利用GPS北斗ATGM336H-5N模塊輸出的原始定位信息,發到單片機后進行處理,提取有用的信息如經緯度、速度、海拔、日期等,通過串口發到電腦的串口調試助手進行顯示,并顯示到LCD屏幕。
程序的功能有GPS信息顯示與發送(LCD顯示經緯度、海拔、速度,電腦串口接收時間、日期、經緯度、海拔、速度數據)
GPS原始數據捕獲(從一開始通電時不完整到過一會后完整)見附件
GPS原始數據捕獲與簡單分析:
$GNGGA,120726.000,3208.0858,N,11841.7828,E,1,05,4.3,12.7,M,0.0,M,,*40
$GNGLL,3208.0858,N,11841.7828,E,120726.000,A,A*43
$GPGSA,A,3,12,25,,,,,,,,,,,6.9,4.3,5.4*3F
$BDGSA,A,3,10,04,07,,,,,,,,,,6.9,4.3,5.4*28
$GPGSV,3,1,12,04,,,21,10,66,313,,12,42,100,34,14,21,289,*49
$GPGSV,3,2,12,15,18,086,,18,79,174,27,20,13,143,24,21,18,203,*73
$GPGSV,3,3,12,24,40,042,,25,37,150,31,31,10,230,,32,33,301,*7A
$BDGSV,1,1,04,03,,,35,04,32,122,34,07,54,184,34,10,33,200,36*50
$GNRMC,120726.000,A,3208.0858,N,11841.7828,E,0.11,303.11,031017,,,A*70
$GNVTG,303.11,T,,M,0.11,N,0.20,K,A*21
$GNZDA,120726.000,03,10,2017,00,00*4E
$GPTXT,01,01,01,ANTENNA OK*35
原始數據中逗號數量和順序的統計:
1 2 3 4 5 6 7 8 9 a b c d
$GNGGA,034214.000,3208.1201,N,11841.7167,E,1,07,1.7,7.7,M,0.0,M,,*7 OK*
1 2 3 4 5 6 7 8 9 abc
$GNRMC,034214.000,A,3208.1201,N,11841.7167,E,2.71,336.76,041017,,,A*700
GPS原始數據及處理后的數據
(見附件)
- 單片機的RXD端口接收來自GPS模塊的數據,把數據進行處理,并顯示到Lcd上,同時
- 通過TXD端口經過USB-TTL模塊發送到電腦的串口調試軟件上顯示。
- 注意事項:
- 1、串口調試軟件的波特率要設為9600;
- 2、單片機與USB-TTL模塊兩者要共地!!!(我也不知為什么,攤手.jpg)
- #include "reg52.h"
- #include "main.h"
- #include "LCD1602.h"
- #include "GPS.h"
- unsigned char xdata Display_GPGGA_Buffer[68]={0}; //用于儲存GPGGA的數據
- unsigned char xdata Display_GPRMC_Buffer[68]={0}; //用于儲存GPRMC的數據
- unsigned int k=0,qian_a=0,hou_a=0,qian_b=0,hou_b=0,qian_c=0,hou_c=0; //存儲前后逗號的位置序號的變量
- bit qian_OK=0; //已找出前面的逗號的標志變量
- bit First_Share_OK=0; //已開始LCD顯示的標志變量
- bit jiajian=1; //進行加或減的標志變量
- //bit Page = 0;
- bit Flag_OV = 0; //日期需進位的標志變量
- bit Flag_Calc_GPGGA_OK = 0; //GPGGA完整有效的數據已收到的標志變量
- bit Flag_Calc_GPRMC_OK = 0; //GPRMC完整有效的數據已收到的標志變量
- //主函數
- void main()
- unsigned int i = 0;
- unsigned int j=0;
- Init_LCD1602(); //LCD初始化
- LCD1602_write_com(0x80); //LCD指針設置到第一行第一列
- LCD1602_write_word("Searching data. "); //顯示正在搜索數據
- Uart_Init(); //串口初始化
- while(1)
- // Scan_Key();
- qian_OK=0; //標志變量歸零
- k=0; //累計量歸零
- if (First_Share_OK==0) //讓變量j在0~10000之間來回增減,增加到10000時顯示". ",減到0時顯示" .",實現兩點來回閃動
- if (jiajian==1)
- j++;
- if (j==10000)
- jiajian=0;
- LCD1602_write_com(0x8e);
- LCD1602_write_data('.');
- LCD1602_write_com(0x8f);
- LCD1602_write_data(' ');
- else
- j--;
- if (j==0)
- jiajian=1;
- //代碼詳見附件
