單片機(jī)源程序如下:
- #include <reg51.h>
- #include <intrins.h>
- typedef unsigned char uchar;
- typedef unsigned int uint;
- sbit DAT = P0^2;
- sbit CLK = P0^1;
- void Delay_1ms(uint x)
- uint i;
- uchar j;
- for(i = 0; i < x; i++) for(j = 0; j <= 148; j++);
- //名稱: Keyscan()
- //功能: P1外接4×4按鍵, 用掃描法讀出鍵值
- //返回: 按鍵值0~15/如無鍵按下, 返回16
- uchar Keyscan(void)
- uchar i, j, temp;
- uchar Buffer[4] = {0xef, 0xdf, 0xbf, 0x7f};
- for(j = 0; j < 4; j++)//循環(huán)四次
- P1 = Buffer[j]; //在P1高四位分別輸出一個(gè)低電平
- temp = 0x01; //計(jì)劃先判斷P1.0位
- for(i = 0; i < 4; i++) //循環(huán)四次
- if(!(P1 & temp)) //從P1低四位,截取1位
- return (i + j * 4); //返回取得的按鍵值
- temp <<= 1; //判斷的位,左移一位
- return 16; //判斷結(jié)束,沒有鍵按下,返回16
- } //呵呵,實(shí)質(zhì)性的語句不過8行,就是這么簡練!
- // 功能: 經(jīng)由 P0 驅(qū)動(dòng) 164,再使得共陽數(shù)碼管顯示 0~F
- //參數(shù): k (鍵盤數(shù)值)
- void Display(uchar k)
- uchar code table[16] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xd8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; //共陽段碼
- uchar i, j;
- j = table[k]; //取出段碼
- for(i = 0; i < 8; i++)
- DAT = j & 0x01; //低位在前
- CLK = 0;
- Delay_1ms(1);
- CLK = 1;
- j >>= 1;
- void Main(void)
- uchar Key_Value = 16, Key_Temp1, Key_Temp2;//兩次讀出的鍵值
- P0 = 0xff;
- while(1)
- //---------以下讀入按鍵、消抖、等待按鍵釋放
- P1 = 0xff;
- Key_Temp1 = Keyscan(); //先讀入按鍵
- if(Key_Temp1 != 16)
- { //如果有鍵按下
- Delay_1ms(10); //延時(shí)一下
- Key_Temp2 = Keyscan(); //再讀一次按鍵
- if (Key_Temp1 == Key_Temp2)
- { //必須是兩次相等
- Key_Value = Key_Temp1; //才保存,這就是消除抖動(dòng)
- Display(Key_Value); //顯示鍵值
兩種4X4按鍵掃描.rar
(113.67 KB, 下載次數(shù): 9)
2017-9-24 14:19 上傳
點(diǎn)擊文件名下載附件
掃描法簡易代碼
