交通燈控制電路仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
下載附件
2017-12-23 19:32 上傳
下載附件
2017-12-23 20:10 上傳
單片機(jī)源程序如下:
- //功能:交通燈控制程序
- #include <reg52.h> //包含頭文件reg51.h,定義了51單片機(jī)的專用寄存器
- unsigned char t0,t1; //定義全局變量,用來(lái)保存延時(shí)時(shí)間循環(huán)次數(shù)
- unsigned count=0;
- unsigned char time=60;
- sbit wei1=P3^6;
- sbit wei2=P3^7;
- unsigned char code sum[]={0x3f,0x06,0x5b,
- 0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
- 0x77,0x7c,0x39,0x5e,0x79,0x71};
- void delayms(unsigned int ms) //@12.000MHz
- unsigned char i, j;
- while(ms--)
- i = 2;
- j = 239;
- do
- while (--j);
- } while (--i);
- void display()
- P2=0x00;
- wei1=0;
- P2=sum[time/10];
- delayms(5);
- wei1=1;
- P2=0x00;
- wei2=0;
- P2=sum[time%10];
- delayms(5);
- wei2=1;
- void int_3() interrupt 3
- TH1=(65536-50000)/256; //設(shè)置定時(shí)器初值
- TL1=(65536-50000)%256;
- count++;
- if(count==20)
- count=0;
- time--;
- if(time==0)
- time=60;
- display();
- void delay0_5s1()
- for(t0=0;t0<10;t0++) //采用全局變量t0作為循環(huán)控制變量
- TH0=(65536-50000)/256; //設(shè)置定時(shí)器初值
- TL0=(65536-50000)%256;
- TR0=1; //啟動(dòng)T1
- while(!TF0); //查詢計(jì)數(shù)是否溢出,即50ms定時(shí)時(shí)間到,TF1=1
- TF0=0; //50ms定時(shí)時(shí)間到,將定時(shí)器溢出標(biāo)志位TF1清零
- //函數(shù)名:delay_t1
- //函數(shù)功能:實(shí)現(xiàn)0.5~128s延時(shí)
- //形式參數(shù):unsigned char t;
- // 延時(shí)時(shí)間為0.5s×t
- //返回值:無(wú)
- void delay_t1(unsigned char t)
- for(t1=0;t1<t;t1++) //采用全局變量t1作為循環(huán)控制變量
- delay0_5s1();
- //函數(shù)名:int_0
- //函數(shù)功能:外部中斷0中斷函數(shù),緊急情況處理,當(dāng)CPU響應(yīng)外部中斷0的中斷請(qǐng)求時(shí),
- // 自動(dòng)執(zhí)行該函數(shù),實(shí)現(xiàn)兩個(gè)方向紅燈同時(shí)亮10 s
- //形式參數(shù):無(wú)
- //返回值:無(wú)
- void int_0() interrupt 0 //緊急情況中斷
- unsigned char i,j,k,l,m,n,o;
- i=P1; //保護(hù)現(xiàn)場(chǎng),暫存P1口、t0、t1、TH1、TL1
- j=t0;
- k=t1;
- l=TH1;
- m=TL1;
- n=TH0;
- o=TL0;
- P1=0xdb; //兩個(gè)方向都是紅燈
- delay_t1(20); //延時(shí)10 s
- P1=i; //恢復(fù)現(xiàn)場(chǎng),恢復(fù)進(jìn)入中斷前P1口、t0、t1、TH1、TL1
- t0=j;
- t1=k;
- TH1=l;
- TL1=m;
- TH0=n;
- TL0=o;
- //函數(shù)名:int_1
- //函數(shù)功能:外部中斷1中斷函數(shù),特殊情況處理,當(dāng)CPU響應(yīng)外部中斷1的中斷請(qǐng)求時(shí),
- // 自動(dòng)執(zhí)行該函數(shù),實(shí)現(xiàn)A道放行5 s
- //形式參數(shù):無(wú)
- //返回值:無(wú)
- void int_1() interrupt 2 //特殊情況中斷
- EA=0; //關(guān)中斷
- j=t0;
- k=t1;
- l=TH1;
- m=TL1;
- n=TH0;
- o=TL0;
- EA=1; //開(kāi)中斷
- P1=0xf3; //A道放行
- delay_t1(10); //延時(shí)5 s
- EA=0; //關(guān)中斷
- t0=j;
- t1=k;
- TH1=l;
- TL1=m;
- TH0=n;
- TL0=o;
- EA=1; //開(kāi)中斷
- void main() //主函數(shù)
- unsigned char k;
- TMOD=0x11; //T1設(shè)置為工作方式1
- EA=1; //開(kāi)總中斷允許位
- ET1=1;
- TR1=1;
- EX0=1; //開(kāi)外部中斷0中斷允許位
- IT0=1; //設(shè)置外部中斷0為下降沿觸發(fā)
- EX1=1; //開(kāi)外部中斷1中斷允許位
- IT1=1; //設(shè)置外部中斷1為下降沿觸發(fā)
- while(1)
- P1=0xf3; //A綠燈,B紅燈,延時(shí)55 s
- delay_t1(110);
- for(k=0;k<3;k++) //A綠燈閃爍3次
- {P1=0xf3;
- delay0_5s1(); //延時(shí)0.5 s
- P1=0xfb;
- P1=0xeb; //A黃燈,B紅燈,延時(shí)2 s
- delay_t1(4);
- P1=0xde; //A紅燈,B綠燈,延時(shí)55 s
- delay_t1(110);
- for(k=0;k<3;k++) //B綠燈閃爍3次
- {P1=0xde;
- P1=0xdf;
- P1=0xdd; //A紅燈,B黃燈,延時(shí)2 s
- delay_t1(4);
交通燈控制電路仿真 程序.zip
(39.2 KB, 下載次數(shù): 119)
2017-12-23 19:35 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
