查看: 2908|回復: 0
ADXL363引腳圖功能及數據手冊下載
ID:228414 發表于 2017-8-19 17:17 | 顯示全部樓層 |閱讀模式
ADXL363引腳圖如下:
ADXL363管腳功能:
功能框圖:
       GENERAL DESCRIPTION
The ADXL363 is an ultralow power, three-sensor combination consisting of a 3-axis MEMS accelerometer, a temperature sensor, and an on-board ADC input for synchronous conversion of an external signal. The entire system consumes less than 2 µA at a 100 Hz output data rate and 270 nA when in motion triggered wake-up mode.
The ADXL363 communicates via a serial port interface (SPI) and always provides 12-bit output resolution for all three
sensors. The ADXL363 accelerometer provides selectable measurement
ranges of ±2 g, ±4 g, and ±8 g, with a resolution of 1 mg/LSB on the ±2 g range. Unlike accelerometers that use power duty
cycling to achieve low power consumption, the ADXL363 does not alias input signals by undersampling; it samples the full bandwidth of the sensor at all data rates.
The ADXL363 temperature sensor operates with a scale factor of 0.065°C (typical). Acceleration and temperature data can be stored in a 512-sample multimode FIFO buffer, allowing up to 13 sec of data to be stored.
In addition to the accelerometer and temperature sensor, the ADXL363 also provides access to an internal ADC for synchronous conversion of an additional analog input.
The ADXL363 operates on a wide 1.6 V to 3.5 V supply range, and can interface, if necessary, to a host operating on a separate, lower supply voltage. The ADXL363 is available in a 3 mm × 3.25 mm × 1.06 mm package.
ADXL363數據手冊下載:
ADXL363.pdf (1.84 MB, 下載次數: 6)
主站蜘蛛池模板: 亚洲国产黄色 | 在线免费观看黄色片 | 亚洲福利专区 | 伊人久久精品 | 亚洲一区二区三区视频 | 欧美日韩高清 | 久久午夜视频 | 黄色av免费在线观看 | 亚洲在线一区 | 国产精品手机在线观看 | 亚洲欧美在线播放 | 国产精品日韩在线 | 黄色大片免费在线观看 | 日韩福利在线 | 黄网站视频 | 免费av片| 久久亚洲欧美 | 久久这里都是精品 | 日韩在线视频观看 | 糖心vlog精品一区二区 | 在线a| 久久国产欧美 | 国产999视频 | 亚洲激情在线播放 | 一区二区高清视频 | 亚洲欧美日本在线 | 日韩天堂av | 国产精品一品二区三区的使用体验 | 日韩精品一区在线 | 五月天黄色网址 | 日日夜夜天天干 | 亚洲性猛交 | 欧美日日日 | 精品免费视频 | 欧美成人一区二区三区片免费 | 免费三级网站 | 91av免费| 日日日操操操 | 欧美成人精品一区二区三区 | 人人射人人| 欧美成人一级 |
