之前自己用這個模塊的時候也找了很多了歷程來測試,但是都是沒有通過,最后得出的結論是spi通信的問題,,自己也懶得去找問題,,所以就擱置了現在把調試通過的程序拿來分享給大家,可以讀卡的,其他功能需要自己開發哦
- #include "lpcreg.h"
- #include "main.h"
- #include "mfrc522.h"
- #include <STDIO.H>
- #include <string.h>
- unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
- //M1卡的某一塊寫為如下格式,則該塊為錢包,可接收扣款和充值命令
- //4字節金額(低字節在前)+4字節金額取反+4字節金額+1字節塊地址+1字節塊地址取反+1字節塊地址+1字節塊地址取反
- unsigned char code data2[4] = {0,0,0,0x01};
- unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
- unsigned char g_ucTempbuf[20];
- void delay1(unsigned int z)
- unsigned int x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void main( )
- unsigned char status,i;
- unsigned int temp;
- InitializeSystem( );
- PcdReset();
- PcdAntennaOff();
- PcdAntennaOn();
- while (1)
- status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
- if (status != MI_OK)
- PcdReset();
- PcdAntennaOff();
- PcdAntennaOn();
- continue;
- printf("讀出的卡的類型:");
- for(i=0;i<2;i++)
- temp=g_ucTempbuf[i];
- printf("%X",temp);
- status = PcdAnticoll(g_ucTempbuf);//防沖撞
- { continue; }
- ////////以下為超級終端打印出的內容////////////////////////
- printf("卡序列號:"); //超級終端顯示,
- for(i=0;i<4;i++)
- status = PcdSelect(g_ucTempbuf);//選定卡片
- { continue; }
- status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
- { continue; }
- status = PcdWrite(1, data1);//寫塊
- { continue; }
- while(1)
- PcdReset();
- PcdAntennaOff();
- PcdAntennaOn();
- continue;
- { continue; }
- { continue; }
- { continue; }
- status = PcdValue(PICC_DECREMENT,1,data2);//扣款
- { continue; }
- status = PcdBakValue(1, 2);//塊備份
- { continue; }
- status = PcdRead(2, g_ucTempbuf);//讀塊
- { continue; }
- printf("此卡的讀塊:"); //超級終端顯示,
- for(i=0;i<16;i++)
- printf("\n");
- LED_GREEN = 0;
- delay1(100);
- LED_GREEN = 1;
- delay1(100);
- LED_GREEN = 0;
- delay1(200);
- LED_GREEN = 1;
- PcdHalt();
- //系統初始化
- void InitializeSystem()
- P0M1 = 0x0; P0M2 = 0x0;
- P1M1 = 0x0; P1M2 = 0x0;
- P3M1 = 0x0; P3M2 = 0xFF;
- P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;P2 = 0xFF;
- TMOD=0x21; //設T0為方式1,GATE=1;
- SCON=0x50;
- TH1=0xFD; //波特率為4800bps
- TL1=0xFD;
- // TH1=0XE0; //9600
測試通過程序.zip
(95.54 KB, 下載次數: 170)
2017-9-27 18:33 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