- // UartPrintf("----------------------------------------------\r\n");
- // UartPrintf(RX_Buffer);
- // UartPrintf("\r\n");
- if ( Flag_GPS_OK == 1
- && RX_Buffer[1] == 'G'
- && RX_Buffer[3] == 'G'
- && RX_Buffer[4] == 'G'
- && RX_Buffer[5] == 'A'
- && (RX_Buffer[28] == 'N'|| RX_Buffer[28] == 'S')
- && (RX_Buffer[41] == 'E'|| RX_Buffer[41] == 'W') ) //確認是否收到"GPGGA"這一幀完整有效的數據
- for( i = 0; i < 67 ; i++) //必須為i<67,因為要確保Display_GPGGA_Buffer[67]為'\0',便于串口發送
- Display_GPGGA_Buffer[i] = RX_Buffer[i]; //儲存到數組中
- Flag_Calc_GPGGA_OK = 1; //收到完整有效數據后,置為1
- if(Flag_Calc_GPGGA_OK == 1) //已收到完整有效的數據,可以進行顯示,
- Flag_Calc_GPGGA_OK = 0; //標志位歸零
- if (First_Share_OK == 0)
- First_Share_OK=1; //"Searching data. "不需再顯示,標志變量置為1
- LCD1602_write_com(0x01); //先清屏
- LCD1602_write_data(Display_GPGGA_Buffer[28]); //顯示 N 或者 S
- LCD1602_write_word(": ");
- LCD1602_write_data(Display_GPGGA_Buffer[18]); //緯度
- LCD1602_write_data(Display_GPGGA_Buffer[19]);
- LCD1602_write_data(0xdf); //度符號的ASCII碼,16進制
- LCD1602_write_data(Display_GPGGA_Buffer[20]); //緯度
- LCD1602_write_data(Display_GPGGA_Buffer[21]);
- LCD1602_write_word("'"); //秒
- for (i=0;i<68;i++) //由于海拔有時是1位數有時是2位數有時是3位數,不定
- { //而確定的是其數值在第9與第10個逗號之間,所以用此算法輸出海拔
- if ( Display_GPGGA_Buffer[i]==',' ) //逐個檢索
- k++; //k計算逗號數量
- if (k==9&&qian_OK==0)
- qian_a=i,qian_OK=1; //找到第9個,則記錄其序號,同時標志變量置為1
- if (k==10) //海拔數據位于第9~10個逗號之間
- hou_a=i; //記錄第10個的序號
- k=0; //歸零
- qian_OK=0; //重置為0
- break; //找到后直接跳出循環
- LCD1602_write_com(0x89); //準備在第一行第9列輸出海拔數據
- switch(hou_a-qian_a-1) //計算海拔數據的長度
- case 3:LCD1602_write_word(" ");break; //根據海拔數據長度輸出對應所需的空格數,使其顯示方式為右對齊
- case 4:LCD1602_write_word(" ");break;
- case 5:LCD1602_write_word(" ");break;
- case 6:break;
- case 7:break;
- for (i=qian_a+1; i<=hou_a-1; i++)
- LCD1602_write_data(Display_GPGGA_Buffer[i]); //輸出海拔
- LCD1602_write_data('m'); //顯示單位
- LCD1602_write_com(0xc0); //在第2行第1列開始輸出經度
- LCD1602_write_data(Display_GPGGA_Buffer[41]); //輸出E 或者 W
- LCD1602_write_data(':');
- LCD1602_write_data(Display_GPGGA_Buffer[30]); //經度
- LCD1602_write_data(Display_GPGGA_Buffer[31]);
- LCD1602_write_data(Display_GPGGA_Buffer[32]);
- LCD1602_write_data(Display_GPGGA_Buffer[33]);
- LCD1602_write_data(Display_GPGGA_Buffer[34]);
- UartPrintf("----------------------------------------------\r\n"); //串口發送數據到電腦
- UartPrintf("Original data(1):\r\n");
- UartPrintf(Display_GPGGA_Buffer); //直接把首地址作為實參
