從別處找的電子秤程序STM32單片機(jī)主控 hx711芯片+12864液晶顯示 希望對(duì)大家有幫助
stm32單片機(jī)主程序如下:
- /******************** (C) COPYRIGHT 2012 WildFire Team **************************
- * 文件名 :main.c
- * 描述 :3個(gè)LED在 SysTick 的控制下,以500ms的頻率閃爍。
- * 實(shí)驗(yàn)平臺(tái):野火STM32開發(fā)板
- * 庫(kù)版本 :ST3.5.0
- * 作者 :wildfire team
- #include "stm32f10x.h"
- #include "SysTick.h"
- #include "12864.h"
- #include "HX711.h"
- uint32_t ticktime;
- unsigned long HX711_Buffer = 0;
- unsigned int Weight_Maopi = 0,Weight_Shiwu = 0;
- char Price_Count = 0;
- unsigned char KEY_NUM = 0;
- unsigned char Price_Buffer[5] = {0x00,0x00,0x00,0x00,0x00};
- unsigned long Money = 0;
- unsigned char Flag_OK = 0;
- unsigned char temp = 0,temp1 = 0xf7;
- * 函數(shù)名:main
- * 描述 :主函數(shù)
- * 輸入 :無(wú)
- * 輸出 :無(wú)
- void Key_GPIO_Config(void)
- { GPIO_InitTypeDef GPIO_InitStructTRIG;
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE);
- GPIO_InitStructTRIG.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2;
- GPIO_InitStructTRIG.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructTRIG.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructTRIG);
- GPIO_SetBits(GPIOA, GPIO_Pin_1|GPIO_Pin_2 );
- void Led_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- GPIO_SetBits(GPIOC, GPIO_Pin_3 );
- void Get_Weight()
- HX711_Buffer = HX711_Read();
- HX711_Buffer = HX711_Buffer/100;
- if(HX711_Buffer >= Weight_Maopi)
- Weight_Shiwu = HX711_Buffer;
- Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //獲取實(shí)物的AD采樣數(shù)值。
- Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/2.135+0.05); //計(jì)算實(shí)物的實(shí)際重量
- //因?yàn)椴煌膫鞲衅魈匦郧不一樣,因此,每一個(gè)傳感器需要矯正這里的2.15這個(gè)除數(shù)。
- //當(dāng)發(fā)現(xiàn)測(cè)試出來(lái)的重量偏大時(shí),增加該數(shù)值。
- //如果測(cè)試出來(lái)的重量偏小時(shí),減小改數(shù)值。
- //該數(shù)值一般在2.15附近調(diào)整之間。因傳感器不同而定。
- //+0.05是為了四舍五入百分位
- if( Weight_Shiwu > 20000 )
- GPIO_ResetBits(GPIOC, GPIO_Pin_3 ); //打開警報(bào)
- else
- GPIO_SetBits(GPIOC, GPIO_Pin_3 ); //關(guān)閉警報(bào)
- else if(HX711_Buffer < Weight_Maopi - 30)
- GPIO_ResetBits(GPIOC, GPIO_Pin_3 ); //負(fù)重量報(bào)警
- //獲取毛皮重量
- void Get_Maopi()
- Weight_Maopi = HX711_Buffer/100;
- int main(void)
- Led_GPIO_Config();
- Key_GPIO_Config();
- /* 配置SysTick 為10us中斷一次 */
- SysTick_Init();
- LCD12864_InitPort(); //端口初始化
- LCD12864_Init(); //液晶初始化
- HX711_init();
- // LCD12864_Pos(3,5);
- LCD_ShowString(1,0,"初始化……");
- /* LCD12864_NoWaitIdle_COM_Write(0x80); //指針設(shè)置
- LCD12864_write_word("※※※※※※※※");
- LCD12864_NoWaitIdle_COM_Write(0x90); //指針設(shè)置
- LCD12864_write_word("※※歡迎使用※※");
- LCD12864_NoWaitIdle_COM_Write(0x88); //指針設(shè)置
- LCD12864_write_word("※20公斤電子秤※");
- LCD12864_NoWaitIdle_COM_Write(0x98); //指針設(shè)置
- LCD12864_write_word("※※※※※※※※"); */
- Get_Maopi(); //稱毛皮重量
- delay_ms(10000); //延時(shí)10s,等待傳感器穩(wěn)定
- Price_Count = 0;
- Price_Buffer[0] = 0;
- Price_Buffer[1] = 0;
- Price_Buffer[2] = 0;
- Price_Buffer[3] = 0;
- Price_Buffer[4] = 0;
- Money = 0;
- Flag_OK = 0;
- LCD12864_Clr(); //清空
- while(1)
- delay_ms(500);
- LCD12864_Clr();
- LCD_ShowString(1,0,"上海工程技術(shù)大學(xué)");
- LCD_ShowString(2,0,"大學(xué)生創(chuàng)新項(xiàng)目");
- // LCD12684_Wdat(i+0x30);
- Get_Weight(); //稱重
- //顯示當(dāng)前重量
- LCD_ShowString(3,0,"重量");
- LCD12864_Pos(3,2);
- // LCD12684_Wdat('');
- if( Weight_Shiwu/10000 != 0)
- LCD12684_Wdat(Weight_Shiwu/10000 + 0x30);
- else
- LCD12684_Wdat(' ');
- LCD12684_Wdat(Weight_Shiwu%10000/1000 + 0x30);
- LCD12684_Wdat('.');
- LCD12684_Wdat(Weight_Shiwu%1000/100 + 0x30);
- LCD12684_Wdat(Weight_Shiwu%100/10 + 0x30);
- LCD12684_Wdat(Weight_Shiwu%10 + 0x30);
- LCD_ShowString(3,6,"kg");
- /******************* (C) COPYRIGHT 2012 WildFire Team *****END OF FILE************/
完整源碼51黑下載地址:
HX711+lcd12864.rar
(286.38 KB, 下載次數(shù): 166)
2017-8-1 19:25 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
