查看: 2733|回復: 0
Tablet counting system verilog code
ID:256825 發(fā)表于 2017-12-3 16:09 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
Hex keypad or tablet counting system
源程序如下:
  1. //##################################################################
  2. /*
  3. Project/Module        : Assignment
  4. File name        : HexKeyCodeGenerator.v
  5. Version                : 1-0
  6. Date created        : 25 Aug 2017
  7. Author                : Vimalraj Kasivisvanathan
  8. Code type        : Verilog
  9. Description        : Verilog code for HexKeypad
  10. */
  11. //##################################################################
  12. //`default_nettype none
  13. module HEXKEY
  14. #(parameter [3:0]
  15. PRESSKEY = 4'b0001,
  16. KEYCOL0 = 4'b0010,
  17. KEYCOL1 = 4'b0011,
  18. KEYCOL2 = 4'b0100,
  19. KEYCOL3 = 4'b0101,
  20. //DELAY1 = 4'b0110,
  21. //DELAY2 = 4'b0111,
  22. KEYVALID = 4'b1000,
  23. KEYRELEASE = 4'b1001,
  24. KEYERROR = 4'b1010)
  25. (input        b_ip_hex_sys_clock,
  26. input        b_ip_hex_sys_reset,
  27. input        b_ip_hex_clear,
  28. input [3:0] b_ip_hex_keypad_row
  29. output reg [3:0] b_op_hex_keycode,
  30. output reg              b_op_hex_valid_code,
  31. output reg [3:0]  b_op_hex_keypad_column,
  32. );
  33. reg [3:0] current,next,row;
  34. //***********************************************************
  35. ///////////////FIRST//////////////////////////////////////
  36. always @(posedge b_ip_hex_sys_clock) begin: BGN
  37. if (b_ip_hex_sys_reset || b_ip_hex_clear) current <= PRESSKEY;
  38. else                                         current <= next;
  39. end
  40. //////////////////////////////////////////////////////////
  41. ///////////////////////CURRENTSTATE/////////////////////////
  42. always @(b_ip_hex_keypad_row || current)begin: NSL
  43.         case(current)
  44.
  45.                 PRESSKEY:
  46.                         if ((|b_ip_hex_keypad_row))  next <= KEYCOL0;
  47.                         else                            next <= PRESSKEY;
  48.
  49.                 KEYCOL0:
  50.                         if ((|b_ip_hex_keypad_row))  next = KEYVALID;
  51.                         else if ((!(|b_ip_hex_keypad_row)) && b_op_hex_keypad_column == 4'b0001) next = KEYCOL1;
  52.
  53.
  54.                 KEYCOL1:
  55.                         if ((|b_ip_hex_keypad_row))  next = KEYVALID;
  56.                         else if ((!(|b_ip_hex_keypad_row)) && b_op_hex_keypad_column == 4'b0010) next = KEYCOL2;
  57.                 KEYCOL2:
  58.                         if ((|b_ip_hex_keypad_row))  next = KEYVALID;
  59.                         else if ((!(|b_ip_hex_keypad_row)) && b_op_hex_keypad_column == 4'b0100) next = KEYCOL3;
  60.                 KEYCOL3:
  61.                         if ((|b_ip_hex_keypad_row))          next = KEYVALID;
  62.                         else if (!(b_ip_hex_keypad_row)) next = KEYERROR;
  63.                         else                                 next = 4'bx;
  64.                 KEYVALID:
  65.                         next = KEYRELEASE;
  66.                 KEYRELEASE:
  67.                         if (!(|b_ip_hex_keypad_row)) next = PRESSKEY;
  68.                         else                            next = KEYRELEASE;
  69.                 KEYERROR:
  70.                         next = PRESSKEY;
  71.
  72.                 default:
  73.                         next = 4'bx;
  74.         endcase
  75. end
  76. /////////////////////NEXTSTATE LOGIC///////////////////////////////////////////////
  77. always @(posedge b_ip_hex_sys_clock)begin: ROL
  78.     if (b_ip_hex_sys_reset || b_ip_hex_clear)begin
  79.         b_op_hex_keypad_column <= 4'b1111;
  80.         b_op_hex_valid_code    <= 1'b0;
  81.         b_op_hex_keycode       <= 4'b0000;
  82.         row                       <= 4'b0000;
  83. end
  84. else begin
  85.         case(next)
  86.                 PRESSKEY:begin
  87.                         b_op_hex_keypad_column <= 4'b1111;
  88.                         b_op_hex_valid_code    <= 1'b0;
  89.                         b_op_hex_keycode       <= 4'b0000;
  90.                         row                       <= 4'b0000;
  91.                         end
  92.
