查看: 4112|回復(fù): 0
Verilog HDL同步FIFO的設(shè)計報告
ID:300798 發(fā)表于 2018-4-2 13:08 | 顯示全部樓層 |閱讀模式
分享一個fifo設(shè)計,基于V語言
大學(xué)物聯(lián)網(wǎng)工程學(xué)院
Verilog HDL項(xiàng)目設(shè)計報告
題目同步FIFO的設(shè)計
專業(yè)、學(xué)號電科1362910201 13629102225
授課班號6292758
摘要
FIFO【1】是First Input First Output的縮寫,先進(jìn)先出隊(duì)列,這是一種傳統(tǒng)的按序執(zhí)行方法,也是一種先進(jìn)先出的數(shù)據(jù)緩存器。它與普通存儲器的區(qū)別是沒有外部讀寫地址線,這樣使用起來非常簡單,但缺點(diǎn)就是只能順序?qū)懭霐?shù)據(jù),順序讀出數(shù)據(jù),其數(shù)據(jù)地址由內(nèi)部讀寫指針自動加1完成,不能像普通存儲器那樣,可以由地址線決定讀取或?qū)懭肽硞指定的地址。為了提高效率和降低系統(tǒng)設(shè)計的難度,本文使用Verilog HDL【 2 】描述語言,通過Xilinx公司的ISE 【3】軟件進(jìn)行程序編寫以及仿真,再將程序燒寫進(jìn)Basys2開發(fā)板,設(shè)計實(shí)現(xiàn)了一種4bit-256深的同步FIFO,提供數(shù)據(jù)緩沖。
關(guān)鍵詞:同步FIFO  Verilog HDL  Basys
Abstract
FIFO is a acronym of First Input First Output, FIFO queue, which is a traditional sequential execution method, but also a FIFO data register. It differs from the ordinary that there is no external memory write address lines, so very simple to use, but the disadvantage is that the only sequential write data sequentially read out, the data read by the internal address pointer is automatically incremented by 1 to complete, not like generic memory that can be determined by the address line read from or written to a specified address. In order to improve efficiency and reduce the difficulty of system design, we use Verilog HDL description language, take advantage of Xilinx's ISE software programming and simulation, and then burn program written Basys2 development board, designed and implemented a 4bit-256 deep synchronous FIFO, provide data buffering.
Keywords: synchronous FIFO  Verilog HDL  Basys2
目錄
一、系統(tǒng)設(shè)計
1.1 設(shè)計目的
1.2 方案的對比分析與確定
1.2.1 初始方案
1.2.2 改進(jìn)方案
1.3 電路方框圖及說明
1.4 電路設(shè)計及說明
1.4.1 頂層模塊
1.4.2 時鐘分頻模塊
1.4.3 數(shù)據(jù)輸入輸出模塊
1.4.4 譯碼模塊
