查看: 3605|回復(fù): 2
1602程序怎么轉(zhuǎn)變成12864,求大神修改
ID:218048 發(fā)表于 2017-7-20 09:22 | 顯示全部樓層 |閱讀模式
30黑幣
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit rs=P0^7;
sbit lcden=P0^5;
sbit rw=P0^6;
sbit s1=P3^2;                   // 獨(dú)立按鍵K1
sbit s2=P3^3;                   // 獨(dú)立按鍵K2
sbit s3=P3^4;                   // 獨(dú)立按鍵K3
uchar count,s1num;
char miao,shi,fen;
uchar code table[]="  2007-7-30 MON";
uchar code table1[]="    00:00:00";
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(uchar com)
        rs=0;
        lcden=0;
        P2=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        rs=1;
        lcden=0;
        P2=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        uchar num;
        rw=0;
        lcden=0;
//        fen=59;
//        miao=53;
//        shi=23;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<15;num++)
                        write_date(table[num]);
                        delay(5);
        write_com(0x80+0x40);
        for(num=0;num<12;num++)
                        write_date(table1[num]);
                        delay(5);
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void write_sfm(uchar add,uchar date)
        uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+shi);
        write_date(0x30+ge);
void keyscan()
        if(s1==0)                                           //  K1 選擇調(diào)時(shí)間的位置
                delay(5);
                if(s1==0)
                {        s1num++;
                        while(!s1);
                        if(s1num==1)
                                TR0=0;
                                write_com(0x80+0x40+10);
                                write_com(0x0f);
                        if(s1num==2)
                                write_com(0x80+0x40+7);
                        if(s1num==3)
                                write_com(0x80+0x40+4);
                        if(s1num==4)
                                s1num=0;
                                write_com(0x0c);
                                TR0=1;
                }        //  K1 時(shí)間加1
                if(s1num!=0)
                        if(s2==0)
                                delay(5);
                                if(s2==0)
                                        while(!s2);
                                        if(s1num==1)
                                                miao++;
                                                if(miao==60)
                                                        miao=0;
                                                write_sfm(10,miao);
                                        if(s1num==2)
                                                fen++;
                                                if(fen==60)
                                                        fen=0;
                                                write_sfm(7,fen);
                                        if(s1num==3)
                                                shi++;
                                                if(shi==24)
                                                        shi=0;
                                                write_sfm(4,shi);
                        }        //  K1 時(shí)間減1
                        if(s3==0)
                                delay(5);
                                if(s3==0)
                                        while(!s3);
                                        if(s1num==1)
                                        /*        if(miao==0)
                                                        miao=59;
                                                        write_sfm(10,miao);
                                                miao--;
                                                if(miao==-1)
                                                        miao=59;
                                                write_sfm(10,miao);
                                        if(s1num==2)
                                                fen--;
                                                if(fen==-1)
                                                        fen=59;
                                                write_sfm(7,fen);
                                        if(s1num==3)
                                                shi--;
                                                if(shi==-1)
                                                        shi=23;
                                                write_sfm(4,shi);
        init();
                keyscan();
//        while(1);
void timer0() interrupt 1
        count++;
if(count==18)
                        count=0;
                        miao++;
                        if(miao==60)
                                miao=0;
                                fen++;
                                if(fen==60)
                                        fen=0;
                                        shi++;
                                        if(shi==24)
                                                shi=0;
                                        write_sfm(4,shi);
                                write_sfm(7,fen);
                        write_sfm(10,miao);
1602程序怎么轉(zhuǎn)變成12864程序的,求大神幫忙
ID:61002 發(fā)表于 2017-7-20 12:38 | 顯示全部樓層
不能直接轉(zhuǎn)的 需要重新寫
ID:82765 發(fā)表于 2017-7-20 13:05 | 顯示全部樓層
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
主站蜘蛛池模板: 高清一区二区 | 亚洲精品乱码久久久久久动漫 | 久久精品视频一区 | 99视频免费观看 | 97视频在线 | 成人在线免费视频观看 | 午夜免费小视频 | 久久超 | 98久久| 欲望岛av | 亚洲永久免费 | 日日夜夜精品视频免费 | 欧洲av网站| 一区二区三区黄色 | 国产精品久久久久久久久久久久久久久 | 欧美日韩在线免费观看 | 国产一区精品在线 | 玖玖视频 | 欧美久久网 | 精品国产999久久久免费 | 欧美啪啪网站 | 少妇激情视频 | 久久精品国产精品 | 久久精视频 | av网址在线播放 | 解开岳的丰满奶罩bd | 成年人黄色大片 | 成av人片一区二区三区久久 | 黄色av免费| 日韩免费 | 神马香蕉久久 | 五月天毛片 | 久久久久久国产精品 | 日韩黄色网址 | 日韩视频二区 | 亚洲国产精品久久久久久久 | 午夜激情福利视频 | 六月色| 日韩理论在线 | 欧美三级韩国三级日本三斤在线观看 | 肉丝美脚视频一区二区 |
