查看: 30242|回復: 1
[討論]
ID:25976 發表于 2010-9-14 12:27 | 顯示全部樓層 |閱讀模式
#include <stc\STC10.h>
#include <intrins.h>
//#include "inc\serial.h"
#define MAX_LEN 80
#define FRAME_HEAD1 0x7e
#define FRAME_HEAD2 0x81
#define PC_RECV_IDEL 1
#define PC_RECV_HEAD 2
#define PC_RECV_LEN  3
#define PC_RECV_ADDR 4
#define PC_RECV_TYPE 5
#define PC_RECV_NUM  6
#define PC_RECV_DATA 7
#define PC_SEND_IDEL  1
#define PC_SEND_HEAD  2
#define PC_SEND_LEN   3
#define PC_SEND_ADDR  4
#define PC_SEND_TYPE  5
#define PC_SEND_NUM   6
#define PC_SEND_DATA  7
#define PC_SEND_CHSUM 8
sbit LC5520_CS = P2^7;
sbit LED_OUT = P1^7;
typedef unsigned char uchar;
typedef unsigned int uint;
//接收幀結構
typedef struct pc_recv_frame
uchar rf_len;
uint rf_addr;
uchar rf_type;
uchar rf_num;
uchar rf_dat[MAX_LEN];
uchar rf_chsum;
}pc_recv_fr;
//發送幀結構
typedef struct pc_send_frame
uchar sf_len;
uint sf_addr;
uchar sf_type;
uchar sf_num;
uchar sf_dat[MAX_LEN];
uchar sf_chsum;
}pc_send_fr;
pc_recv_fr pdata pr_fr;   //接收幀結構變量
pc_send_fr pdata ps_fr;   //發送幀結構變量
bit serial0_recv_end = 0;  //接收完畢標志位
bit serial0_send_end = 0;  //發送完畢標志位
bit flag = 1;
uchar idata serv_data_count = 0;  //接收內容字節計數器
uchar idata send_data_count = 0;  //發送內容字節計數器
uchar idata serial0_recv_state = PC_RECV_IDEL;     //接收過程判斷標志
uchar idata serial0_send_state = PC_SEND_IDEL;    //發送過程判斷標志
void init_system(void);
void reset (void);
void delay_ms(uint ms);
uchar read_data(uchar xdata *read_data_addr);
void main(void)
init_system();
LED_OUT = 0;
ps_fr.sf_len = 0x06;
ps_fr.sf_addr = 0x03;
ps_fr.sf_type = 0x01;
ps_fr.sf_num = 0x01;
ps_fr.sf_dat[0] = 0x02;
ps_fr.sf_dat[1] = 0x03;
  while(1){
     while(flag){
   SBUF = 0x00;
   flag = 0;
  delay_ms(6000);
// SP = 0x60;
AUXR = AUXR | 0X42;
TMOD = 0x21;
TH1 = 0xE5;
TL1 = 0xE5;
TR1 = 1;
SCON = 0x50;
PCON = 0x80;
IE = 0x12;
IP = 0x10;
TH0 = 0xD8;
TL0 = 0xF0;
P0 = 0xff;
P1 = 0xff;
P2 = 0xff;
P3 = 0xff;
AUXR1 = 0x00;
LC5520_CS = 1;
ET0 = 0;
TR0 = 0;
ES = 1;
    EA = 1;
uchar c;
LC5520_CS = 0;
c = *read_data_addr;
LC5520_CS = 1;
return c;
//軟件看門狗
//void reset (void)
//((void (code *) (void)) 0x0000) ();
/*delay 1 ms*/
    uint i;
    uchar j;
    for(i=0;i<ms;i++)
        for(j=0;j<100;j++) {
        _nop_();
void serial_rec(void) interrupt 4 using 1
uchar tempSBUF;
if(RI)
RI = 0;
tempSBUF = SBUF;
switch(serial0_recv_state)
  case PC_RECV_IDEL:
   if(tempSBUF == FRAME_HEAD1)  //幀頭為0x7e
    serial0_recv_state = PC_RECV_HEAD;
    break;
  case PC_RECV_HEAD:        //幀頭為0x81
   if(tempSBUF == FRAME_HEAD2) {
    serial0_recv_state = PC_RECV_LEN;
    pr_fr.rf_chsum = 0x00;    //清累加和
    LED_OUT = !LED_OUT;
    break;
  case PC_RECV_LEN:        //接收到長度
   pr_fr.rf_len = tempSBUF;   //從長度開始的計算累加和
   serial0_recv_state = PC_RECV_ADDR;
   pr_fr.rf_chsum = pr_fr.rf_chsum + tempSBUF;
