查看: 3910|回復: 1
C8051F同時實現AD和串口收發的程序
ID:229453 發表于 2017-8-31 10:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
C8051F同時實現AD和串口收發的程序.rar (7.5 KB, 下載次數: 39)
  1. //---------------------------------------------------------------------
  2. #include <C8051F020.h>
  3. #include "stdio.h"
  4. sfr16 TMR3RL = 0x92; //定時器3重裝載寄存器
  5. sfr16 TMR3 = 0x94; //定時器3計數器
  6. sfr16 DP     =0x82;
  7. sfr16 ADC0   =0xbe;
  8. sfr16 ADC0GT =0xc4;
  9. sfr16 ADCOLT =0xc6;
  10. sfr16 RCAP2  =0xca;
  11. sfr16 T2     =0xcc;
  12. sfr16 RCAP4  =0xe4;
  13. sfr16 T4     =0xf4;
  14. sfr16 DAC0   =0xd2;
  15. sfr16 DAC1   =0xd5;
  16. #define uchar unsigned char
  17. #define uint unsigned int
  18. //----------------------------------------------------------------------
  19. //參數設置區
  20. //----------------------------------------------------------------------
  21. #define BAUDRATE 9600 //波特率bps
  22. #define SYSCLK 11059200 //外部晶振,修改也要修改OSCXCN
  23. #define SMODVAL 0 //SMOD的值,修改請也修改PCONVAL
  24. #define PCONVAL 0x00 //PCON的值,=0x00時SMOD0=0; =0x80時SMOD0=1
  25. #define TXVAL (256-SYSCLK*(SMODVAL+1)/BAUDRATE/384) //定時器初值
  26. #define MAX_LEN 1//每次接收/發送字符串的長度
  27. #define SAMPLERATE0 5000
  28. #define NUM_SAMPLES 1
  29. #define TURE        1
  30. #define FALSE       0
  31. //---------------------------------------------------------------------
  32. //全局變量
  33. //---------------------------------------------------------------------
  34. sbit LED = P1^6; //LED '1'亮 '0'滅
  35. bit readFlag = 0; //讀標志
  36. uchar readCounts = 0; //已經讀取的字符個數,與MAX_LEN比較
  37. uchar idATa trdATa[MAX_LEN]; //要接收/發送的字符串
  38. xdATa unsigned samples[NUM_SAMPLES];
  39. bit ADC0_DONE;
  40. //----------------------------------------------------------------------
  41. //子函數聲明
  42. //----------------------------------------------------------------------
  43. void SYSCLK_Init(void); //系統時鐘初始化
  44. void PORT_Init(void); //端口初始化
  45. void UART0_Init(void); //串口UART0初始化
  46. void Send_Char(uchar ch); //發送單個字符
  47. void Send_String(uchar * str, uint len); //發送一個字符串
  48. void UART0_ISR(); //串口中斷服務程序,接收字符
  49. void Timer3_Init(uint counts); //定時器3初始化
  50. void Timer3_ISR(void); //定時器3中斷服務程序
  51. void ADC0_Init (void);
  52. //----------------------------------------------------------------------
  53. //主函數
  54. //----------------------------------------------------------------------
  55. void main(void)
  56. {unsigned short i;
  57. floAT temp,k;
  58. WDTCN = 0xde; //禁止看門狗
  59. WDTCN = 0xad;
  60. P6&=0x02;
  61. here:
  62. i=0;
  63. SYSCLK_Init(); //時鐘初始化
  64. PORT_Init(); //端口初始化
  65. UART0_Init(); //串口初始化
  66. Timer3_Init(SYSCLK/12/10); //定時器初始化
  67. EA = 1; //開全局中斷
  68. ADC0_Init();
  69. AD0INT=0;
  70. AD0BUSY=1;
  71. while(AD0INT==0);
  72. temp=ADC0;
  73. k=(temp*2.4)/4096;
  74. printf("\n");
  75. printf("voltage%f",k);
  76. printf("\n");
  77. i=0;
  78. while(1)
  79. {
