查看: 3543|回復: 0
Blink a Led on F28379D
ID:237562 發表于 2017-10-7 04:14 | 顯示全部樓層 |閱讀模式
// FILE:   Lab2_cpu01.c
//File extracted from Texas one day workshop 379D
#include "F28x_Project.h"     // Device Header File and Examples Include File
// Function Prototypes
void ConfigureADC(void);
void ConfigureEPWM(void);
void ConfigureDAC(void);
void SetupADCEpwm(void);
interrupt void adca1_isr(void);
// Variables
#define RESULTS_BUFFER_SIZE 256
Uint16 AdcaResults[RESULTS_BUFFER_SIZE];
Uint16 resultsIndex;
Uint16 ToggleCount = 0;
Uint16 dacOffset;
Uint16 dacOutput;
Uint16 sineEnable = 0;
extern int QuadratureTable[40];
void main(void)
        // Initialize System Control
    InitSysCtrl();
    EALLOW;
    ClkCfgRegs.PERCLKDIVSEL.bit.EPWMCLKDIV = 1;
    EDIS;
    // Initialize GPIO
    InitGpio();                                                         // Configure default GPIO
    EALLOW;
    GpioCtrlRegs.GPADIR.bit.GPIO18 = 1;                // Used as input to ADC
    GpioCtrlRegs.GPADIR.bit.GPIO31 = 1;                // Drives LED LD2 on controlCARD
    EDIS;
    GpioDataRegs.GPADAT.bit.GPIO18 = 0;         // Force GPIO18 output LOW
    GpioDataRegs.GPADAT.bit.GPIO31 = 1;                // Turn off LED
    // Clear all interrupts and initialize PIE vector table
    DINT;
    InitPieCtrl();
    IER = 0x0000;
    IFR = 0x0000;
    InitPieVectTable();
    // Map ISR functions
    EALLOW;
    PieVectTable.ADCA1_INT = &adca1_isr;         // Function for ADCA interrupt 1
    EDIS;
    // Configure the ADC and power it up
    ConfigureADC();
    // Configure the ePWM
    ConfigureEPWM();
    // Configure DAC-B
    ConfigureDAC();
    // Setup the ADC for ePWM triggered conversions on channel 0
    SetupADCEpwm();
    // Initialize results buffer
    for(resultsIndex = 0; resultsIndex < RESULTS_BUFFER_SIZE; resultsIndex++)
            AdcaResults[resultsIndex] = 0;
    resultsIndex = 0;
    // Enable PIE interrupt
    PieCtrlRegs.PIEIER1.bit.INTx1 = 1;
    // Enable global interrupts and higher priority real-time debug events
    IER |= M_INT1;                         // Enable group 1 interrupts
    EINT;                                          // Enable Global interrupt INTM
    ERTM;                                          // Enable Global real-time interrupt DBGM
    // Sync ePWM
    EALLOW;
    CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1;
    EDIS;
    // Start ePWM
    EPwm2Regs.TBCTL.bit.CTRMODE = 0;                         // Un-freeze and enter up-count mode
    do {
              GpioDataRegs.GPADAT.bit.GPIO31 = 0;                // Turn on LED
              DELAY_US(1000 * 500);                                        // ON delay
              DELAY_US(1000 * 500);                                        // OFF delay
    } while(1);
// Write ADC configurations and power up the ADC for both ADC A and ADC B
        EALLOW;
        AdcaRegs.ADCCTL2.bit.PRESCALE = 6;                         // Set ADCCLK divider to /4
        AdcaRegs.ADCCTL2.bit.RESOLUTION = 0;                 // 12-bit resolution
        AdcaRegs.ADCCTL2.bit.SIGNALMODE = 0;                 // Single-ended channel conversions (12-bit mode only)
        AdcaRegs.ADCCTL1.bit.INTPULSEPOS = 1;                // Set pulse positions to late