二、結(jié)果與討論
2.1 調(diào)試步驟與現(xiàn)象
2.1.1 調(diào)試程序
2.1.2 仿真
2.1.3 燒寫程序到Basys2開發(fā)板
2.2 出現(xiàn)的問題與分析
2.3 對相關(guān)數(shù)據(jù)的分析與討論
三、心得體會
3.1 設(shè)計特點(diǎn)
3.2 評估結(jié)果
3.3 改善建議
3.4 自我體會
五、參考文獻(xiàn)
六、附錄
附錄一 RTL原理圖
附錄二 作品圖片
一、系統(tǒng)設(shè)計
1.1 設(shè)計目的
              為了鞏固和加深對“VerilogHDL數(shù)字設(shè)計與綜合”與“數(shù)字電子技術(shù)”兩門課程的理論知識及應(yīng)用,了解如何使用VerilogHDL語言進(jìn)行電路設(shè)計的步驟與方法,掌握ISE軟件編程以及仿真的使用方法,初步了解Basys2開發(fā)板的使用方法,同時讓我們對電子電路設(shè)計有進(jìn)一步的認(rèn)識,為我們后期對設(shè)計與制作的學(xué)習(xí)奠定了基礎(chǔ)。
1.2 方案的對比分析與確定
1.2.1 初始方案
使用100kHz作為工作時鐘。當(dāng)寫入信號有效時,每個時鐘上升沿來臨,寫入一個數(shù)據(jù),同時寄存器指針指向寄存器下一位;當(dāng)讀取信號有效時,每個始終上升沿來臨,讀出一個數(shù)據(jù)。數(shù)據(jù)存滿,滿信號燈亮;無數(shù)據(jù)時,空信號燈亮。
缺點(diǎn):該方案的程序燒錄進(jìn)Basys2開發(fā)板后,對輸入數(shù)據(jù)有很高的要求,首先速度必須很快,因?yàn)槊恳粋上升沿來臨就會寫入一個數(shù)據(jù),如果數(shù)據(jù)輸入不及時,同一個數(shù)據(jù)將被輸入兩遍,讀出速度太快,丟包率高。
優(yōu)點(diǎn):該方案適合于仿真,可以快速實(shí)現(xiàn)功能仿真。
1.2.2 改進(jìn)方案
同樣使用100kHz作為工作時鐘。先使用開關(guān)設(shè)置好4位要寫入的數(shù)據(jù),按下寫入按鍵后該數(shù)據(jù)寫入寄存器;隨時可按下讀取按鍵,讀出一個數(shù)據(jù)并顯示在數(shù)碼管上。數(shù)據(jù)存滿,滿信號燈亮;無數(shù)據(jù)時,空信號燈亮。
缺點(diǎn):該方案仿真時間相對較長。
優(yōu)點(diǎn):該方案的程序燒錄進(jìn)Basys2開發(fā)板后,隨時可以寫入數(shù)據(jù),同時可以隨時讀出數(shù)據(jù),速度自由,目前測試丟包率為零。
1.3 電路方框圖及說明
1.4 電路設(shè)計及說明
1.4.1 頂層模塊
     連接控制時鐘分頻模塊div、數(shù)據(jù)輸入輸出模塊fifo、譯碼模塊transcoder
1.4.2 時鐘分頻模塊
     將Basys2開發(fā)板上的50MHz時鐘輸入分頻為100kHz作為其他模塊的工作時鐘。
     通過4個開關(guān)實(shí)現(xiàn)4bit數(shù)據(jù)的輸入,當(dāng)寫入按鍵按下時,數(shù)據(jù)被寫入且寄存器指針指向下一位。當(dāng)讀取按鍵按下時,讀出最先輸入的一個數(shù)據(jù)。寫入、讀取時間自由。
1.4.4 譯碼模塊
         將4位輸入的BCD碼【4】譯為8位二進(jìn)制代碼用于數(shù)碼管顯示。
二、結(jié)果與討論
2.1.1 調(diào)試程序
     最初采用通過判斷寫入信號與讀取信號的高低電平來控制數(shù)據(jù)的輸入與輸出,時鐘信號的上升沿直接控制指針+1。無法做到隨時的輸入與輸出,且對數(shù)據(jù)輸入方式要求極高,丟包率高。
                            之后修改程序,通過判斷寫入信號與讀取信號的上升沿來控制數(shù)據(jù)的輸入與輸出,并同時控制指針+1。測試可以做到隨時的輸入與輸出,目前丟包率為零。
2.1.2 仿真
