查看: 3788|回復: 1
超聲波PIC單片機C程序
ID:229453 發(fā)表于 2017-8-30 20:59 | 顯示全部樓層 |閱讀模式
超聲波PIC單片機C程序
  1. ////////////////////////////////////////////////////////////////////////////////
  2. //
  3. //     PIC16F877 + HC-SR04 + LCD03 example
  4. //     Written October 2008 , using HITECH PIC16 compiler
  5. //
  6. //                 Note - assumes a 20MHz crystal, which is 5MHz timer clock
  7. //                 A 1:4 prescaler is used to give a 1.25MHz timer count (0.8uS per tick)
  8. //
  9. //     This code is Freeware - Use it for any purpose you like.
  10. //
  11. ///////////////////////////////////////////////////////////////////////////////
  12. #include <pic.h>
  13. #include <stdio.h>
  14.
  15. __CONFIG(0x3b32);
  16. #define trig        RB0
  17. #define echo        RB1
  18. void clrscn(void);                                                        // prototypes
  19. void cursor(char pos);
  20. void print(char *p);
  21. void setup(void);
  22. unsigned int get_srf04(void);
  23. char s[21];        // buffer used to hold text to print
  24. void main(void)
  25. {
  26. unsigned int range;
  27.         setup();        // sets up the PIC16F877 I2C port
  28.         clrscn();        // clears the LCD03 disply
  29.         cursor(2);        // sets cursor to 1st row of LCD03
  30.         sprintf(s,"SRF04 Ranger Test");                // text, printed into our buffer
  31.         print(s);        // send it to the LCD03
  32.         while(1) {        // loop forever
  33.                 range = get_srf04();                                        // get range from srf04 (round trip flight time in 0.8uS units)
  34.                 cursor(24);        // sets cursor to 2nd row of LCD03
  35.                 sprintf(s,"Range = %dcm  ", range/72);        // convert to cm
  36.                 print(s);        // send it to the LCD03
  37.                 cursor(44);        // sets cursor to 3rd row of LCD03
  38.                 sprintf(s,"Range = %dinch  ", range/185);        // convert to inches
  39.                 print(s);        // send it to the LCD03
  40.                 TMR1H = 0;        // 52mS delay - this is so that the SRF04 ranging is not too rapid
  41.                 TMR1L = 0;        // and the previous pulse has faded away before we start the next one
  42.                 T1CON = 0x21;                                                        // 1:4 prescale and running
  43.                 TMR1IF = 0;
  44.                 while(!TMR1IF);                                                // wait for delay time
  45.                 TMR1ON = 0;        // stop timer
  46.         }
  47. }
  48. unsigned int get_srf04(void)
  49. {
  50.         TMR1H = 0xff;                                                // prepare timer for 10uS pulse
  51.         TMR1L = -14;
  52.         T1CON = 0x21;                                                // 1:4 prescale and running
  53.         TMR1IF = 0;
  54.         trig = 1;                                                        // start trigger pulse
  55.         while(!TMR1IF);                                        // wait 10uS
  56.         trig = 0;                                                        // end trigger pulse
  57.         TMR1ON = 0;                                                        // stop timer
  58.
  59.         TMR1H = 0;                                                        // prepare timer to measure echo pulse
  60.         TMR1L = 0;
  61.         T1CON = 0x20;                                                // 1:4 prescale but not running yet
  62.         TMR1IF = 0;
  63.         while(!echo && !TMR1IF);                // wait for echo pulse to start (go high)
  64.         TMR1ON = 1;                                                        // start timer to measure pulse
  65.         while(echo && !TMR1IF);                        // wait for echo pulse to stop (go low)
  66.         TMR1ON = 0;                                                        // stop timer
  67.         return (TMR1H<<8)+TMR1L;                // TMR1H:TMR1L contains flight time of the pulse in 0.8uS units
  68. }
  69. void clrscn(void)
  70. {
  71.         SEN = 1;        // send start bit
  72.         while(SEN);                                                        // and wait for it to clear
  73.         SSPIF = 0;
  74.         SSPBUF = 0xc6;                                                // LCD02 I2C address
  75.         while(!SSPIF);                                                // wait for interrupt