  93.                 KEYCOL0:begin
  94.                         b_op_hex_keypad_column <= 4'b0001;
  95.                         b_op_hex_valid_code    <= 1'b0;
  96.                         row                       <= b_ip_hex_keypad_row;
  97.                                 if (row == 4'b0001) b_op_hex_keycode <= 4'b0000;
  98.                                 else if (row == 4'b0010) b_op_hex_keycode <= 4'b0100;
  99.                                 else if (row == 4'b0100) b_op_hex_keycode <= 4'b1000;
  100.                                 else if(row == 4'b1000) b_op_hex_keycode <= 4'b1100;
  101.                         end
  102.                 KEYCOL1:begin
  103.                         b_op_hex_keypad_column <= 4'b0010;
  104.                         b_op_hex_valid_code    <= 1'b0;
  105.                         row                       <= row;
  106.                                 if (row == 4'b0001) b_op_hex_keycode <= 4'b0001;
  107.                                 else if (row == 4'b0010) b_op_hex_keycode <= 4'b0101;
  108.                                 else if (row == 4'b0100) b_op_hex_keycode <= 4'b1001;
  109.                                 else if(row == 4'b1000) b_op_hex_keycode <= 4'b1101;
  110.                         end
  111.                 KEYCOL2:begin
  112.                         b_op_hex_keypad_column <= 4'b0100;
  113.                         b_op_hex_valid_code    <= 1'b0;
  114.                         row                       <= row;
  115.                                 if (row == 4'b0001) b_op_hex_keycode <= 4'b0010;
  116.                                 else if (row == 4'b0010) b_op_hex_keycode <= 4'b0110;
  117.                                 else if (row == 4'b0100) b_op_hex_keycode <= 4'b1010;
  118.                                 else if(row == 4'b1000) b_op_hex_keycode <= 4'b1110;
  119.                         end
  120.                 KEYCOL3:begin
  121.                         b_op_hex_keypad_column <= 4'b1000;
  122.                         b_op_hex_valid_code    <= 1'b0;
  123.                         row                       <= row;
  124.                                 if (row == 4'b0001) b_op_hex_keycode <= 4'b0011;
  125.                                 else if (row == 4'b0010) b_op_hex_keycode <= 4'b0111;
  126.                                 else if (row == 4'b0100) b_op_hex_keycode <= 4'b1011;
  127.                                 else if(row == 4'b1000) b_op_hex_keycode <= 4'b1111;
  128.                         end
  129.                 KEYRELEASE:begin
  130.                         b_op_hex_keypad_column <= 4'b1111;
  131.                         b_op_hex_valid_code    <= 1'b0;
  132.                         b_op_hex_keycode       <= b_op_hex_keycode;
  133.                         end
  134. ……………………
  135. …………限于本文篇幅 余下代碼請從51黑下載附件…………
HexKeypad.rar (72.42 KB, 下載次數: 6)
主站蜘蛛池模板: 伊人久久综合 | 91女人18毛片水多国产 | 国产三级视频在线播放 | 一区二区免费 | 午夜美女福利 | 久久av片| 亚洲国产欧美日韩在线 | 亚洲二三区 | 激情久久久 | 自拍偷拍欧美日韩 | 国产在线一区二区三区 | 高清免费av | 欧美午夜精品一区二区三区 | 久草网在线 | 久久国产精品免费视频 | 国产精品一区二区在线播放 | 免费av一区二区 | 欧美成年人视频 | 日韩欧美在线播放 | 欧美日韩不卡 | 国产天堂在线 | 午夜网站在线观看 | 日本视频免费 | 丁香av | 国产精品一区二区三区免费 | 日韩毛片在线播放 | av毛片网站| 亚洲乱色 | 午夜视频在线看 | 亚洲在线播放 | 九九免费视频 | 中文字幕在线一区二区三区 | 午夜免费av| 亚洲福利一区 | 日韩精品一区在线观看 | 好色网站| 免费看黄网 | 国产美女在线播放 | 成人av一区二区三区在线观看 | 欧美顶级黄色大片免费 | 在线观看欧美日韩视频 |
