查看: 3062|回復: 5
兩片NRF24L01無法實現通信 大神們幫我看看,兩天了!
ID:225049 發表于 2017-8-5 19:33 | 顯示全部樓層 |閱讀模式
兩片NRF24L01無法實現通信
  1. #include <STC12C5A60S2.H>
  2. #include"LCD1602display.h"
  3. // Define interface to nRF24L01
  4. // Define SPI pinssbit qq=P3^4;
  5. sbit CE = P2^1; // Chip Enable pin signal (output)
  6. sbit CSN = P2^2; // Slave Select pin, (output to CSN, nRF24L01)
  7. sbit SCK = P2^3; // Master Out, Slave In pin (output)
  8. sbit MOSI = P2^4; // Serial Clock pin, (output)
  9. sbit MISO = P2^5; // Master In, Slave Out pin (input)
  10. sbit IRQ = P2^6; // Interrupt signal, from nRF24L01 (input)
  11. sbit P3_7=P3^2;
  12. // SPI(nRF24L01) commands
  13. #define READ_REG 0x00 // Define read command to register
  14. #define WRITE_REG 0x20 // Define write command to register
  15. #define RD_RX_PLOAD 0x61 // Define RX payload register address
  16. #define WR_TX_PLOAD 0xA0 // Define TX payload register address
  17. #define FLUSH_TX 0xE1 // Define flush TX register command
  18. #define FLUSH_RX 0xE2 // Define flush RX register command
  19. #define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
  20. #define NOP 0xFF // Define No Operation, might be used to read status register
  21. // SPI(nRF24L01) registers(addresses)
  22. #define CONFIG 0x00 // 'Config' register address
  23. #define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
  24. #define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
  25. #define SETUP_AW 0x03 // 'Setup address width' register address
  26. #define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
  27. #define RF_CH 0x05 // 'RF channel' register address
  28. #define RF_SETUP 0x06 // 'RF setup' register address
  29. #define STATUS 0x07 // 'Status' register address
  30. #define OBSERVE_TX 0x08 // 'Observe TX' register address
  31. #define CD 0x09 // 'Carrier Detect' register address
  32. #define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
  33. #define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
  34. #define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
  35. #define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
  36. #define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
  37. #define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
  38. #define TX_ADDR 0x10 // 'TX address' register address
  39. #define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
  40. #define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
  41. #define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
  42. #define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
  43. #define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
  44. #define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
  45. #define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
  46. #define uchar unsigned char
  47. /***************************************************/
  48. #define TX_ADR_WIDTH 5 // 5字節寬度的發送/接收地址
  49. #define TX_PLOAD_WIDTH 4 // 數據通道有效數據寬度
  50. uchar code table[]={'0','1','2','3','4','5','6','7','8','9','a','b','c','d','e','f'};
  51. uchar code
  52. TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};
  53. // 定義一個靜態發送地址,該地址是指通道0的地址嗎??
  54. uchar RX_BUF[TX_PLOAD_WIDTH]; //是否以確定發送與接收的數據寬度一樣??
  55. uchar TX_BUF[TX_PLOAD_WIDTH]; //是否以確定發送與接收的數據寬度一樣??
  56. uchar flag; //該字符的作用???