初始方案:在仿真程序中輸入18位數(shù)據(jù),寫入信號保持高電平時數(shù)據(jù)按一定速度輸入,讀取信號保持高電平時,數(shù)據(jù)可正常讀出。
改進(jìn)方案:在仿真程序中嘗試輸入兩個數(shù)據(jù),并讀出數(shù)據(jù)。測試可行。
                            初始方案無法正常讀出。改進(jìn)方案測試可行。
2.2 出現(xiàn)的問題與分析
問題一:仿真時數(shù)據(jù)讀不出來,但燒寫進(jìn)開發(fā)板時測試正常。
分析:仿真時時間設(shè)置不對,設(shè)置為每100個時間單位輸入一個數(shù)據(jù),但是此時100KHz的時鐘信號還未出現(xiàn)過一個上升沿,所以數(shù)據(jù)無法寫入。
問題二:仿真時能無限寫入數(shù)據(jù),但只能讀取最后一個數(shù)據(jù)。
分析:每次數(shù)據(jù)寫入時指針沒有指向下一位,數(shù)據(jù)輸入后一直覆蓋之前的數(shù)據(jù),所以時鐘只能讀取最后一個數(shù)據(jù)。
問題三:程序編寫為16深,但只能存儲15個數(shù)據(jù)。
分析:數(shù)據(jù)從第0位寄存器開始儲存數(shù)據(jù),由于寫入信號同時控制著數(shù)據(jù)的寫入與指針的指向,但當(dāng)?shù)竭_(dá)第15位時,指針不再能指向下一位,數(shù)據(jù)也就不再能寫入,即數(shù)據(jù)寄存在0-14位寄存器。
FIFO的幾個重要參數(shù):
1、寬度:寬度即4bit,每個數(shù)據(jù)為四位。在該程序中可自由修改寬度。
2、深度:深度指能夠儲存的數(shù)據(jù)個數(shù)。在該程序中可自由修改深度,方便擴(kuò)展。
3、滿標(biāo)志:滿標(biāo)志用于阻止數(shù)據(jù)寫入而造成的溢出。判斷FIFO是否已滿十分重要。
4、空標(biāo)志:空標(biāo)志用于阻止數(shù)據(jù)讀取而造成的無效數(shù)據(jù)讀出。
5、寫入指針:指向下一個要寫入的地址,寫入時同時加1。
6、讀取指針:指向下一個要讀取的地址,讀取時同時加1。
三、心得體會
3.1 設(shè)計特點(diǎn)
本課程設(shè)計運(yùn)用Verilog HDL硬件描述語言,通過Xilinx公司的ISE軟件進(jìn)行程序編寫以及仿真,將程序燒寫至Basys2開發(fā)板,設(shè)計實(shí)現(xiàn)了一種4bit-256深的同步FIFO,提供數(shù)據(jù)緩沖。不同于之前硬件電路課程設(shè)計和C語言課程設(shè)計,此課程設(shè)計需要結(jié)合硬件和軟件知識,需要掌握Verilog HDL硬件描述語言,熟悉Basys2開發(fā)板的硬件電路及板上各模塊的使用方法。
    設(shè)計的同步FIFO寬度為4bit,深度為256,參數(shù)可以在程序中修改,方便擴(kuò)展。通過4位開關(guān)輸入數(shù)據(jù),寫入按鍵確認(rèn)輸入的數(shù)據(jù),讀取按鍵讀取一條數(shù)據(jù),這樣設(shè)計便于手動輸入數(shù)據(jù)。滿標(biāo)志LED亮表示隊(duì)列已滿,空標(biāo)志LED亮表示隊(duì)列是空狀態(tài),方便觀察。使用數(shù)碼管顯示4位2進(jìn)制數(shù),充分利用板上模塊資源,完成整個設(shè)計。
3.2 評估結(jié)果
利用Basys2開發(fā)板基本實(shí)現(xiàn)了FIFO隊(duì)列所有要求。但是通過手動輸入數(shù)據(jù)模擬不同工作頻率模塊間通信,還不能實(shí)際運(yùn)用。
并且存在程序編寫為16深,但只能存儲15個數(shù)據(jù)的問題,原因是數(shù)據(jù)從第0位寄存器開始儲存數(shù)據(jù),由于寫入信號同時控制著數(shù)據(jù)的寫入與指針的指向,但當(dāng)?shù)竭_(dá)第15位時,指針不再能指向下一位,數(shù)據(jù)也就不再能寫入,即數(shù)據(jù)寄存在0-14位寄存器。