  76.         SSPIF = 0;                                                        // then clear it.
  77.         SSPBUF = 0;                                                        // address of register to write to
  78.         while(!SSPIF);                                                //
  79.         SSPIF = 0;                                                        //
  80.         SSPBUF = 12;                                                // clear screen
  81.         while(!SSPIF);                                                //
  82.         SSPIF = 0;                                                        //
  83.         SSPBUF = 4;                                                        // cursor off
  84.         while(!SSPIF);                                                //
  85.         SSPIF = 0;                                                        //
  86.
  87.         PEN = 1;        // send stop bit
  88.         while(PEN);                                                        //
  89. }
  90.
  91. void cursor(char pos)
  92. {
  93.         SEN = 1;        // send start bit
  94.         while(SEN);                                                        // and wait for it to clear
  95.         SSPIF = 0;
  96.         SSPBUF = 0xc6;                                                // LCD02 I2C address
  97.         while(!SSPIF);                                                // wait for interrupt
  98.         SSPIF = 0;                                                        // then clear it.
  99.         SSPBUF = 0;                                                        // address of register to write to
  100.         while(!SSPIF);                                                //
  101.         SSPIF = 0;                                                        //
  102.         SSPBUF = 2;                                                        // set cursor
  103.         while(!SSPIF);                                                //
  104.         SSPIF = 0;                                                        //
  105.         SSPBUF = pos;                                                //
  106.         while(!SSPIF);                                                //
  107.         SSPIF = 0;                                                        //
  108.
  109.         PEN = 1;        // send stop bit
  110.         while(PEN);                                                        //
  111. }
  112.
  113. void print(char *p)
  114. {
  115.         SEN = 1;        // send start bit
  116.         while(SEN);                                                        // and wait for it to clear
  117.         SSPIF = 0;
  118.         SSPBUF = 0xc6;                                // LCD02 I2C address
  119.         while(!SSPIF);                                // wait for interrupt
  120.         SSPIF = 0;                                        // then clear it.
  121.         SSPBUF = 0;                                        // address of register to write to
  122.         while(!SSPIF);                                //
  123.         SSPIF = 0;                                        //
  124.         while(*p) {
  125.                 SSPBUF = *p++;                        // write the data
  126.                 while(!SSPIF);                        //
  127.                 SSPIF = 0;                                //
  128.         }
  129.         PEN = 1;                                        // send stop bit
  130.         while(PEN);                                        //
  131. }
  132. ……………………
  133. …………限于本文篇幅 余下代碼請從51黑下載附件…………
超聲波PIC單片機C程序.rar (1.63 KB, 下載次數(shù): 19)
ID:209855 發(fā)表于 2017-11-22 14:01 | 顯示全部樓層
超聲波傳感器是用的什么型號的?
主站蜘蛛池模板: 午夜色播| 一区二区三区国产精品 | 午夜在线视频观看 | 日韩黄色在线观看 | 在线播放黄色 | 国产一区在线看 | 精品视频在线播放 | 五月婷色| 黄色三级大片 | 欧美不卡一区 | 欧美日韩黄色片 | 欧美福利在线观看 | 久久狠狠干 | 黄色一级免费视频 | 国产精品一区二区在线免费观看 | 中文字幕日韩欧美 | 躁躁躁日日躁 | 久久黄视频 | 91色网站| 国产综合久久 | 亚洲人高潮女人毛茸茸 | 国产精品毛片一区视频播 | 国产一区高清 | 91播放| 国产精品区二区三区日本 | 日韩av不卡在线 | 一级黄色大片 | 精品一区二区三区免费 | 美日韩一区 | 99久热| 男女h黄动漫啪啪无遮挡软件 | 亚洲天堂影院 | 亚洲国产一区在线 | 欧美亚洲国产日韩 | 久久免费视频观看 | 日韩精品三区 | 国产视频福利 | 91动漫在线观看 | 国产欧美精品一区二区 | 特级毛片爽www免费版 | 亚洲激情中文字幕 |