- UartPrintf("......\r\n");
- UartPrintf("Processed data(1): \r\n");
- UartPrintData(Display_GPGGA_Buffer[28]); //N 或者 S
- UartPrintf(": ");
- UartPrintData(Display_GPGGA_Buffer[18]); //發送緯度
- UartPrintData(Display_GPGGA_Buffer[19]);
- UartPrintData('*'); //串口無法發送擴展的ASCII碼(大于127),所以用*代替度數符號
- UartPrintData(Display_GPGGA_Buffer[20]);
- UartPrintData(Display_GPGGA_Buffer[21]);
- UartPrintData('\'');
- UartPrintf("\r\n"); //發送回車換行
- UartPrintData(Display_GPGGA_Buffer[41]); //E 或者 W
- UartPrintf(": ");
- UartPrintData(Display_GPGGA_Buffer[30]);
- UartPrintData(Display_GPGGA_Buffer[31]);
- UartPrintData(Display_GPGGA_Buffer[32]);
- UartPrintData(Display_GPGGA_Buffer[33]); //發送經度
- UartPrintData(Display_GPGGA_Buffer[34]);
- UartPrintf("Altitude: ");
- for (i=qian_a+1; i<=hou_a-1; i++) //發送海拔
- UartPrintData(Display_GPGGA_Buffer[i]);
- UartPrintf(" m");
- // 這部分代碼詳見附件
- && RX_Buffer[1] == 'G'&& RX_Buffer[3] == 'R'&& RX_Buffer[4] == 'M'&& RX_Buffer[5] == 'C')
- if( Flag_GPS_OK == 1
- && RX_Buffer[3] == 'R'
- && RX_Buffer[4] == 'M'
- && RX_Buffer[5] == 'C'
- && RX_Buffer[18]== 'A') //確認是否收到"GPRMC"這一幀完整有效的數據
- Display_GPRMC_Buffer[i] = RX_Buffer[i];
- Flag_Calc_GPRMC_OK = 1;
- Hour = (Display_GPRMC_Buffer[7]-0x30)*10+(Display_GPRMC_Buffer[8]-0x30)+8; //UTC時間轉換到北京時間(東八區),0x30即48
- if( Hour >= 24) //如果溢出
- Hour %= 24; //獲取實際Hour
- Flag_OV = 1; //日期進位的標志變量置為1
- else
- Flag_OV = 0;
- Min_High = Display_GPRMC_Buffer[9];
- Min_Low = Display_GPRMC_Buffer[10]; //獲取時間數據
- Sec_High = Display_GPRMC_Buffer[11];
- Sec_Low = Display_GPRMC_Buffer[12];
- for (i=0;i<68;i++) //由于日期數據前面的速度數據也是位數不定,所以速度數據位數也不定,故亦用此算法精確地確定日期數據位置
- if ( Display_GPRMC_Buffer[i]==',' )
- k++;
- if (k==9&&qian_OK==0) //日期數據位于第9~10個逗號之間
- qian_b=i,qian_OK=1;
- if (k==10)
- hou_b=i;
- k=0;
- qian_OK=0;
- break;
- Year_High = Display_GPRMC_Buffer[qian_b+5]; //獲取日期
- Year_Low = Display_GPRMC_Buffer[qian_b+6];
- Month_High = Display_GPRMC_Buffer[qian_b+3];
- Month_Low = Display_GPRMC_Buffer[qian_b+4];
- Day_High = Display_GPRMC_Buffer[qian_b+1];
- Day_Low = Display_GPRMC_Buffer[qian_b+2];
- if(Flag_OV == 1) //如果日期須進位
- UTCDate2LocalDate(); //UTC日期進位并轉換為北京時間
- if(Flag_Calc_GPRMC_OK == 1) //GPRMC數據完整有效則顯示
- Flag_Calc_GPRMC_OK = 0;
- First_Share_OK=1;
- for (i=0;i<68;i++) //由于速度數據也是位數不定,故亦用此算法精確地確定速度數據位置
- k++;
- if (k==7&&qian_OK==0) //速度數據位于第7~8個逗號之間