   break;             //軟件仿真時,這個break開始就不是退出中斷程序了,不知程序轉哪里了
  case PC_RECV_ADDR:     //接收到地址
   pr_fr.rf_addr = tempSBUF;
   serial0_recv_state = PC_RECV_TYPE;
   break;
  case PC_RECV_TYPE:    //接收到類型
   pr_fr.rf_type = tempSBUF;
   serial0_recv_state = PC_RECV_NUM;
   break;
  case PC_RECV_NUM:    //接收到幀序號
   pr_fr.rf_num = tempSBUF;
   serial0_recv_state = PC_RECV_DATA;
   serv_data_count = 0x00;  //接收內容字節計數器清零
   break;
  case PC_RECV_DATA:    //接收數據并算累加和
   if(serv_data_count < (pr_fr.rf_len-4))
    pr_fr.rf_dat[serv_data_count] = tempSBUF;
    serv_data_count++;
    }else
     {     //接收完畢后,還原接收初始狀態
     if(pr_fr.rf_chsum == tempSBUF)
      {    //校驗累加和,相同,則置接收完畢標志位
      serial0_recv_end = 1;
      }else
       {   //校驗錯誤,清接累加和,以便下次接收
   break;
  default:      //還原接收初始狀態,和累加和
   break;
} else if(TI)
  TI = 0;
  switch(serial0_send_state)
   case PC_SEND_IDEL:     //發送0x7e
    SBUF = FRAME_HEAD1;
    serial0_send_state = PC_SEND_HEAD;
    break;
   case PC_SEND_HEAD:
    SBUF = FRAME_HEAD2;  //發送0x81
    ps_fr.sf_chsum = 0x00;  //清發送累加和
    serial0_send_state = PC_SEND_LEN;
    break;
   case PC_SEND_LEN:     //發送長度
    SBUF = ps_fr.sf_len;
    ps_fr.sf_chsum = ps_fr.sf_chsum + ps_fr.sf_len;
    serial0_send_state = PC_SEND_ADDR;
    break;     //計算發送累加和
   case PC_SEND_ADDR:   //發送地址
    SBUF = ps_fr.sf_addr;
    ps_fr.sf_chsum = ps_fr.sf_chsum + ps_fr.sf_addr;
    serial0_send_state = PC_SEND_TYPE;
    break;
   case PC_SEND_TYPE:   //發送類型
    SBUF = ps_fr.sf_type;
    ps_fr.sf_chsum = ps_fr.sf_chsum + ps_fr.sf_type;
    serial0_send_state = PC_SEND_NUM;
    break;
   case PC_SEND_NUM:   //發送幀序號
    SBUF = ps_fr.sf_num;
    ps_fr.sf_chsum = ps_fr.sf_chsum + ps_fr.sf_num;
    serial0_send_state = PC_SEND_DATA;
    send_data_count = 0x00;   //清發送內容字節計數器
    break;
   case PC_SEND_DATA:    //發送內容字節,并計算累加和
    if(send_data_count < (ps_fr.sf_len-4))
     SBUF = ps_fr.sf_dat[send_data_count];
     ps_fr.sf_chsum = ps_fr.sf_chsum + ps_fr.sf_dat[send_data_count];
     send_data_count++;
     }else
      {serial0_send_state = PC_SEND_CHSUM;}
    break;
    case PC_SEND_CHSUM:      //發送累加和
    SBUF = ps_fr.sf_chsum;
    serial0_send_end = 1;  //置發送完畢標志位
    break;
   default:
    break;
總之程序非常怪異,不知道跑到哪里去了?希望回復能夠說的清楚一些
ID:1 發表于 2010-9-14 14:07 | 顯示全部樓層
這個程序是干什么的?  運行平臺是什么
主站蜘蛛池模板: 亚洲精品在线观看视频 | 亚洲一区二区免费视频 | 亚洲免费久久 | 天天操天天看 | 亚洲在线视频 | 日韩午夜精品 | 欧美在线网址 | 久久综合国产 | 久久九九国产 | 欧美午夜精品 | 久色精品 | 欧美不卡一区二区三区 | 黄色成人在线视频 | 看逼网站 | 精品日韩在线 | 毛片免费在线观看 | av免费看网站 | 天天爽夜夜爽 | 99视频免费在线观看 | av入口 | 自拍偷拍综合 | 成人做爰www看视频软件 | 99视频在线观看免费 | 六十路av | 亚洲欧美另类在线 | 毛片毛片毛片毛片毛片 | 亚洲国产精品久久久 | 久久久久久久 | 人人澡人人爽 | 九九成人| 中文字幕永久在线 | 中文字幕在线观看免费视频 | 一区二区三区四区视频 | 国产在线天堂 | 天天操女人 | 激情六月婷婷 | 日本在线观看 | 中文字幕在线资源 | xxxx性欧美| 日韩毛片网站 | 一区二区国产在线 |
