親測SD卡讀寫SDIO接口可用。
CPU STM32F103ZET6.
SD卡讀寫-SDIO接口 代碼.7z
(159.08 KB, 下載次數: 35)
2022-11-22 03:08 上傳
點擊文件名下載附件
- /******************** (C) COPYRIGHT 2009 奮斗嵌入式開發工作室 ********************
- * File Name : main.c
- * Author : Sun68
- * Version : V1.0
- * Date : 11/11/2009
- * Description : 演示將一段字符串寫入AT45DB161D的1頁中,然后讀出并通過USART1傳送出去。
- 字符串:SPI AT45DB161D Example: This is SPI DEMO, 終端上出現這一行字,說明AT45DDB161的讀寫正常
- 定義:
- USART1
- TXD1----- PA9-US1-TX
- RXD1----- PA10-US1-RX 速率:115200,n,8,1
- SPI2
- NSS---PB12-SPI2-NSS
- MISO--PB14-SPI2-MISO
- MOSI--PB15-SPI2-MOSI
- SCK---PB13-SPI2-SCK
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x.h"
- #include "platform_config.h"
- #include "stm32f10x_usart.h"
- #include "misc.h"
- extern void SPI_Flash_Init(void);
- extern u8 SPI_Flash_ReadByte(void);
- extern u8 SPI_Flash_SendByte(u8 byte);
- extern void FlashPageEarse(u16 page);
- extern void FlashPageRead(u16 page,u8 *Data);
- extern void FlashPageWrite(u16 page,u8 *Data);
- extern void FlashWaitBusy(void);
- extern void AT45_RomTo_buf(unsigned char buffer,unsigned int page);
- extern u8 AT45_buf_ToRam(unsigned char buffer,unsigned int start_address,unsigned int length);
- extern u8 AT45_RamTo_buf(unsigned char buffer,unsigned int start_address,unsigned int length);
- extern void AT45_buf_ToRom(unsigned char buffer,unsigned int page);
- extern void AT45_page_earse(unsigned int page);
- extern unsigned char AT45_buffer[];
- /** @addtogroup StdPeriph_Examples
- /** @addtogroup USART_Interrupt
- /* Private typedef -----------------------------------------------------------*/
- typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
- /* Private define ------------------------------------------------------------*/
- #define TxBufferSize1 (countof(TxBuffer1) - 1)
- #define RxBufferSize1 (countof(TxBuffer1) - 1)
- /* Private macro -------------------------------------------------------------*/
- #define countof(a) (sizeof(a) / sizeof(*(a)))
- /* Private variables ---------------------------------------------------------*/
- USART_InitTypeDef USART_InitStructure;
- uint8_t TxBuffer1[] = "SPI AT45DB161D Example: This is SPI DEMO, 終端上出現這一行字,說明AT45DDB161的讀寫正常";
- uint8_t RxBuffer1[RxBufferSize1],rec_f;
- __IO uint8_t TxCounter1 = 0x00;
- __IO uint8_t RxCounter1 = 0x00;
- uint8_t NbrOfDataToTransfer1 = TxBufferSize1;
- uint8_t NbrOfDataToRead1 = RxBufferSize1;
- __IO TestStatus TransferStatus1 = FAILED;
- /* Private function prototypes -----------------------------------------------*/
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void NVIC_Configuration(void);
- void Delay(__IO uint32_t nCount);
- void USART_OUT(USART_TypeDef* USARTx, uint8_t *Data,uint16_t Len);
- TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitTypeDef USART_InitStruct;
- USART_ClockInitTypeDef USART_ClockInitStruct;
- int16_t USART_FLAG;
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program
- * @param None
- * @retval : None
- int main(void)
- uint8_t a=0;
- uint16_t i=0;
- /* System Clocks Configuration */
- RCC_Configuration();
- /* NVIC configuration */
- NVIC_Configuration();
- /* Configure the GPIO ports */
- GPIO_Configuration();
- /* USART1 configuration ------------------------------------------------------*/
- /* USART and USART2 configured as follow:
- - BaudRate = 115200 baud
- - Word Length = 8 Bits
- - One Stop Bit
- - No parity
- - Hardware flow control disabled (RTS and CTS signals)
- - Receive and transmit enabled
- USART_InitStructure.USART_BaudRate = 115200;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- /* Configure USART1 */
- USART_Init(USART1, &USART_InitStructure);
- /* Enable USART1 Receive and Transmit interrupts */
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
- USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
- /* Enable the USART1 */
- USART_Cmd(USART1, ENABLE);
- SPI_Flash_Init();
- GPIO_SetBits(GPIOB, GPIO_Pin_5);
- for(i=0; i<TxBufferSize1;i++) AT45_buffer[i]=TxBuffer1[i];
- AT45_RamTo_buf(1,0,TxBufferSize1);
- AT45_buf_ToRom(1,1); //1區to一頁
- AT45_RomTo_buf(1,1); //1頁to1區
- AT45_buf_ToRam(1,0,TxBufferSize1);
- //GPIO_SetBits(GPIOB, GPIO_Pin_5); while(1);
- //GPIO_ResetBits(GPIOB, GPIO_Pin_5);
- a=0;
- for(i=0; i<TxBufferSize1;i++){
- if(AT45_buffer[i]==TxBuffer1[i]) a=1;
- else {a=0; i=TxBufferSize1;}
- if(a==1) USART_OUT(USART1,&AT45_buffer[0],TxBufferSize1);
- while (1)
- void USART_OUT(USART_TypeDef* USARTx, uint8_t *Data,uint16_t Len){
- uint16_t i;
- for(i=0; i<Len; i++){
- USART_SendData(USARTx, Data[i]);
- while(USART_GetFlagStatus(USARTx, USART_FLAG_TC)==RESET);
- for(; nCount != 0; nCount--);
- /* Setup the microcontroller system. Initialize the Embedded Flash Interface,
- initialize the PLL and update the SystemFrequency variable. */
- SystemInit();
- /* Enable USART1, GPIOA, GPIOx and AFIO clocks */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOx
- | RCC_APB2Periph_AFIO, ENABLE);
- /* Enable USART2 clock */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
- * @brief Configures the different GPIO ports.
- * @param None
- * @retval : None
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1 |RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
- RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
- RCC_APB2Periph_GPIOE, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //LED1
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_3; //LED2, LED3
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //LCD 背光控制
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- GPIO_ResetBits(GPIOE, GPIO_Pin_0);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //USART1 TX
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //復用推挽輸出
- GPIO_Init(GPIOA, &GPIO_InitStructure); //A端口
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART1 RX
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //復用開漏輸入
- //GPIO_PinRemapConfig(AFIO_MAPR_USART1_REMAP, ENABLE);
- * @brief Configures the nested vectored interrupt controller.
- * @param None
- * @retval : None
- NVIC_InitTypeDef NVIC_InitStructure;
- /* Configure the NVIC Preemption Priority Bits */
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
- /* Enable the USART1 Interrupt */
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- * @brief Compares two buffers.
- * @param pBuffer1, pBuffer2: buffers to be compared.
- * @param BufferLength: buffer's length
- * @retval : PASSED: pBuffer1 identical to pBuffer2
- * FAILED: pBuffer1 differs from pBuffer2
- while(BufferLength--)
- if(*pBuffer1 != *pBuffer2)
- return FAILED;
- pBuffer1++;
- pBuffer2++;
- return PASSED;
