查看: 4239|回復: 2
圖像處理程序C++代碼
ID:222572 發表于 2017-7-26 16:09 | 顯示全部樓層 |閱讀模式
內含圖像處理程序C++代碼:
全部資料下載地址:
圖像處理程序.rar (1.45 MB, 下載次數: 27)
       MICROSOFT FOUNDATION CLASS LIBRARY : 002
AppWizard has created this 002 application for you.  This application
not only demonstrates the basics of using the Microsoft Foundation classes
but is also a starting point for writing your application.
This file contains a summary of what you will find in each of the files that
make up your 002 application.
002.dsp
    This file (the project file) contains information at the project level and
    is used to build a single project or subproject. Other users can share the
    project (.dsp) file, but they should export the makefiles locally.
002.h
    This is the main header file for the application.  It includes other
    project specific headers (including Resource.h) and declares the
    CMy002App application class.
002.cpp
    This is the main application source file that contains the application
    class CMy002App.
002.rc
    This is a listing of all of the Microsoft Windows resources that the
    program uses.  It includes the icons, bitmaps, and cursors that are stored
    in the RES subdirectory.  This file can be directly edited in Microsoft
    Visual C++.
002.clw
    This file contains information used by ClassWizard to edit existing
    classes or add new classes.  ClassWizard also uses this file to store
    information needed to create and edit message maps and dialog data
    maps and to create prototype member functions.
res\002.ico
    This is an icon file, which is used as the application's icon.  This
    icon is included by the main resource file 002.rc.
res\002.rc2
    This file contains resources that are not edited by Microsoft
    Visual C++.  You should place all resources not editable by
    the resource editor in this file.
For the main frame window:
MainFrm.h, MainFrm.cpp
    These files contain the frame class CMainFrame, which is derived from
    CMDIFrameWnd and controls all MDI frame features.
    This bitmap file is used to create tiled images for the toolbar.
    The initial toolbar and status bar are constructed in the CMainFrame
    class. Edit this toolbar bitmap using the resource editor, and
    update the IDR_MAINFRAME TOOLBAR array in 002.rc to add
    toolbar buttons.
For the child frame window:
ChildFrm.h, ChildFrm.cpp
    These files define and implement the CChildFrame class, which
    supports the child windows in an MDI application.
AppWizard creates one document type and one view:
002Doc.h, 002Doc.cpp - the document
    These files contain your CMy002Doc class.  Edit these files to
    add your special document data and to implement file saving and loading
    (via CMy002Doc::Serialize).
002View.h, 002View.cpp - the view of the document
    These files contain your CMy002View class.
    CMy002View objects are used to view CMy002Doc objects.
res\002Doc.ico
    This is an icon file, which is used as the icon for MDI child windows
    for the CMy002Doc class.  This icon is included by the main
Other standard files:
StdAfx.h, StdAfx.cpp
    These files are used to build a precompiled header (PCH) file
    named 002.pch and a precompiled types file named StdAfx.obj.
Resource.h
    This is the standard header file, which defines new resource IDs.
    Microsoft Visual C++ reads and updates this file.
Other notes:
AppWizard uses "TODO:" to indicate parts of the source code you
should add to or customize.
If your application uses MFC in a shared DLL, and your application is
in a language other than the operating system's current language, you
will need to copy the corresponding localized resources MFC42XXX.DLL
from the Microsoft Visual C++ CD-ROM onto the system or system32 directory,
and rename it to be MFCLOC.DLL.  ("XXX" stands for the language abbreviation.
For example, MFC42DEU.DLL contains resources translated to German.)  If you
don't do this, some of the UI elements of your application will remain in the
language of the operating system.
ID:229281 發表于 2017-9-11 10:47 | 顯示全部樓層
文件夾是空的
ID:558239 發表于 2019-12-25 15:37 | 顯示全部樓層
坑人啊
主站蜘蛛池模板: 国产一区二区精品丝袜 | 中文在线字幕免费观看 | 91av视频在线播放 | 午夜精品久久久久久 | 欧美视频一区二区 | 特级淫片裸体免费看 | 视频一区二区三区在线观看 | 福利视频午夜 | 日韩福利在线观看 | 亚洲在线播放 | 日韩a在线观看 | 日韩免费大片 | 色婷婷香蕉在线一区二区 | 亚洲天堂偷拍 | 国产一区二区视频在线观看 | 一区二区黄色 | 国产精品久久一区 | 欧美一区二区三区免费 | 成人免费看片在线观看 | 香蕉视频导航 | 深夜视频在线观看 | 久久免费看视频 | 精品欧美黑人一区二区三区 | 成年人毛片 | 美女91网站 | 爱爱短视频 | 毛片网站免费 | 国产精品美女在线 | 国产精品高清在线观看 | 国产在线黄色 | 色黄大色黄女片免费中国 | 91久久久久久久 | 久久er99热精品一区二区 | 亚洲精品国产精品国自产观看 | 欧美性猛交xxxx免费看久久久 | 蜜桃成人av | 日韩伦理一区二区 | 日韩中文字幕第一页 | 视频一二三区 | 色综合天天综合网国产成人网 | 亚洲影院在线 |