  57. uchar x=0,y=0,z=0,m=0; //為什么設置為這個數字
  58. uchar bdata sta;
  59. sbit RX_DR        = sta^6;
  60. sbit TX_DS        = sta^5;
  61. sbit MAX_RT = sta^4;
  62. /**************************************************/
  63. /**************************************************
  64. 函數:delay_ms()
  65. 描述:
  66. 延遲x毫秒
  67. /**************************************************/
  68. void delay_ms(uchar x)
  69. {
  70. uchar i, j;
  71. i = 0;
  72. for(i=0; i<x; i++)
  73. {
  74. j = 250;
  75. while(--j);
  76. j = 250;
  77. while(--j);
  78. }
  79. }
  80. /**************************************************/
  81. /**************************************************
  82. 函數:SPI_RW()
  83. 描述:
  84. 根據SPI協議,寫一字節數據到nRF24L01,同時從nRF24L01
  85. 讀出一字節
  86. /**************************************************/
  87. //是不是接收端與發射端都要用到這個函數,讀出的字節是否為狀態字
  88. uchar SPI_RW(uchar byte)
  89. {
  90. uchar i;
  91. for(i=0; i<8; i++) // 循環8次
  92. {
  93. MOSI = (byte & 0x80); // byte最高位輸出到MOSI
  94. byte <<= 1; // 低一位移位到最高位
  95. SCK = 1; // 拉高SCK,nRF24L01從MOSI讀入1位數據,同時從MISO輸出1位數據
  96. byte |= MISO; // 讀MISO到byte最低位
  97. SCK = 0; // SCK置低
  98. }
  99. return(byte); // 返回讀出的一字節
  100. }
  101. /**************************************************/
  102. /**************************************************
  103. 函數:SPI_RW_Reg()
  104. 描述:寫數據value到reg寄存器
  105. 是不是通過寫地址確定寄存器,然后向其寫數據??
  106. /**************************************************/
  107. uchar SPI_RW_Reg(uchar reg, uchar value)
  108. {
  109. uchar status;
  110. CSN = 0; // CSN置低,開始傳輸數據
  111. status = SPI_RW(reg); // 選擇寄存器,同時返回狀態字
  112. SPI_RW(value); // 然后寫數據到該寄存器
  113. CSN = 1; // CSN拉高,結束數據傳輸
  114. return(status); // 返回狀態寄存器
  115. }
  116. /**************************************************/
  117. /**************************************************
  118. 函數:SPI_Read()
  119. 描述:
  120. 從reg寄存器讀一字節
  121. /**************************************************/
  122. uchar SPI_Read(uchar reg)
  123. {
  124. uchar reg_val;
  125. CSN = 0; // CSN置低,開始傳輸數據
  126. SPI_RW(reg); // 選擇寄存器
  127. reg_val = SPI_RW(0); // 然后從該寄存器讀數據 為什么送一個0就可以讀回一個數據
  128. CSN = 1;
  129. // CSN拉高,結束數據傳輸
  130. return(reg_val); // 返回寄存器數據
  131. }
  132. /**************************************************/
  133. /**************************************************
  134. 函數:SPI_Read_Buf()
  135. 描述:
  136. 從reg寄存器讀出bytes個字節,通常用來讀取接收通道
  137. 數據或接收/發送地址
  138. /**************************************************/
  139. uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
  140. {
  141. uchar status, i;
  142. CSN = 0; // CSN置低,開始傳輸數據
  143. status = SPI_RW(reg); // 選擇寄存器,同時返回狀態字
  144. for(i=0; i<bytes; i++)
  145. pBuf[ i] = SPI_RW(0); // 逐個字節從nRF24L01讀出
  146. CSN = 1; // CSN拉高,結束數據傳輸
  147. return(status); // 返回狀態寄存器
  148. }
  149. /**************************************************/
  150. /**************************************************
