查看: 4168|回復: 6
我的超聲波測距為什么都出不來,幫幫我收下這10黑幣吧
ID:222099 發表于 2017-7-25 15:48 | 顯示全部樓層 |閱讀模式
10黑幣
程序如下
#include"lcd.h"
void Read_Busy()           //忙檢測函數,判斷bit7是0,允許執行;1禁止
    unsigned char sta;      //
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,釋放總線
    }while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd)     //寫命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //寫數據
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐標顯示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//按指定位置顯示一個字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
Lcd1602_Write_Cmd(X); //發命令字
Lcd1602_Write_Data(DData); //發數據
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //顯示字符串
    LcdSetCursor(x,y);      //當前字符的坐標
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打開,5*8,8位數據
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
#include<reg51.h>
#include<intrins.h>
#include"lcd.h"
sbit Trig = P2^1;
sbit Echo = P2^0;
unsigned char PuZh[]=" Pechin Science ";
unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0; //顯示用指針
       unsigned int  time=0;
    unsigned long S=0;
    bit      flag =0;
    unsigned char disbuff[4]    ={ 0,0,0,0,};
* 函 數 名         : main
* 函數功能     : 主函數
* 輸    入         : 無
* 輸    出         : 無
void Conut(void)
  time=TH0*256+TL0;
  TH0=0;
  TL0=0;
  S=(time*1.7)/100;     //算出來是CM
  if((S>=700)||flag==1) //超出測量范圍顯示“-”
   flag=0;
   DisplayOneChar(0, 1, ASCII[11]);
   DisplayOneChar(1, 1, ASCII[10]); //顯示點
   DisplayOneChar(2, 1, ASCII[11]);
   DisplayOneChar(3, 1, ASCII[11]);
   DisplayOneChar(4, 1, ASCII[12]); //顯示M
   disbuff[0]=S%1000/100;
   disbuff[1]=S%1000%100/10;
   disbuff[2]=S%1000%10 %10;
   DisplayOneChar(0, 1, ASCII[disbuff[0]]);
   DisplayOneChar(2, 1, ASCII[disbuff[1]]);
   DisplayOneChar(3, 1, ASCII[disbuff[2]]);
void zd0() interrupt 1    //T0中斷用來計數器溢出,超過測距范圍
    flag=1;        //中斷溢出標志
void  StartModule()            //啟動模塊
   Trig=1;                        //啟動一次模塊
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   Trig=0;
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
  while(--i)
   j=10;
   while(--j);
void main(void)
  TMOD=0x01;     //設T0為方式1,GATE=1;
  TH0=0;
  TL0=0;
  ET0=1;             //允許T0中斷
  EA=1;      //開啟總中斷
InitLcd1602();
LcdShowStr(0,0,PuZh);
   StartModule();
      while(!Echo);  //當RX為零時等待
      TR0=1;       //開啟計數
      while(Echo);   //當RX為1計數并等待
      TR0=0;    //關閉計數
         Conut();   //計算
   delayms(80);
只能這樣子
ID:222336 發表于 2017-7-25 16:11 | 顯示全部樓層
看一看
ID:221642 發表于 2017-7-25 20:47 | 顯示全部樓層
好好研究一下吧!
HC_SR04超聲波.zip
41.05 KB, 下載次數: 10
HC_SR04超聲波
ID:34643 發表于 2017-7-26 06:02 | 顯示全部樓層
你的程序中就沒有看到你的顯示驅動的端口設置情況啊,從這里看,你的程序是不全的。
ID:222099 發表于 2017-7-28 21:54 | 顯示全部樓層
51mcu 發表于 2017-7-26 06:02
是不全啊,謝了
ID:222099 發表于 2017-7-28 21:55 | 顯示全部樓層
陶墨一 發表于 2017-7-25 20:47
好好研究一下吧!
謝謝分享
ID:159760 發表于 2017-7-29 00:30 | 顯示全部樓層
用STm32的輸入捕獲功能捕獲引腳收到到電平的時間進行測距。不過有一點必須注意,超聲波模塊能夠產生超聲波信號的前提是必須要給模塊的引腳輸送脈沖信號,脈沖信號的周期在10ms左右,太高的的話是不能夠產生超聲波信號的
主站蜘蛛池模板: 最新中文字幕在线观看 | 黄色大片在线播放 | 欧美在线免费 | 中文字幕在线观看一区 | 精品福利在线 | 亚洲欧美另类在线 | 糖心vlog精品一区二区 | 国产又粗又猛又黄又爽无遮挡 | av黄色在线 | 91亚色视频 | 久久精品视频免费 | 99在线精品视频 | 日韩亚洲欧美在线观看 | 色哟哟一区二区 | 国产精品美女毛片真酒店 | 日韩欧美国产成人 | 久久精品久久久久 | 日本福利视频 | 久久av免费观看 | 久操av在线 | 伊人网综合 | 五月播播 | 在线观看av片 | 日韩视频在线观看免费 | 久草福利在线 | 天天摸天天干 | 欧美日韩高清 | 最新国产精品视频 | 1级黄色大片 | 亚洲免费一区二区 | 久久综合爱 | 色婷婷综合网 | 黄色一级小说 | av福利在线观看 | 成年人视频在线免费观看 | 国产精品高清在线观看 | 一区二区高清视频 | 国产成人在线免费观看 | 亚洲综合自拍 | 欧美日韩在线一区二区三区 | 狠狠撸狠狠干 |