- qian_c=i,qian_OK=1;
- if (k==8)
- hou_c=i;
- k=0;
- qian_OK=0;
- break;
- LCD1602_write_com(0xc9); //準備在第2行第9列顯示
- switch(hou_c-qian_c-2) //原式為(hou_c-1)-qian_c-1。由于速度不太準還浮動,故只讓它顯示一位小數
- case 3:LCD1602_write_word(" ");break; //使右對齊
- case 4:break;
- case 5:break;
- for (i=qian_c+1; i<=hou_c-2; i++) //(原式為hou_c-1-1)
- LCD1602_write_data(Display_GPRMC_Buffer[i]); //顯示速度
- LCD1602_write_word("m/s"); //顯示單位
- UartPrintf("Original data(2):\r\n");
- UartPrintf(Display_GPRMC_Buffer);
- UartPrintf("Processed data(2): \r\n");
- UartPrintf("Time: ");
- UartPrintData(Hour/10+0x30); //串口發送時間
- UartPrintData(Hour%10+0x30);
- UartPrintData(':');
- UartPrintData(Min_High);
- UartPrintData(Min_Low);
- UartPrintData(Sec_High);
- UartPrintData(Sec_Low);
- UartPrintf("Date: "); //發送日期
- UartPrintf("20");
- UartPrintData(Display_GPRMC_Buffer[qian_b+5]);
- UartPrintData(Display_GPRMC_Buffer[qian_b+6]);
- UartPrintData('-');
- UartPrintData(Display_GPRMC_Buffer[qian_b+3]);
- UartPrintData(Display_GPRMC_Buffer[qian_b+4]);
- UartPrintData(Display_GPRMC_Buffer[qian_b+1]);
- UartPrintData(Display_GPRMC_Buffer[qian_b+2]);
- UartPrintf("Speed: ");
- for (i=qian_c+1; i<=hou_c-1; i++)
- UartPrintData(Display_GPRMC_Buffer[i]);
- UartPrintf(" m/s\r\n"); //發送速度,2位小數都發
- UartPrintf("----------------------------------------------\r\n");//分隔符
- //UTC日期與當地日期轉換
- void UTCDate2LocalDate(void)
- Day = (Day_High - 0x30) * 10 + (Day_Low-0x30) + 1; //日期進一
- Month = (Month_High - 0x30) * 10 + (Month_Low - 0x30);
- Year = 2000 + (Year_High - 0x30) * 10 + (Year_Low - 0x30);
- MaxDay = GetMaxDay(Month,Year); //獲取當月天數最大值
- if(Day > MaxDay) //如果溢出
- Day = 1;
- Month += 1;
- if(Month > 12)
- Year+=1;
- Day_High = Day/10 + 0x30; //轉換日期值為ASCII
- Day_Low = Day%10 + 0x30;
- Month_High = Month/10 + 0x30;
- Month_Low = Month%10 + 0x30;
- Year_High = Year%100/10 + 0x30;
- Year_Low = Year%10 + 0x30;
- //獲取當月日期最大值
- unsigned char GetMaxDay(unsigned char Month_Value,unsigned int Year_Value)
- unsigned char iDays;
- switch(Month_Value)
- case 1:
- case 3:
- case 5:
- case 7:
- case 8:
- case 10:
- case 12:
- iDays = 31;
- break;
- case 2:
- //2月份比較特殊,需要根據是不是閏年來判斷當月是28天還29天
- iDays = IsLeapYear(Year_Value) ? 29 : 28 ;
- break;
- case 4:
- case 6:
- case 9:
- case 11:
- iDays = 30;
GPS(LCD,USart).zip
(101.7 KB, 下載次數: 363)
2017-11-1 21:40 上傳
點擊文件名下載附件
GPS信息發到單片機,經過處理,發到串口,并顯示到LCD