  151. 函數:SPI_Write_Buf()
  152. 描述:
  153. 把pBuf緩存中的數據寫入到nRF24L01,通常用來寫入發
  154. 射通道數據或接收/發送地址
  155. /**************************************************/
  156. uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
  157. {
  158. uchar status, i;
  159. CSN = 0; // CSN置低,開始傳輸數據
  160. status = SPI_RW(reg); // 選擇寄存器,同時返回狀態字
  161. for(i=0; i<bytes; i++)
  162. SPI_RW(pBuf[ i]); // 逐個字節寫入nRF24L01
  163. CSN = 1; // CSN拉高,結束數據傳輸
  164. return(status); // 返回狀態寄存器
  165. }
  166. /**************************************************/
  167. /**************************************************
  168. 函數:RX_Mode()
  169. 描述:
  170. 這個函數設置nRF24L01為接收模式,等待接收發送設備的數據包
  171. /**************************************************/
  172. void RX_Mode(void)
  173. {
  174. CE = 0;
  175. SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);
  176. // CRC使能,16位CRC校驗,上電,接收模式
  177. CE = 1; // 拉高CE啟動接收設備
  178. }
  179. /**************************************************/
  180. /**************************************************
  181. 函數:TX_Mode()
  182. 描述:
  183. 這個函數設置nRF24L01為發送模式,(CE=1持續至少10us),
  184. 130us后啟動發射,數據發送結束后,發送模塊自動轉入接收
  185. 模式等待應答信號。
  186. /**************************************************/
  187. void TX_Mode(uchar * BUF)
  188. {
  189. CE = 0;
  190. SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);
  191. // 寫入發送地址 (與接收地址一樣)
  192. SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH);
  193. // 寫數據包到TX FIFO(前以定義BUF數組發送數據4字節,寫數據用于發送模式)
  194. SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);
  195. // CRC使能,16位CRC校驗,上電
  196. CE = 1;
  197. }
  198. /**************************************************/
  199. /*********
  200. *****************************************
  201. 函數: init_io()
  202. 描述:
  203. 初始化IO
  204. /**************************************************/
  205. void init_io(void)
  206. {
  207. CE = 0; // 待機
  208. CSN = 1; // SPI禁止
  209. SCK = 0; // SPI時鐘置低
  210. IRQ = 1; // 中斷復位
  211. SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);
  212. // 寫入發送地址 (與接收地址一樣)
  213. SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);
  214. // 為了應答接收設備,接收通道0地址和發送地址相同 (發射端設置0通道接收應答信號)
  215. SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 使能接收通道0自動應答
  216. SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 使能接收通道0
  217. SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a);
  218. // 自動重發延時等待250us+86us,自動重發10次
  219. SPI_RW_Reg(WRITE_REG + RF_CH, 10);
  220. // 選擇射頻通道0x40
  221. SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH);
  222. // 接收通道0選擇和發送通道相同有效數據寬度
  223. SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);
  224. // 數據傳輸率1Mbps,發射功率0dBm,低噪聲放大器增益
  225. }
  226. /**************************************************/
  227. /**************************************************
  228. 函數:CheckButtons()
  229. 描述:
  230. 檢查按鍵是否按下,按下則發送一字節數據
  231. /**************************************************/
