查看: 4132|回復(fù): 1
1602字符液晶自動水平和垂直滾動演示程序加仿真
ID:254377 發(fā)表于 2017-11-27 21:27 | 顯示全部樓層 |閱讀模式
在單片機的控制下能實現(xiàn)自動水平滾動與自動垂直滾動,并且?guī)в袝和i_始按鈕
  1. /***************   writer:shopping.w   ******************/
  2. #include <reg52.h>
  3. #include <string.h>
  5. #define uint unsigned int
  6. void Initialize_LCD();
  7. void ShowString(uchar,uchar,uchar *);
  8. sbit K1 = P3^0;
  9. sbit K2 = P3^1;
  10. sbit K3 = P3^2;
  11. uchar code Prompt[]="PRESS K1--K4 TO START DEMO PROG";
  12. uchar const Line_Count = 6;
  13. uchar code Msg[][80]=
  14. {
  15.          "Many CAD users dismiss",
  16.         "process of creating PCB",
  17.         "of view.with PCB layout",
  18.         "placement and track routing,",
  19.         "can often be the most time",
  20.         "And if you use circuit simulation",
  21.         "you are going to spend even more"
  22. };
  23. uchar Disp_Buffer[32];
  24. void Delayxms(uint ms)
  25. {
  26.          uchar i;
  27.         while(ms--)
  28.         {
  29.                  for(i=0;i<120;i++);
  30.         }
  31. }
  32. void V_Scroll_Display()
  33. {
  34.          uchar i,j,k = 0;
  35.         uchar *p = Msg[0];
  36.         uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  37.         while(p<q)
  38.         {
  39.                  for(i=0;(i<16)&&(p<q);i++)
  40.                 {
  41.                          if(((i==0)||(i==15))&& *p == ' ')
  42.                                 p++;
  43.                         if(*p != '\0')
  44.                         {
  45.                                  Disp_Buffer[i] = *p++;
  46.                         }
  47.                         else
  48.                         {
  49.                                  if(++k>Line_Count)
  50.                                         break;
  51.                                 p = Msg[k];
  52.                                 Disp_Buffer[i] = *p++;
  53.                         }
  54.                 }
  55.                 for(j=i;j<16;j++)
  56.                         Disp_Buffer[j]=' ';
  57.                 while(F0)
  58.                         Delayxms(5);
  59.                 ShowString(0,0,"      ");
  60.                 Delayxms(150);
  61.                 while(F0)
  62.                         Delayxms(5);
  63.                 ShowString(0,1,Disp_Buffer);
  64.                 Delayxms(150);
  65.                 while(F0)
  66.                         Delayxms(5);
  67.                 ShowString(0,0,Disp_Buffer);
  68.                 ShowString(0,1,"      ");
  69.                 Delayxms(150);
  70.         }
  71.         ShowString(0,0,"         ");
  72.         ShowString(0,1,"         ");
  73. }
  74. void H_Scroll_Display()
  75. {
  76.         uchar m,n,t = 0,L=0;
  77.         uchar *p = Msg[0];
  78.         uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  79.         for(m=0;m<16;m++)
  80.                         Disp_Buffer[m]=' ';
  81.         while(p<q)
  82.         {
  83.                  if((m=16||m==31)&& *p == ' ')
  84.                         p++;
  85.                 for(m=16;m<32&&p<q;m++)
  86.                 {
  87.                          if(*p != '\0')
  88.                         {
  89.                                 Disp_Buffer[m] = *p++;
  90.                         }
  91.                         else
  92.                         {
  93.                                  if(++t>Line_Count)
  94.                                         break;
  95.                                 p = Msg[t];
  96.                                 Disp_Buffer[m] = *p++;
  97.                         }
  98.                 }
  99.                 for(n=m;n<32;n++)
  100.                         Disp_Buffer[n]=' ';
  101.                 for(m=0;m<=16;m++)
  102.                 {
  103.                          while(F0)
  104.                                  Delayxms(5);
  105.                            ShowString(0,L,Disp_Buffer+1);
  106.                            while(F0)
  107.                                  Delayxms(5);
  108.                         Delayxms(20);
  109.                 }
  110.                 L = (L==0)? 1:0;
  111.                 Delayxms(200);
  112.         }
  113.         if(L==1)
  114.                 ShowString(0,1,"      ");
  115. }
  116. void EX_INT0() interrupt 0
  117. {
  118.          F0 = !F0;
  119. }
  120. void main()
  121. {
  122.          uint Count = 0;
  123.         IE = 0x81;
  124.         IT0 = 1;
  125. ……………………
  126. …………限于本文篇幅 余下代碼請從51黑下載附件…………
60 1602字符液晶滾動演示程序.zip (63.09 KB, 下載次數(shù): 33)
參與人數(shù) 1黑幣 +5 收起 理由
yinkun230 + 5 淡定
ID:523060 發(fā)表于 2019-5-4 19:02 | 顯示全部樓層
很好,解決了我很大問題
主站蜘蛛池模板: 日韩视频免费看 | av免费网站| 国产伦精品一区二区三区四区 | 日韩中文字幕第一页 | 黄色大片视频 | 视频一二区 | 亚洲高清免费 | 可以在线观看的av | www日韩| 狠狠操综合网 | 欧美一二区 | 中文字幕久久精品 | 精品小视频 | 成人在线视频网站 | 日韩欧美视频一区 | 日韩免费视频一区二区 | 青青草国产成人av片免费 | txvlog.com| 免费黄色一级视频 | 伊人精品综合 | 蜜桃色999| 91精品久久久久久粉嫩 | 国产三级做爰高清在线 | 日韩在线不卡 | 日韩免费在线视频 | 久久精品小视频 | 天天干天天爽 | 中文字幕在线视频观看 | 国产精品高清在线观看 | 免费在线黄色网址 | 国模无码大尺度一区二区三区 | 丰满少妇av| 男女操操操 | 人人草人人爽 | 日韩在线成人 | 久久久久久网 | 在线观看欧美日韩视频 | 美女黄色小说 | 精品免费在线观看 | 特级毛片爽www免费版 | 91亚洲国产成人久久精品网站 |