        AdcaRegs.ADCCTL1.bit.ADCPWDNZ = 1;                        // Power up the ADC
        DELAY_US(1000);        // Delay for 1ms to allow ADC time to power up
        EDIS;
        EALLOW;
        // Assumes ePWM clock is already enabled
        EPwm2Regs.TBCTL.bit.CTRMODE = 3;            // Freeze counter
        EPwm2Regs.TBCTL.bit.HSPCLKDIV = 0;                        // TBCLK pre-scaler = /1
        EPwm2Regs.TBPRD = 0x07D0;                                // Set period to 2000 counts (50kHz)
        EPwm2Regs.ETSEL.bit.SOCAEN        = 0;                // Disable SOC on A group
        EPwm2Regs.ETSEL.bit.SOCASEL        = 2;                // Select SOCA on period match
    EPwm2Regs.ETSEL.bit.SOCAEN = 1;                         // Enable SOCA
        EPwm2Regs.ETPS.bit.SOCAPRD = 1;                        // Generate pulse on 1st event
        EDIS;
    EALLOW;
    DacbRegs.DACCTL.bit.DACREFSEL = 1;                        // Use ADC references
    DacbRegs.DACCTL.bit.LOADMODE = 0;                        // Load on next SYSCLK
    DacbRegs.DACVALS.all = 0x0800;                                // Set mid-range
    DacbRegs.DACOUTEN.bit.DACOUTEN = 1;                        // Enable DAC
    EDIS;
        EALLOW;
        AdcaRegs.ADCSOC0CTL.bit.CHSEL = 0;                  // SOC0 will convert pin A0
        AdcaRegs.ADCSOC0CTL.bit.ACQPS = 14;                 // Sample window is 100 SYSCLK cycles
        AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = 7;                 // Trigger on ePWM2 SOCA/C
        AdcaRegs.ADCINTSEL1N2.bit.INT1SEL = 0;                 // End of SOC0 will set INT1 flag
        AdcaRegs.ADCINTSEL1N2.bit.INT1E = 1;                   // Enable INT1 flag
        AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1;                 // Make sure INT1 flag is cleared
        EDIS;
        // Read the ADC result and store in circular buffer
        AdcaResults[resultsIndex++] = AdcaResultRegs.ADCRESULT0;
        if(RESULTS_BUFFER_SIZE <= resultsIndex)
                resultsIndex = 0;
        // Toggle GPIO18 so we can read it with the ADC
        if (ToggleCount++ >= 15)
                GpioDataRegs.GPATOGGLE.bit.GPIO18 = 1;
                ToggleCount = 0;
        // Write to DACB to create input to ADC-A0
        if (sineEnable != 0)
                dacOutput = dacOffset + ((QuadratureTable[resultsIndex % 0x20] ^ 0x8000) >> 5);
                dacOutput = dacOffset;
        DacbRegs.DACVALS.all = dacOutput;
        // Return from interrupt
        AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1;                 // Clear ADC INT1 flag
        PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;                // Acknowledge PIE group 1 to enable further interrupts
// end of file
主站蜘蛛池模板: 日本成人黄色 | 日韩专区在线 | 毛片在线视频 | 欧美激情视频一区 | 亚洲欧美中文字幕 | 久热久草| 日本免费观看视频 | 国产日韩欧美在线观看 | 久久精品国产免费 | 99av| 97人人艹| 午夜视频在线免费观看 | 国产综合视频 | 国产日韩欧美日韩大片 | 91精品在线播放 | 欧美在线观看一区 | 免费三级网站 | 成人免费看片39 | 久久久久国产视频 | 欧美三级韩国三级日本三斤在线观看 | 日本中文字幕在线播放 | 美女免费网站 | 欧美一级视频在线观看 | 国产一区在线看 | 国产成人小视频 | 久久久一 | 免费在线观看av | 在线中文字幕 | 久草视频观看 | 亚洲综合区| 视频一区在线观看 | 欧美日韩一区二区三区视频 | 亚洲乱码在线观看 | 国产黄色片在线观看 | 网站av| 一级国产片 | 国产永久精品 | 日韩精品一区在线 | 欧美精品系列 | 亚洲激情一区二区 | 天天爽夜夜操 |
