查看: 5647|回復: 1
STC12單片機兩路PWM輸出(占空比可調)程序
ID:224782 發表于 2017-8-4 18:39 | 顯示全部樓層 |閱讀模式
*                                                     PWM輸出(可調)程序
*        Don.2017.7
#include <STC12C5A60S2.h>
#include <intrins.h>
typedef unsigned char uchar8;
sbit PWM0_ADD = P2 ^ 0;
sbit PWM0_CUT = P2 ^ 1;
sbit PWM1_ADD = P2 ^ 2;
sbit PWM1_CUT = P2 ^ 3;
void PWM0_OUT( )
        CCON = 0x00;
        //PCA控制器清零
        CL = 0;
        CH = 0;
        //16位PAC計數器清零
        TMOD = 0x42;
        //定時器0工作在模式2(8位自動重裝)
        TL0 = ;
        TH0 = ;
        //寫入初值
        //計算: 初值 = (256 - 外部晶振頻率 / PCA時鐘源頻率)H
        //PCA時鐘源頻率 = 256 * PWM頻率
        AUXR = 0X80;
        //T0工作在1T模式
        TR0 = 1;
        //T0開始工作
        CMOD = 0x08;
        //設置計數器時鐘源
        //0x00:系統時鐘/12, 0x02:系統時鐘/2
        //0x04: 定時器T0溢出脈沖, 0x06: P1.2引腳輸入的外部時鐘
        //0x08:系統時鐘, 0x0a: 系統時鐘/4
        //0x0c: 系統時鐘/6, 0x0e: 系統時鐘/8
        //PWM波的頻率 = CMOD數值(10位)/256
        CCAPM0 = 0x42;
        //8位PWM P1.3輸出
        //0x42:無中斷;0x53:下降沿產生中斷;
        //0x63:上升沿產生中斷;0x73:跳變沿產生中斷
        CCAP0L = 0xc0;
        CCAP0H = 0xc0;
        //占空比設置:數值 / 256 * 100%
        //0xc0:占空比為25%,0x80:占空比為50%,0x40:占空比為75%
        CR = 1;
void PWM1_OUT( )
        CCON = 0x00;
        //PCA控制器清零
        CL = 0;
        CH = 0;
        //16位PAC計數器清零
        CMOD = 0x08;
        //設置計數器時鐘源
        CCAPM1 = 0x42;
        //8位PWM P1.3輸出
        CCAP1L = 0xc0;
        CCAP1H = 0xc0;
        CR = 1;
void PWM0_Alter(uchar8 type0, uchar8 change0)
//type = 0減占空比,1增加占空比 change: 0x0c約5%,0x05約2%
        if(type0  ==  0)
                    if(CCAP0L < 0xe6)   //<90%
                        CCAP0L += change0;
                    CCAP0H += change0;
                if(CCAP0L > 0x19)  //>10%
                        CCAP0L -= change0;
                           CCAP0H -= change0;
void PWM1_Alter(uchar8 type1, uchar8 change1)
//type1 = 0減占空比,1增加占空比 change1: 0x0c約5%,0x05約2%
        if(type1  ==  0)
                    if(CCAP1L < 0xe6)   //<90%
                        CCAP1L += change1;
                    CCAP1H += change1;
                if(CCAP1L > 0x19)  //>10%
                        CCAP1L -= change1;
                           CCAP1H -= change1;
void PWM_Alter_Drive( )
        if(PWM0_ADD == 0)
                _nop_( );_nop_( );_nop_( );_nop_( );
                //按鍵消抖
                while(PWM0_ADD == 0);
                //按鍵釋放才跳出執行下一步
                PWM0_Alter(1, 0x05);
        if(PWM0_CUT == 0)
                while(PWM0_CUT == 0);
                PWM0_Alter(0, 0x05);
        if(PWM1_ADD == 0)
                //按鍵消抖
                while(PWM1_ADD == 0);
                //按鍵釋放才跳出執行下一步
                PWM1_Alter(1, 0x05);
        if(PWM1_CUT == 0)
                while(PWM1_CUT == 0);
                PWM1_Alter(0, 0x05);
void main( )
        P1M0 = 0x00;
        P1M1 = 0x00;
        P2M0 = 0x00;
        P2M1 = 0x00;
        //配置標準I/O口
        PWM0_OUT( );
        PWM1_OUT( );
                 PWM_Alter_Drive( );
ID:224782 發表于 2017-8-4 19:49 | 顯示全部樓層
可調占空比
主站蜘蛛池模板: 日韩视频免费在线观看 | 欧美日韩免费看 | 欧美成人精品一区二区 | 韩国av在线 | 2025国产精品 | 亚洲精品久久久蜜桃 | 在线免费观看黄 | 国产做受入口竹菊 | 免费久久久 | 欧美视频在线播放 | 亚洲视频在线一区 | 一级毛片一级毛片 | 婷婷六月天 | 中文字幕+乱码+中文乱码91 | 亚洲激情在线播放 | 黄色一级片网站 | 中文字幕在 | 毛片毛片毛片毛片毛片 | 日日爽夜夜爽 | 黄色大片av | 中文字幕av久久爽av | 午夜精品一区二区三区在线视频 | 又色又爽又黄18网站 | 亚洲一区免费 | 久久小视频| 欧美视频免费在线观看 | 欧美日韩在线一区二区 | 欧美综合一区 | 成人性生活免费视频 | 伊人网视频 | 国产精品麻豆视频 | 欧美69视频 | 久久精品视频网站 | 日本福利视频 | 国产主播99 | 亚洲一区二区免费视频 | 黄色a一级 | 超碰精品在线 | 欧洲精品一区二区 | 欧美区一区二 | 青青草福利视频 |