3.3 改善建議
(1)通過矩陣鍵盤輸入數(shù)據(jù)和控制輸入和讀取;
(2)使用液晶屏幕顯示參數(shù),標(biāo)志滿、空狀態(tài),美化交互界面;
(3)可以手動輸入位寬和深度參數(shù)。
3.4 自我體會
通過本次課程設(shè)計,我們鞏固和加深了“VerilogHDL數(shù)字設(shè)計與綜合”與“數(shù)字電子技術(shù)”兩門課程的理論知識及應(yīng)用,認(rèn)識到了基礎(chǔ)知識是一切實(shí)踐的基礎(chǔ),只有掌握好了理論知識,才能更好地使用工具去做設(shè)計與創(chuàng)新。
相比于在紙上寫代碼,使用軟件編寫代碼,可以及時仿真驗(yàn)證效果,通過實(shí)踐加深所學(xué)知識,熟悉使用VerilogHDL語言進(jìn)行電路設(shè)計的步驟與方法。學(xué)習(xí)ISE軟件編程以及仿真,方便之后將此軟件作為一個優(yōu)秀的工具,為我們設(shè)計更復(fù)雜的項(xiàng)目服務(wù)。在實(shí)際使用Basys2開發(fā)板,燒寫程序到芯片中時,出現(xiàn)了各種問題,我們通過查閱網(wǎng)絡(luò)資料、詢問老師、同學(xué)交流等多種方式,將問題一一解決,在解決問題的過程中我們加深了對軟件的使用和對知識點(diǎn)的學(xué)習(xí)。
我們認(rèn)識到動手實(shí)踐會遇到書中未提出的許多問題,而找出問題原因并將其解決鍛煉了我們查閱資料、獨(dú)立思考的能力,豐富了我們的實(shí)踐經(jīng)驗(yàn),使我們對電子電路設(shè)計有進(jìn)一步的認(rèn)識,為我們后期對設(shè)計與制作的學(xué)習(xí)奠定了基礎(chǔ)。
五、參考文獻(xiàn)
1、Szwagrzyk J, Whitt J K. FIFO peek access: US, US7773453[P]. 2010.
2、袁本榮, 劉萬春, 賈云得,等. 用Verilog HDL進(jìn)行FPGA設(shè)計的一些基本方法[J]. 微計算機(jī)信息:測控儀表自動化, 2004, 20(6):93-94.
3.田耘 胡彬 徐文波. XILINX ISE DESIGN SUITE 10.X FPGA開發(fā)指南(邏輯設(shè)計篇)[M]. 人民郵電, 2008.
4.陳安時. 小數(shù)二進(jìn)制碼對BCD碼的轉(zhuǎn)換[J]. 電子技術(shù)應(yīng)用, 1982(6).
六、附錄
附錄一RTL原理圖
附錄二作品圖片
圖 1  初始狀態(tài),F(xiàn)IFO中為空
圖 2  設(shè)置好輸入數(shù)據(jù),按下寫入鍵
圖 3  寫入數(shù)據(jù)中途讀取數(shù)據(jù)
圖 4  寫入數(shù)據(jù)完畢,滿信號燈亮
圖 5  讀取數(shù)據(jù)完畢,空信號燈亮
完整的Word格式文檔51黑下載地址(內(nèi)含清晰圖片):
Verilog課設(shè)報告.docx (916.49 KB, 下載次數(shù): 28)
主站蜘蛛池模板: 亚洲天天操 | 一区二区小视频 | 精品免费视频 | 免费网站观看www在线观看 | 日韩精品一二区 | 狼人久久 | 黄色一级片免费看 | 国产在线成人 | 国产一区精品在线 | 国产精品一区三区 | 亚洲午夜在线 | 亚洲欧美精品在线 | 日韩中文在线观看 | 亚洲精品一二区 | 欧美国产精品一区二区 | 日韩成人在线播放 | 亚洲区视频 | 免费日韩av| 婷婷免费视频 | 91亚洲成人 | 久草资源站| 色综合99| 亚洲欧美日韩一区二区 | 91在线一区二区 | 欧美日韩免费 | 天天射天天操天天干 | 黄色三级在线观看 | 国模一区二区 | 国产精品久久久久永久免费看 | 97香蕉视频 | 黄色国产视频 | 国产精品一级 | 国产香蕉视频在线观看 | 久久性视频 | 日韩特级 | 亚洲精品乱码久久久久久蜜桃91 | 日韩av网站在线观看 | 国产美女精品 | 日韩精品在线免费观看 | 日韩黄网| 欧美三级大片 |