  80.    {if(readFlag) //已經讀取
  81.     {
  82.       readFlag = 0; //清零
  83.       Send_String(trdATa,MAX_LEN); //發送字符串
  84.      i++;
  85. if(i==10000){goto here;}
  86. }
  87. }
  88. }}
  89. //----------------------------------------------------------------------
  90. //子函數具體實現
  91. //----------------------------------------------------------------------
  92. //系統時鐘初始化
  93. void SYSCLK_Init(void)
  94. {
  95. uint i;
  96. OSCXCN = 0x67; //采用外部晶振22.1184MHz,不分頻. 選型OSCXCN=0110,0111
  97. for(i=0;i<256;i++); //等待>1ms
  98. while(!(OSCXCN&0x80)); //查詢直到XTLVLD=1,晶振穩定
  99. OSCICN = 0x88; //切換到外部振蕩器,允許時鐘失效監測器. OSCICN=1000,1000
  100. }
  101. //端口初始化
  102. void PORT_Init(void)
  103. {
  104. XBR0 = 0x04; //允許UART0,RX,TX連到2個端口引腳. XBR0=0000,0100
  105. XBR1 = 0x00;
  106. XBR2 = 0x40; //交*開關使能
  107. P0MDOUT |= 0x03; //P0.0為推拉方式輸出,即TX0,RX0所在的端口 0000,0011
  108. P1MDOUT |=0x40; //P1.6為推拉方式輸出,即LED所在的端口 0100,0000
  109. }
  110. //串口初始化
  111. void UART0_Init(void)
  112. {
  113.    SCON0=0x50;
  114.    TMOD=0x20;
  115.    TH1=-(SYSCLK/BAUDRATE/16);
  116.    TR1=1;
  117.    CKCON|=0x10;
  118.    PCON|=0x80;
  119.    TI0=1;
  120.    TR0 = 1;
  121.    ES0 =1; //UART0中斷開啟   ADC時候要屏蔽
  122.    TR1 = 1; //啟動定時器T1
  123.   }
  124. //定時器初始化
  125. void Timer3_Init(uint counts)
  126. {
  127. TMR3CN = 0x00; //禁止定時器T3,清TF3,采用SYSCLK/12為時基
  128. TMR3RL = -counts; //初始化重裝載值
  129. TMR3 = 0xffff; //設置為立即重裝載
  130. EIE2 |= 0x01; //T3中斷開啟
  131. TMR3CN |= 0x04; //啟動T3
  132. }
  133. //發送單個字符
  134. void Send_Char(uchar ch)
  135. {
  136. SBUF0 = ch; //送入緩沖區1
  137. while(TI0 == 0); //等待發送完畢
  138. TI0 = 0; //軟件清零
  139. }
  140. //發送字符串,調用Send_Char() len字符串長度
  141. void Send_String(uchar * str,uint len)
  142. {
  143. uint k = 0;
  144. do
  145. {
  146. Send_Char(*(str + k));
  147. k++;
  148. } while(k < len);
  149. }
  150. //定時器3中斷服務程序
  151. void Timer3_ISR(void) interrupt 14 using 0
  152. {
  153. TMR3CN &= ~(0x80); //清TF3
  154. LED = ~LED;
  155. }
  156. //UART0中斷服務程序. 接收字符
  157. void UART0_ISR(void) interrupt 4 using 1
  158. {
  159. uchar rxch;
  160. if(RI0) //中斷標志 RI0=1 數據完整接收
  161. {
  162. RI0 = 0; //軟件清零
  163. rxch = SBUF0; //讀緩沖
  164. if(readCounts>=MAX_LEN)
  165. {
  166. readCounts = 0;
  167. readFlag = 1;
  168. }
  169. ……………………
  170. …………限于本文篇幅 余下代碼請從51黑下載附件…………
ID:467431 發表于 2021-3-6 17:16 | 只看該作者
   ES0 =1; //UART0中斷開啟   ADC時候要屏蔽    樓主,ADC這個中斷不能與串口中斷同時使用嗎?
主站蜘蛛池模板: 久久机热这里只有精品 | 亚洲视频一区二区三区四区 | 99精品视频在线观看 | 日韩国产一区二区 | 欧美一区二区三区在线视频 | 91精品国产成人www | 日韩二区三区 | 日韩黄色影院 | 免费av一区二区三区 | 日日干日日射 | 成人小网站 | 免费一区二区三区 | 日本在线播放 | 91麻豆产精品久久久久久夏晴子 | 日韩在线观看一区 | 精品久久久一区二区 | 日韩三级一区 | 91久久国产综合久久91 | 久久网页 | 中文在线字幕观看 | 亚洲欧美一区二区三区四区 | 久久夜色精品国产欧美乱极品 | 激情影院在线观看 | 日本a级大片| 一区二区三区视频 | 亚洲欧美在线视频 | 久久午夜精品 | 国产精品伦一区二区三级视频 | 国产精品激情 | 日韩精品一区在线观看 | 亚欧在线观看 | 天天操天天碰 | 超碰在线小说 | 午夜国产在线 | 国产成人精品视频 | 中文字幕一二三四区 | 国产九九 | 欧美国产精品一区二区 | 日本www视频| 中文字幕av一区二区三区 | 欧美成人区 |
