程序是:發(fā)送給單片機01時,單片機發(fā)送“Turn on ad!”給上位機,開啟ad轉(zhuǎn)換,并顯示AD的電壓,在數(shù)碼管的前三位顯示ad的數(shù)字量。
但發(fā)送01給單片機后,擰動電位器后,二極管會改變,但數(shù)碼管一直顯示8.8.8.(會閃);求幫忙解決!!!!
還有用adc0804芯片來實現(xiàn)ad轉(zhuǎn)換,我到現(xiàn)在還有點搞不懂!!!支招!!!
- #include <reg52.h>
- #include <intrins.h>
- #include <stdio.h>
- #define uchar unsigned char
- sbit dula=P2^6;
- sbit wela=P2^7;
- sbit adwr=P3^6;
- sbit adrd=P3^7;
- uchar a,b,flag,flag_ad,flag_smg,ad_vol,t0;
- float num;
- uchar code table[]={
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- void delay(uchar z)
- uchar x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void display(uchar num)
- uchar bai,shi,ge;
- bai=num/100;
- shi=num%100/10;
- ge=num%10;
- wela=1;
- P0=0x7e;
- wela=0;
- P0=0xff;
- dula=1;
- dula=table[bai];
- dula=0;
- delay(5);
- wela=1;
- P0=0x7d;
- wela=0;
- P0=0xff;
- dula=1;
- dula=table[shi];
- dula=0;
- delay(5);
- wela=1;
- P0=0x7b;
- wela=0;
- P0=0xff;
- dula=1;
- dula=table[ge];
- dula=0;
- delay(5);
- uchar ad()
- uchar adval;
- wela=1;
- P0=0x7f;
- adwr=1;
- adwr=0;
- adwr=1;
- delay(10);
- P1=0xff;
- adrd=1;
- adrd=0;
- adval=P1;
- adrd=1;
- P1=adval;
- return adval;
- void main()
- EA=1;
- TMOD=0x21;
- TH1=0xfd;
- TL1=0xfd;
- TR1=1;
- TH0=0x4c;
- TL0=0x00;
- ET0=1;
- SM0=0;
- SM1=1;
- REN=1;
- ES=1;
- while(1)
- if(flag==1)
- flag=0;
- ES=0;
- TI=1;
- switch(b)
- case 0 : puts("Turn on ad!\n");TR0=1;break;
- case 1 : puts("Turn off ad!\n");TR0=0;break;
- case 2 : puts("Error!\n");break;
- while(!TI);
- TI=0;
- ES=1;
- if(flag_smg==1)
- ES=0;
- flag_smg=0;
- ad_vol=ad();
- num=(float)ad_vol*5.0/256.0;
- TI=1;
- printf("The voltagle is %fV\n",num);
- while(!TI);
- TI=0;
- ES=1;
- display(ad_vol);
- void timer0() interrupt 1
- TH0=0x4c;
- TL0=0x00;
- t0++;
- if(t0==20)
- t0=0;
- flag_smg=1;
- void uart() interrupt 4
- RI=0;
- a=SBUF;
- flag=1;
- if(a==1)
- b=0;
- else if(a==2)
- b=1;
- else
- b=2;
