位置1
- I2CDelay();
- I2C_SCL = 0; //再拉低SCL,以使從機(jī)發(fā)送出下一位
- I2C_SDA = 1; //8位數(shù)據(jù)發(fā)送完后,拉高SDA,發(fā)送非應(yīng)答信號(hào)
- I2CDelay();
- I2CDelay();
- I2C_SCL = 0; //再拉低SCL完成非應(yīng)答位,并保持住總線
- return dat;
- unsigned char I2CReadACK() //I2C總線讀操作,并發(fā)送應(yīng)答信號(hào),返回值為讀到的字節(jié)
- I2CDelay();
- else
- I2CDelay();
- I2C_SDA = 0; //8位數(shù)據(jù)發(fā)送完后,拉低SDA,發(fā)送應(yīng)答信號(hào)
- I2CDelay();
- I2CDelay();
- return dat;
- //設(shè)置DAC的初始值,val是初始值
- void DA(unsigned char val)
- I2CStart();
- if(!I2CWrite(0x48<<1))//尋址PCF8591,如未應(yīng)答,停止操作并返回
- I2CStop();
- return;
- I2CWrite(0x40);
- I2CWrite(val);
- I2CStop();
- //輸出波形頻率
- void setwavefreq(unsigned char freq)
- unsigned long temp;
- temp=(12/12)/(freq*32);//定時(shí)器的計(jì)數(shù)頻率,是波形頻率的32倍
- temp=65536-temp;//定時(shí)器重載
- temp=temp+33;//修斷中斷響應(yīng)延時(shí)造成的誤差
- T1RH=(unsigned char)(temp>>8);
- T1RL=(unsigned char)temp;
- TMOD&=0x0F;
- TMOD|=0x10;
- TH1=T1RH;
- TL1=T1RL;
- ET1=1;
- PT1=1;
- TR1=1;
- //中斷T1服務(wù)函數(shù)
- void timer1() interrupt 3
- static unsigned int i=0;
三角波.rar
(30.75 KB, 下載次數(shù): 37)
2017-7-15 16:12 上傳
點(diǎn)擊文件名下載附件
