初看是你按鍵掃描有問題,導(dǎo)致flag有數(shù)值,或者你按鍵板電路有故障,導(dǎo)致它認為你有按鍵存在 |
上面是代碼~ |
#include<reg52.h> #define uchar unsigned char #define uint unsigned int uchar code table[]= { 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71, }; uchar info[32]; uint temp,num=0,flag=0; uchar keyscany(); void init(); void delay(uchar i) { uchar j,k; for(j=i;j>0;j--) for(k=125;k>0;k--); } void main() { init(); while(1) { while(1) { info[num]=keyscany(); if(flag>0) { while(flag==0); SBUF=info[num]; num++; } if(num==32) break; } num=0; } } void init() { TMOD=0X20; TH1=0XFD; TL1=0XFD; TR1=1; SM0=0; SM1=1; REN=1; ES=1; EA=1; } uchar keyscany() { P3=0xfe; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delay(10); if(temp!=0xf0) { temp=P3; switch (temp) { case(0xee):num=0;break; case(0xde):num=1;break; case(0xbe):num=2;break; case(0x7e):num=3;break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } } } P3=0xfd;//??? temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delay(10); if(temp!=0xf0) { temp=P3; switch (temp) { case(0xed):num=4;break; case(0xdd):num=5;break; case(0xbd):num=6;break; case(0x7d):num=7;break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } } } P3=0xfb; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delay(10); if(temp!=0xf0) { temp=P3; switch (temp) { case(0xeb):num=8;break; case(0xdb):num=9;break; case(0xbb):num=10;break; case(0x7b):num=11;break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } } } P3=0xf7; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delay(10); if(temp!=0xf0) { temp=P3; switch (temp) { case(0xe7):num=12;break; case(0xd7):num=13;break; case(0xb7):num=14;break; case(0x77):num=15;break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } } } flag++; return num; } void inter() interrupt 4 { while(!TI); TI=0; } |
