查看: 6303|回復: 2
TM1638資料(.c文件和頭文件)
ID:234748 發表于 2017-9-21 21:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//-------------------------------------------------------------------------------TM1638.c-------------------------------------------------------------------
#include "TM1638.h"
#include "stdint.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
const uint8_t tab2[] = {0x3F,0x06,0x5B,0x4F,
                        0x66,0x6D,0x7D,0x07,
                        0x7F,0x6F,0x77,0x7C,
                        0x39,0x5E,0x79,0x71};
#define ADD 10
#define MINUS 11
#define EQUAL 12
#define CLEAR 13
#define PLUS 14
#define DIVIDE 15
unsigned int flag;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void TM1638_Write(unsigned char DATA)   //寫數據函數
unsigned char i;
DIO_OUT;
for(i=0;i<8;i++)
   CLK_low;
   if(DATA & 0x01){
    DIO_high;
   }else{
    DIO_low;
   CLK_high;
   DATA>>=1;
unsigned char TM1638_Read(void)     //讀數據函數
unsigned char i;
unsigned char temp=0;
DIO_IN;
STB_low;
for(i=0;i<8;i++)
    temp>>=1;
    CLK_low;
    _delay_us(100);
    if(DIO_READ)
     temp |= 0x80;
     temp &= 0x7f;
    CLK_high;
return temp;
void Write_COM(unsigned char cmd)  //發送命令字
CLK_high;
STB_high;
STB_low;
TM1638_Write(cmd);
STB_high;
*函數功能:讀取按鍵值
*輸入參數:無
*輸出參數:無
*返回值:  無
unsigned char Read_key(void)
unsigned char c[4];
unsigned int key_value=0x00;
unsigned int i;
STB_high;
STB_low;
TM1638_Write(0x42);
_delay_us(1);
for(i=0;i<4;i++)
  c[i]=TM1638_Read();
STB_high;
if(c[0]&BIT2)
  key_value |= BIT1;
else if(c[0]&BIT6)
  key_value |= BIT4;
else if(c[0]&BIT0)
  key_value |= BIT2;
else if(c[0]&BIT1)
  key_value |= BIT3;
else if(c[0]&BIT5)
  key_value |= BIT6;
else if(c[0]&BIT4)
  key_value |= BIT5;
else if(c[1]&BIT0)
  key_value |= BITB;
else if(c[1]&BIT4)
  key_value |= BITC;
else if(c[1]&BIT1)
  key_value |= BITA;
else if(c[2]&BIT0)
  key_value |= BITD;
else if(c[2]&BIT4)
  key_value |= BIT8;
else if(c[2]&BIT5)
  key_value |= BIT9;
else if(c[2]&BIT6)
  key_value |= BIT7;
else if(c[3]&BIT0)
  key_value |= BITF;
else if(c[3]&BIT1)
  key_value |= BITE;
else if(c[3]&BIT2)
  key_value |= BIT0;
//特殊符號‘AC’ ‘+’ ‘-’ ‘=’
else if(c[1]&BIT2)
     flag<=CLEAR;
  Write_allLED(0);//按下AC,清除所有顯示
else if(c[1]&BIT6)
  flag<=ADD;//按下+,清除所有顯示
else if(c[2]&BIT1)
  flag<=EQUAL;//按下=,清除所有顯示
else if(c[2]&BIT2)
     flag<=MINUS;//按下-,清除所有顯示
for(i=0;i<16;i++)
  if((0x01<<i)==key_value)
   break;
return i;
void Write_DATA(unsigned char add,unsigned char DATA)  //指定地址寫入數據
Write_COM(0x44);
STB_low;
TM1638_Write(0xc0|add);
TM1638_Write(DATA);
STB_high;
void init_TM1638(void)
Write_allLED(0xff);
_delay_ms(100);
Write_allLED(0);
void  Write_allLED(unsigned char DATA){
unsigned char i;
Write_COM(0x8F);//顯示控制
Write_COM(0x40); //數據命令
STB_low;
TM1638_Write(0xc0);
for(i=0;i<16;i++)
    TM1638_Write(DATA);
STB_high;
//---------------------------------------------------------------------------TM1638.h------------------------------------------------------------------------------
#ifndef _TM1638_H
#define _TM1638_H
#include "msp430f6638.h"
#include <stdint.h>
#define CPU_F ((double)20000000)
#define _delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define _delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define DIO_high (P3OUT |= BIT5)
#define DIO_low  (P3OUT &= ~BIT5)
#define CLK_high (P3OUT |= BIT4)
#define CLK_low  (P3OUT &= ~BIT4)
#define STB_high (P3OUT |= BIT2)
#define STB_low  (P3OUT &= ~BIT2)
#define DIO_IN   (P3DIR &= ~BIT5) //輸入狀態
#define DIO_OUT   (P3DIR |= BIT5)  //輸出狀態
#define DIO_READ  (P3IN & BIT5)   //讀引腳電平
void TM1638_Write(unsigned char DATA);   //寫數據函數
unsigned char TM1638_Read(void);         //讀數據函數
void Write_COM(unsigned char cmd);       //發送命令字
unsigned char Read_key(void);
void Write_DATA(unsigned char add,unsigned char DATA);  //指定地址寫入數據
void Write_allLED(unsigned char flag);     //控制全部LED函數,flag表示LED狀態
void init_TM1638(void);
#endif
收藏收藏2 分享淘帖 頂 踩
ID:585335 發表于 2019-7-16 20:01 | 只看該作者
好像不行啊
按鍵有問題
主站蜘蛛池模板: 青青伊人网 | 日韩三级中文字幕 | 亚洲在线一区二区 | 欧美一级特黄视频 | 日韩精品视频免费播放 | 免费国产网站 | 国产精品高潮呻吟 | www.草 | 国产欧美精品一区二区 | 中文字幕在线免费播放 | 在线观看av免费 | 欧美日韩在线一区二区三区 | 天天视频国产 | 欧美一区二区在线播放 | 国产区一区二区 | 国产黄色免费看 | 成年人毛片| 十八岁毛片 | 久久精品视频一区 | 亚洲精品日韩精品 | 欧美日韩精品一区二区在线播放 | 亚洲精品久久久 | 欧美一区二区在线 | 欧美午夜精品 | 午夜视频在线免费观看 | 国产日韩精品在线 | 一级毛片久久久 | 久久久久久久久久国产 | 国产高清视频 | 亚洲精品色图 | 亚洲欧美乱综合图片区小说区 | 青草av在线| 亚洲一区在线播放 | 亚洲精品观看 | 欧美美女性生活 | 婷婷综合| 看国产毛片| 精品国产一区二 | 亚洲精选一区 | 午夜网 | 国产在线欧美 |