  232. void CheckButtons()
  233. {
  234. if(!P3_7)        // 讀取P3^0狀態
  235. {
  236. delay_ms(10);
  237. if(!P3_7)        // 讀取P3^0狀態
  238. {
  239. TX_BUF[0]=x ; // 數據送到緩存 (uchar DATA = 0x01;)
  240. TX_BUF[1]=y;
  241. TX_BUF[2]=z ; // 數據送到緩存 (uchar DATA = 0x01;)
  242. TX_BUF[3]=m;
  243. DisplayOneChar(4,0,table[x%16]);
  244. DisplayOneChar(4,1,table[y%16]);
  245. x++;y++;z+=2;m+=3;
  246. RX_Mode();        // 設置為接收模式
  247. while(!P3_7);
  248. }
  249. }
  250. }
  251. /**************************************************/
  252. void Init_T0 (void)
  253. {
  254. TMOD = 0x01;
  255. TH0 = (65536-50000) /256;
  256. TL0 = (65536-50000) %256;
  257. EA = 1;
  258. ET0 = 1;
  259. TR0 = 1;
  260. }
  261. /**************************************************
  262. 函數:main()
  263. 描述:
  264. 主函數
  265. /**************************************************/
  266. void main(void)
  267. { qq=0;init_io();        // 初始化IO
  268. LCDInit();
  269. Init_T0();
  270. RX_Mode();        // 設置為接收模式
  271. DisplayListChar(1,0,"Xt=");
  272. DisplayListChar(1,1,"Yt=");
  273. DisplayListChar(7,0,"Xr=");
  274. DisplayListChar(7,1,"Yr=");
  275. while(1)
  276. {
  277. CheckButtons();
  278. }
  279. }
  280. /**************************************************/
  281. void Time0_ISR(void) interrupt 1
  282. {
  283. TH0 = (65536-30000) /256;
  284. TL0 = (65536-30000) %256;
  285. SPI_RW(FLUSH_TX);
  286. TX_Mode(TX_BUF);        // 把nRF24L01設置為發送模式并發送數據
  287. //        Check_ACK(1); // 等待發送完畢,清除TX FIFO
  288. //        SPI_RW(FLUSH_TX);
  289. sta = SPI_Read(STATUS);        // 讀狀態寄存器
  290. if(RX_DR)        // 判斷是否接受到數據
  291. {
  292. SPI_Read_Buf(RD_RX_PLOAD, RX_BUF, TX_PLOAD_WIDTH);
  293. // 從RX FIFO讀出數據
  294. flag = 1;
  295. }
  296. SPI_RW_Reg(WRITE_REG + STATUS, sta); // 清除RX_DS中斷標志
  297. if(flag)        // 接受完成
  298. {
  299. flag = 0;        // 清標志
  300. DisplayOneChar(10,0,table[RX_BUF[1]%16]);
  301. DisplayOneChar(10,1,table[RX_BUF[2]%16]);
  302. }
  303. }
ID:123289 發表于 2017-8-5 21:57 | 顯示全部樓層
程序是自己寫的?
NRF24L01通訊原理清楚?
ID:225049 發表于 2017-8-6 09:32 | 顯示全部樓層
yzwzfyz 發表于 2017-8-5 21:57
程序是自己寫的?
NRF24L01通訊原理清楚?
nrf24l01是網上找的,自己根據自己的理解改了一部分,lcd顯示自己寫的
ID:225125 發表于 2017-8-6 10:17 | 顯示全部樓層
先看看有沒有發送出來。把其中一個設置成接收模式,初始化后中斷腳為高,接收到數據中斷為低。
ID:225145 發表于 2017-8-6 11:00 | 顯示全部樓層
LCD顯示能用嗎?用用其他程序試試,或者先不用顯示,用幾個小燈接在扣上看看,數據是不是傳輸成功了
ID:225145 發表于 2017-8-6 11:02 | 顯示全部樓層
回復我怎么看不到啊
主站蜘蛛池模板: 国产欧美在线播放 | 亚洲经典一区 | 免费在线小视频 | 成人国产精品一区二区 | 免费看a级片 | 亚洲精品免费在线 | 久久国产精品视频 | 一级a毛片 | 国产成人+综合亚洲+天堂 | 成人免费看片视频 | 免费网站观看www在线观看 | 中文字幕在线观看网站 | 成年人视频在线播放 | 日韩精品视频免费在线观看 | 99精品在线 | 欧美成人精品一区 | 天天天天躁天天爱天天碰2018 | 色网站在线观看 | www.youjizz.com日本 | 日本一级淫片 | 欧美午夜精品久久久久免费视 | www.免费视频. | 谁有毛片网站 | 国产女人18毛片18精品 | 一区二区三区在线免费 | 亚洲精品自拍视频 | 天天综合av | 久久国产精品免费 | 91爱爱爱| 又色又爽又黄18网站 | www在线播放 | 国产激情网站 | 久久久久久网 | 亚洲第一色网 | 日韩视频一区二区三区 | 日本久久网 | 国产精品久久久久久久久久 | 日韩欧美网站 | 亚洲图片一区二区 | 青青草视频免费在线观看 | 欧美在线免费观看视频 |
