查看: 3538|回復(fù): 0
幫忙看CS5463程序 是否正確
ID:148777 發(fā)表于 2017-9-16 19:36 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#define uchar unsigned char
#define uint unsigned int
uchar flag,a;
uchar x;uchar y;uchar z;
uchar code table[]="Voltage Current Power";
sbit SD0=P0^1;
sbit INT=P0^0;
sbit SCLK=P0^5;
sbit SDI=P0^3;
sbit CS=P0^4;
sbit RESET=P0^2;
void Delay(uchar k)
  uchar i,j;
  for(i=0;i<k;i++)
  for(j=0;j<100;j++);
void CS5463Init(void)
uchar i;
  RESET=1;Delay(5);
  RESET=0;Delay(5);
  RESET=1;
  SDI=0;
  SCLK=0;
  CS=0;Delay(5);
  SDI=1;
  for(i=0;i<32;i++)
    SCLK=1;Delay(2);
        SCLk=0;Delay(2);
  SDI=0;Delay(2);
  SCLK=1;Delay(2);
  SCLK=0;
void CS5463Write(uchar com,uchar dat1,uchar dat2,uchar dat3)
  uchar o,p,r,q;
        SCLK=0;
        for(o=0;o<8;o++)
          SDI=(bit)(com&0x80);
                SCLK=0;
                Delay(2);
                SCLK=1;
                Delay(2);
                com<<=1;
        for(p=0;p<8;p++)
          SDI=(bit)(dat1&0x80);
                SCLK=0;
                Delay(2);
                SCLK=1;
                Delay(2);
                dat1<<=1;
        for(q=0;q<8;q++)
          SDI=(bit)(dat2&0x80);
                SCLK=0;
                Delay(2);
                SCLK=1;
                Delay(2);
                dat2<<=1;
        for(r=0;r<8;r++)
          SDI=(bit)(dat3&0x80);
                SCLK=0;
                Delay(2);
                SCLK=1;
                Delay(2);
                dat3<<=1;
uchar CS5463Read(uchar coml,uchar x,uchar y,uchar z)
uchar s,t,u,v,f=0xfe,g=0xfe,h=0xfe;
        SCLK=0;
        for(s=0;s<8;s++)
          SDI=(bit)(coml&0x80);
                SCLK=0;
                Delay(2);
                SCLK=1;
                Delay(2);
                coml<<=1;
        for(t=0;t<8;t++)
          SDI=(bit)(f&0x80);
                SCLK=0;
                Delay(2);
                SCLK=1;
                Delay(2);
                f<<=1;x<<=1;
                x|=(uchar)SD0;
        return (x);
        for(u=0;u<8;u++)
          SDI=(bit)(g&0x80);
                SCLK=0;
                Delay(2);
                SCLK=1;
                Delay(2);
                g<<=1;y<<=1;
                y|=(uchar)SD0;
        return (y);
        for(v=0;v<8;v++)
         SDI=(bit)(h&0x80);
                SCLK=0;
                Delay(2);
                SCLK=1;
                Delay(2);
                h<<=1;z<<=1;
                z|=(uchar)SD0;
        return (z);
void ComInit()
  TMOD=0x20;
        TH1=0xfd;
        TL1=0xfd;
        SM0=0;
        SM1=1;
        TR1=1;
        REN=1;
        EA=1;
        ES=1;
void send(uchar m,uchar b)
  uchar l;
        if(flag==1)
          ES=0;flag=0;
                for(l=0;l<m;l++)
                  SBUF=TAB[1];
                        while(!TI);
                        Ti=0;
                SUBF=b;
                while(!TI);
                TI=0;
                SBUF=a;
                while(!TI);
                TI=0;
                ES=1;
        ComInit();
    CS5463Init();
        CS5463Write(0x5e,0x80,0x00,0x00);
        CS5463Write(0x40,0x00,0x00,0x01);
        CS5463Write(0x4a,0x00,0x0f,0xa0);
        CS5463Write(0x74,0x00,0x00,0x00);
        CS5463Write(0x64,0x80,0x00,0x01);
        CS5463Read(0xe8,x,y,z);
        CS5463Read(0x10,x,y,z);
        send(22,z);
        send(22,y);
        send(22,z);
void Srei() interrupt 4
  RI=0;
  P1=SBUF;
  a=SBUF;
  flag=1;
主站蜘蛛池模板: 国产xxxx视频| 欧美又大又硬又粗bbbbb | 中国毛片视频 | 国产福利视频在线 | 中文字字幕在线 | 欧美日韩一区二区三区视频 | 午夜精品影院 | 国产精品日韩在线 | 欧美亚洲一区二区三区 | 欧美一级淫片免费视频黄 | 色中色综合 | 国产精品福利在线 | av免费播放 | 情侣av| 在线观看免费黄色 | 成人免费看片视频 | 狠狠躁夜夜躁人爽 | 日韩视频在线免费观看 | 黄色录像免费看 | 户外少妇对白啪啪野战 | 久久久精品一区 | 国产精品久久午夜夜伦鲁鲁 | 黑人巨大猛烈捣出白浆 | 在线午夜视频 | 国产精品美女在线 | 精品亚洲国产成人av制服丝袜 | 免费一级片 | 黄色特级毛片 | 国产一级片免费观看 | 伊人久久综合 | 日本黄色免费网站 | 欧美一区二区三区在线视频 | 深夜福利网站 | 亚洲午夜在线观看 | 国产天堂在线 | 免费在线看a | 国产精品免费在线播放 | 成人毛片在线播放 | 久久久久久中文字幕 | 一级片在线视频 | 美女黄色一级片 |
