#include<reg52.h>
#include<intrins.h>
sbit RS = P2^4; //定義端口
sbit RW = P2^5;
sbit EN = P2^6;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
#define KeyPort P1
unsigned char code dofly_code[]={'0','1','2','3','4','5','6','7','8','9'};//轉(zhuǎn)換成液晶顯示的字符
//void FH();
unsigned int x;
sbit OUT=P3^0; //定義OUT輸出端口
void Init_Timer0(void)
TMOD |= 0x01; //使用模式1,16位定時(shí)器,使用"|"符號可以在使用多個定時(shí)器時(shí)不受影響
//TH0=0x00; //給定初值,這里使用定時(shí)器最大值從0開始計(jì)數(shù)一直到65535溢出
//TL0=0x00;
EA=1; //總中斷打開
ET0=1; //定時(shí)器中斷打開
TR0=1; //定時(shí)器開關(guān)打開
uS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
unsigned char 是定義無符號字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時(shí)請使用匯編,大致延時(shí)
長度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
while(--t);
mS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
void DelayMs(unsigned char t)
while(t--)
//大致延時(shí)1mS
DelayUs2x(245);
DelayUs2x(245);
判忙函數(shù)
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
_nop_();
EN_SET;
return (bit)(DataPort & 0x80);
寫入命令函數(shù)
void LCD_Write_Com(unsigned char com)
// while(LCD_Check_Busy()); //忙則等待
DelayMs(5);
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
_nop_();
EN_CLR;
寫入數(shù)據(jù)函數(shù)
void LCD_Write_Data(unsigned char Data)
//while(LCD_Check_Busy()); //忙則等待
DelayMs(5);
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
清屏函數(shù)
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
寫入字符串函數(shù)
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
LCD_Write_Com(0x80 + x);
LCD_Write_Com(0xC0 + x);
while (*s)
LCD_Write_Data( *s);
s ++;
寫入字符函數(shù)
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
初始化函數(shù)
void LCD_Init(void)
LCD_Write_Com(0x38); /*顯示模式設(shè)置*/
DelayMs(5);
DelayMs(5);
DelayMs(5);
LCD_Write_Com(0x08); /*顯示關(guān)閉*/
LCD_Write_Com(0x01); /*顯示清屏*/
LCD_Write_Com(0x06); /*顯示光標(biāo)移動設(shè)置*/
DelayMs(5);
LCD_Write_Com(0x0C); /*顯示開及光標(biāo)設(shè)置*/
按鍵掃描函數(shù),返回掃描鍵值
unsigned char KeyScan(void) //鍵盤掃描函數(shù),使用行列反轉(zhuǎn)掃描法
unsigned char cord_h,cord_l;//行列值中間變量
KeyPort=0x0f; //行線輸出全為0
cord_h=KeyPort&0x0f; //讀入列線值
if(cord_h!=0x0f) //先檢測有無按鍵按下
DelayMs(10); //去抖
if((KeyPort&0x0f)!=0x0f)
KeyPort=cord_h|0xf0; //輸出當(dāng)前列線值
cord_l=KeyPort&0xf0; //讀入行線值
while((KeyPort&0xf0)!=0xf0);//等待松開并輸出
return(cord_h+cord_l);//鍵盤最后組合碼值
}return(0xff); //返回該值
按鍵值處理函數(shù),返回掃鍵值
unsigned char KeyPro(void)
switch(KeyScan())
case 0x7e:return 1;break;//0 按下相應(yīng)的鍵顯示相對應(yīng)的碼值
case 0x7d:return 2;break;//1
case 0x7b:return 3;break;//2
//case 0x77:return 3;break;//3
case 0xbe:return 4;break;//4
case 0xbd:return 5;break;//5
case 0xbb:return 6;break;//6
//case 0xb7:return 7;break;//7
case 0xde:return 7;break;//8
case 0xdd:return 8;break;//9
case 0xdb:return 9;break;//a
//case 0xd7:return 11;break;//b
//case 0xee:return 0;break;//c
//case 0xed:return 13;break;//d
//case 0xeb:return 14;break;//e
//case 0xe7:return 15;break;//f
default:return 0xff;break;
主函數(shù)
void main(void)
unsigned char num;
unsigned char i,j; //定義局部變量,i,j,其取值范圍是
LCD_Init();
LCD_Write_Com(0x0F);//光標(biāo)開,光標(biāo)閃爍開
LCD_Write_String(0,0,"Input 1-9 HZ");
Init_Timer0();
while (1)
num=KeyPro(); //按鍵返回的值賦給num
if(num!=0xff)
if((i==0)&&(j==0))//回到第一個字符時(shí)清屏
LCD_Clear();//清屏
LCD_Write_Char(0,0,dofly_code[num]);//依次顯示輸入字符
i++;
if(i==16)//如果第一行顯示滿,轉(zhuǎn)到第二行
i=0;j++;
if(j==2)//如果2行都顯示滿,清屏后重新從第一行顯示
j=0;
switch(num)
case 1:x=50000;break;
case 2:x=25000;break;
case 3:x=16600;break;
case 4:x=12200;break;
case 5:x=9980;break;
case 6:x=8000;break;
case 7:x=6800;break;
case 8:x=5800;break;
case 9:x=5000;break;
default:break;
//定時(shí)器中斷
void Timer0_isr(void) interrupt 1 using 1
unsigned char f;
//FH();
TH0=(65536-x)/256; //重新賦值 12M晶振計(jì)算,指令周期1uS,
//200mS方波半個周期100mS,由于定時(shí)器
//最大值65536 即65.536ms 所以
TL0=(65536-x)%256; //直接定時(shí)器不夠用,需要用循環(huán)處理,
//定時(shí)10ms,然后循環(huán)10次后輸出 10x10=100ms
f++;
if(f==10)
f=0;
OUT=~OUT; //用示波器可看到方波輸出
