#include <reg52.h>
#include " LCD1602.h "
sbit zuo = P1^0;
sbit you = P1^1;
sbit zhong = P1^2;
sbit IN1 = P2^1; //P2.0到P2.3是電機驅動輸出控制端
sbit IN2 = P2^2;
sbit IN3 = P2^3;
sbit IN4 = P2^4;
sbit Trig = P2^0; //產生脈沖引腳
sbit Echo = P3^3; //回波引腳
uint distance[4]; //測距接收緩沖區
unsigned char code ASCII[16] = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
unsigned char disbuff[4]= { 0,0,0,0,};
uint distance1;
bit succeed_flag; //測量成功標志
void chaoshengbo();
void delay_20us();
void delay_ms(uint x);
void delay(uint t);
void Tracking();
void shunback();
//延時程序1
void delay(uint t)
uchar j;
while(t--)
{for(j=5;j>0;j--);}
//微妙延時程序
void delay_us(uint x)
do {
x--;
while(x>1);
//毫秒延時
while(x!=0)
delay_us(500);
x--;
//20微妙延時
void delay_20us()
uchar bt ;
for(bt=0;bt<100;bt++);
void Init()
Trig=0;
TMOD = 0x11; //T/C1采用16位定時器/計數器
ET1 = 1; //定時器1開中斷
ET0 = 1;
TH0 = 0x00;
TL0 = 0x00;
TH1 = 0xff;
TL1 = 0xce;
TR1=1;
TR0 = 1; //定時計數器啟動計數
EX0 = 1; //外部中斷0關中斷
PT1 = 1;
EA = 1; //CPU開中斷
//超聲波測距
void chaoshengbo()
uint distance_data,S;
Trig=1;
delay_20us();
Trig=0; //產生一個20us的脈沖,在Trig引腳
while(!Echo); //等待Echo回波引腳變高電平
TR0=1; //啟動定時器1
while(Echo);
TR0=0;
delay_ms(7);
distance_data=TH0*256+TL0;
TH0=0;
TL0=0;
S=(distance_data*1.7)/100;
if(succeed_flag==1)
distance1=S;
disbuff[0]=((S/100)%10);
disbuff[1]=((S/10)%10);
disbuff[2]=(S%10);
DisplayOneChar(9, 0, ASCII[disbuff[0]]);
DisplayOneChar(10, 0, ASCII[10]); //顯示點
DisplayOneChar(11, 0, ASCII[disbuff[1]]);
DisplayOneChar(12, 0, ASCII[disbuff[2]]);
DisplayOneChar(13, 0, ASCII[12]); //顯示M
//左轉
void comeleft()
IN1=0;
IN2=1;
IN3=1;
IN4=1;
//右轉
void comeright ()
IN1=1;
IN2=1;
IN3=1;
IN4=0;
//前進加速;
void comeon()
IN1=0;
IN2=1;
IN3=0;
IN4=1;
void stop()
IN1=0;
IN2=0;
IN3=0;
IN4=0;
void backward()
IN1=1;
IN2=0;
IN3=1;
IN4=0;
//紅外尋跡
void Tracking()
if(zuo==1&&zhong==1&&you==1) //0是接受到黑線,1是白線
comeon();
else if(zuo==1&&zhong==0&&you==1)
comeon();
else if(zuo==0&&zhong==1&&you==1)
comeleft();
else if(zuo==0&&zhong==0&&you==1)
comeleft();
else if(zuo==1&&zhong==1&&you==0)
comeright();
else if(zuo==1&&zhong==0&&you==0)
comeright();
stop();
//避障
void shunback()
chaoshengbo();
delay_ms(50);
Tracking();// 避障運行
if(distance1<8) //當超聲波測距距離小于8則
stop(); //小車停止運動
delay_ms(50);
// backward();
// delay_ms(100);
// comeleft();
// delay_ms(60);
TR1=1;
delay_ms(50);
TR1=0;
Tracking();
} //否則小車直走
//主函數
void main(void)
Init(); //初始化
LCMInit(); //LCM初始化
TMOD=0x01;
TH0=0; //定時器1清零
TL0=0; //定時器1清零
ET0=1; //打開外部中斷
EA=1;
succeed_flag=0; //清測量成功標志
displayfun();
chaoshengbo();
shunback(); //循環調用超聲波測距
Tracking();
//外部中斷0,用做判斷回波電平
INTO_() interrupt 0 // 外部中斷是0號
succeed_flag=1; //至成功測量的標志
#ifndef __lcd1602__
#define __lcd1602__
//定義引腳
sbit LCM_RS = P2^6;
sbit LCM_RW = P2^5;
sbit LCM_E = P2^7;
//數據口定義
#define LCM_Data P0
sbit BF=LCM_Data^7; //忙信號線
//數組變量
unsigned char code yuyiny[18]={
0x00,0x10,0x18,0x20,0x28,0x30,0x38,0x40,
0x48,0x50,0x58,0x60,0x68,0x70,0x78,0x80,0x88,0x98};
unsigned char inittime[7]={0x00,0x00,0x12,0x03,0x04,0x06,0x10}; //初始化時間
//變量
#define uchar unsigned char
#define uint unsigned int
函 數 名:unsigned char ReadStatusLCM(void)
功 能:忙檢測
說 明:
入口參數:無
返 回 值:無
bit busy =0;
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 1;
LCM_E = 1;
busy = BF;
LCM_E = 0;
return(busy);
函 數 名:void WriteCommandLCM(unsigned char WCLCM,BuysC)
功 能:寫命令
說 明:
入口參數:WCLCM
BuysC 需要忙檢測
返 回 值:無
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
if (BuysC) ReadStatusLCM(); //根據需要檢測忙
while (ReadStatusLCM());
LCM_RS = 0;
LCM_RW = 0;
LCM_Data = WCLCM;
LCM_E = 1;
LCM_E = 0;
函 數 名:void WriteDataLCM(unsigned char WDLCM
功 能:寫數據
說 明:
入口參數:WDLCM
返 回 值:無
void WriteDataLCM(unsigned char WDLCM)
while(ReadStatusLCM()); //檢測忙
LCM_RS = 1;
LCM_RW = 0;
LCM_Data = WDLCM;
LCM_E = 1;
LCM_E = 0;
函 數 名:void LCMInit(void)
功 能:LCM初始化
說 明:
入口參數:無
返 回 值:無
void LCMInit(void)
WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
WriteCommandLCM(0x0C,1); //顯示開及光標設置
WriteCommandLCM(0x06,1); //顯示光標移動設置
WriteCommandLCM(0x01,1); //顯示清屏
函 數 名:void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
功 能:按指定位置顯示一個字符
說 明:
入口參數:X 一行顯示個數限制
Y 上下行限制
DData 數據
返 回 值:無
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼 0x40;
X |= 0x80; // 算出指令碼
WriteCommandLCM(X, 0); //這里不檢測忙信號,發送地址碼
WriteDataLCM(DData);
函 數 名:void displayfun(void)
功 能:界面顯示
說 明:
入口參數:無
返 回 值:無
WriteCommandLCM(0x0c,1); //顯示屏打開,光標不顯示,不閃爍,檢測忙信號
/*顯示 鬧鐘 設置*/
DisplayOneChar(0,0,'D');
DisplayOneChar(1,0,'i');
DisplayOneChar(2,0,'s');
DisplayOneChar(3,0,'t');
DisplayOneChar(4,0,'a');
DisplayOneChar(5,0,'n');
DisplayOneChar(6,0,'c');
DisplayOneChar(7,0,'e');
DisplayOneChar(8,0,':');
#endif
