查看: 3807|回復: 2
搶答器vhdl源程序
ID:260092 發(fā)表于 2017-12-11 14:18 | 顯示全部樓層 |閱讀模式
動定義為“開始”(即enable)的開關后,一排指示燈變亮,之后搶答開始,有4個扳動開關代表4個搶答器,數碼管將顯示出最先被扳動的開關的序號,同時發(fā)出聲音,表示搶答成功。若未按“開始”前,有任意開關被扳動,則數碼管顯示被扳動開關的序號,并發(fā)出另一種聲音,表示有人搶答
vhdl源程序如下:
  1. library IEEE;
  2. use IEEE.STD_LOGIC_1164.ALL;
  3. use IEEE.STD_LOGIC_ARITH.ALL;
  4. use IEEE.STD_LOGIC_UNSIGNED.ALL;
  5. --  Uncomment the following lines to use the declarations that are
  6. --  provided for instantiating Xilinx primitive components.
  7. --library UNISIM;
  8. --use UNISIM.VComponents.all;
  9. entity qiangdaqi is
  10. port(enable:in std_logic;
  11.      --reset:in std_logic;
  12.           a:in std_logic;
  13.           b:in std_logic;
  14.           c:in std_logic;
  15.           d:in std_logic;
  16.           clk:in std_logic;
  17.           spkout:out std_logic;
  18.           cs:buffer std_logic_vector(1 downto 0);
  19.           --cs:buffer std_logic;
  20.           led:out std_logic_vector(7 downto 0);
  21.           seg:out std_logic_vector(3 downto 0);
  22.           segment:out std_logic_vector(7 downto 0)
  23.           );
  24. end qiangdaqi;
  25. architecture Behavioral of qiangdaqi is
  26. -- signal led1,led0:std_logic_vector(7 downto 0);
  27. signal flag:std_logic;
  28. signal output:std_logic_vector(3 downto 0);
  29. signal start:std_logic;
  30. signal index:std_logic_vector(5 downto 0);
  31. signal count: std_logic_vector(25 downto 0);
  32. signal fclk:std_logic;
  33. --signal led1:std_logic_vector(7 downto 0);
  34. component input is
  35.     port(--en:in std_logic;
  36.               clk:in std_logic;
  37.                         --reset:in std_logic;
  38.               a:in std_logic;
  39.                         b:in std_logic;
  40.                         c:in std_logic;
  41.                         d:in std_logic;
  42.                         output:out std_logic_vector(3 downto 0);
  43.                         flag:out std_logic);
  44. end component;
  45. component light is
  46.     port(--en:in std_logic;
  47.               clk:std_logic;
  48.                         input:in std_logic_vector(3 downto 0);
  49.                         flag:in std_logic;
  50.                         seg:out std_logic_vector(3 downto 0);
  51.                         ledout:out std_logic_vector(7 downto 0));
  52. end component;
  53. component control is
  54.     port(start:in std_logic;
  55.               a:in std_logic;
  56.                         b:in std_logic;
  57.                         c:in std_logic;
  58.                         d:in std_logic;
  59.                         clk:in std_logic;
  60.                         spkout:out std_logic;
  61.                         index:buffer std_logic_vector(5 downto 0)
  62.          );
  63. end component;
  64. --component lcd is
  65.    -- port(clk:in std_logic;
  66.                 --        enable:in std_logic;
  67.                 --        led:out std_logic_vector(7 downto 0);
  68.                 --        cs:buffer std_logic_vector(1 downto 0);
  69.                 --        start:out std_logic
  70. --                        );
  71. --end component;
  72. begin
  73. --cs<=cs1;
  74. --led<=led1;
  75. process(fclk,enable)
  76. begin
  77. --cs<="00";
  78. --led<="11111111";
  79.      if fclk'event and  fclk='1' then
  80.         if  enable='0' then
  81.                       cs<="01";
  82.                                 --led<="11111111";
  83.                                 if(fclk='1') then
  84.                  led<="11111110";
  85.                                 end if;
  86.                                 if(fclk='0') then
  87.                  led<="11111100";
  88.                                 end if;
  89.                                 if(fclk='1') then
  90.                  led<="11111000";
  91.                                 end if;
  92.                                 if(fclk='0') then
  93.                  led<="11110000";
  94.                                 end if;
  95.                                 if(fclk='1') then
  96.                  led<="11100000";
  97.                                 end if;
  98.                                 if(fclk='0') then
  99.                  led<="11000000";
  100.                                 end if;
  101.                                 if(fclk='1') then
  102.                  led<="10000000";
  103.                                 end if;
  104.                                 if(fclk='0') then
  105.                  led<="00000000";
  106.                                 end if;
  107.                  start <='1';
  108.                         else
  109.             start<='0';
  110.                                 cs<="00";
  111.                       --led<="11111111";
  112.                         end if;
  113.           end if;
  114. end process;
  115. process(clk)
  116. begin
  117.          if (clk'event and clk='1') then
  118.           if(count=50000000)        then
  119.             count<="00000000000000000000000000";
  120.           else
  121.                  count<=count+1;
  122.      end if;
  123.         end if;
  124. end process;
  125. fclk <= count(25);
  126. --process(fclk)
  127. --begin
  128. --if(fclk'event and fclk='1') then
  129.    --counter<="000";
  130. --process(clk,enable)
  131. --begin
  132. --if(clk'event and clk='1') then
  133.   -- if(enable'event and enable='0') then
  134.      --   cs<="01";
  135.           --   led<="11111110";
  136.           --   led<="11111100";
  137.           --   led<="11111000";
  138. ……………………
  139. …………限于本文篇幅 余下代碼請從51黑下載附件…………
搶答器.rar (4.32 KB, 下載次數: 42)
ID:260092 發(fā)表于 2017-12-11 14:20 | 顯示全部樓層
eached for the definition of "start" (enable) the switch, a row of bright lights changed, after Responder, a four flick of a switch on behalf of four Responder, digital controls are to be shown first to be reached for the switch serial number, also issued voices saying Responder success. If the failure to "start" before it was switched on the flick, Digital Display was the flick of a switch the serial numbers, and issued another voice, someone Responder.
ID:323384 發(fā)表于 2019-6-3 12:13 | 顯示全部樓層
真棒真棒真棒
主站蜘蛛池模板: 日韩av综合网 | 国产成人免费视频 | 国产精品免费一区二区三区 | 中文字幕在线看片 | 亚洲天堂影院 | 91蜜桃婷婷狠狠久久综合9色 | 亚洲免费福利视频 | 免费观看av网站 | 国产精品一区二区不卡 | 国产91色| 99在线播放 | 97超碰人人| 大尺度做爰呻吟舌吻网站 | 国产aⅴ爽av久久久久成人 | 欧美www| 日本黄色免费网站 | 人人澡人人爽 | 日本黄色免费视频 | 亚洲三级视频在线观看 | 最新av在线| 在线一区二区视频 | 亚洲区在线 | 天天综合av | 日韩特黄 | 欧美视频三区 | 久久狠狠干 | 国产一区不卡 | wwwxxx欧美| 欧美综合一区二区 | 免费毛片基地 | 99精品视频在线观看 | 欧美综合一区二区 | 欧美成人一级 | 亚洲理论片 | 久久18| 一区二区三区四区在线播放 | 国产精品入口夜色视频大尺度 | 亚洲天堂免费 | 亚洲欧美第一页 | 在线网站免费观看18 | 午夜网站在线观看 |
