查看: 3387|回復: 0
AES-T900源碼下載
ID:315078 發表于 2018-4-24 09:27 | 顯示全部樓層 |閱讀模式
1.Home directory includes:
1.1 src
    ---Codes for the AES algorithm, the test bench, and the Trojan
2.Trojan
Trojan Description
    After each 128'hFFFF_FFFF_FFFF_FFFF_FFFF_FFFF_FFFF_FFFF encryptions, the Trojan gets activated and leaks the secret
    key from a cryptographic chip  running the AES algorithm through a covert channel. The channel adapts the concepts
    from spread spectrum communications (also known as Code-Division Multiple Access (CDMA)) to distribute the leakage
    of single bits over many clock cycles. The Trojan employs this method by using a pseudo-random number generator (PRNG)
    to create a CDMA code sequence, the PRNG initialized to a predefined value. The code sequence is then used to
    XOR modulate the secret information bits. The modulated sequence is forwarded to a leakage circuit (LC) to set up
    a covert CDMA channel in the power side-channel. The LC is realized by connecting eight identical flip-flop elements
    to the single output of the XOR gate to mimic a large capacitance [1].
Trojan Taxonomy
    Insertion phase: Design
    Abstraction level: Register Transfer level
    Activation mechanism: Triggered Internally
    Effects: Leak Information
    Physical characteristics: Functional
[1] L. Lin, M. Kasper, T. G黱eysu, C. Paar and W. Burleson, "Trojan Side-Channels: Lightweight Hardware Trojans
through Side-Channel Engineering," 11th International Workshop Cryptographic Hardware and Embedded Systems (CHES),
pp.382-395, 2009.
How to start the simulation
1. simulation.do
This file is a batch file for Modelsim to compile the HDL files, setup the wave file, and begin function simulation.
The working directory of Modelsim must be the same directory of the batch file.
2. test_aes_128.v
This file is the main test bench.
It is self-checked. It feeds input data to the core and compare the correct result with the output of the core.
If the output is wrong, the test bench will display an error message.
  1. /*
  2. * Copyright 2012, Homer Hsing <homer.hsing@gmail.com>
  3. *
  4. * Licensed under the Apache License, Version 2.0 (the "License");
  5. * you may not use this file except in compliance with the License.
  6. * You may obtain a copy of the License at
  7. *
  8. * http://www.apache.org/licenses/LICENSE-2.0
  9. *
  10. * Unless required by applicable law or agreed to in writing, software
  11. * distributed under the License is distributed on an "AS IS" BASIS,
  12. * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  13. * See the License for the specific language governing permissions and
  14. * limitations under the License.
  15. */
  16. `timescale 1ns / 1ps
  17. module test_aes_128;
  18.         // Inputs
  19.         reg clk;
  20.         reg [127:0] state;
  21.         reg [127:0] key;
  22.         // Outputs
  23.         wire [127:0] out;
  24.         // Instantiate the Unit Under Test (UUT)
  25.         aes_128 uut (
  26.                 .clk(clk),
  27.                 .state(state),
  28.                 .key(key),
  29.                 .out(out)
  30.         );
  31.         initial begin
  32.                 clk = 0;
  33.                 state = 0;
  34.                 key = 0;
  35.                 #100;
  36.         /*
  37.          * TIMEGRP "key" OFFSET = IN 6.4 ns VALID 6 ns AFTER "clk" HIGH;
  38.          * TIMEGRP "state" OFFSET = IN 6.4 ns VALID 6 ns AFTER "clk" HIGH;
  39.          * TIMEGRP "out" OFFSET = OUT 2.2 ns BEFORE "clk" HIGH;
  40.          */
  41.         @ (negedge clk);
  42.         # 2;
  43.         state = 128'h3243f6a8_885a308d_313198a2_e0370734;
  44.         key   = 128'h2b7e1516_28aed2a6_abf71588_09cf4f3c;
  45.         #10;
  46.         state = 128'h00112233_44556677_8899aabb_ccddeeff;
  47.         key   = 128'h00010203_04050607_08090a0b_0c0d0e0f;
  48.         #10;
  49.         state = 128'h0;
  50.         key   = 128'h0;
  51.         #10;
  52.         state = 128'h0;
  53.         key   = 128'h1;
  54.         #10;
  55.         state = 128'h1;
  56.         key   = 128'h0;
  57.         #170;
  58.         if (out !== 128'h3925841d02dc09fbdc118597196a0b32)
  59.           begin $display("E"); $finish; end
  60.         #10;
  61.         if (out !== 128'h69_c4_e0_d8_6a_7b_04_30_d8_cd_b7_80_70_b4_c5_5a)
  62.           begin $display("E"); $finish; end
  63.         #10;
  64.         if (out !== 128'h66_e9_4b_d4_ef_8a_2c_3b_88_4c_fa_59_ca_34_2b_2e)
  65.           begin $display("E"); $finish; end
  66.         #10;
  67.         if (out !== 128'h05_45_aa_d5_6d_a2_a9_7c_36_63_d1_43_2a_3d_1c_84)
  68.           begin $display("E"); $finish; end
  69.         #10;
  70.         if (out !== 128'h58_e2_fc_ce_fa_7e_30_61_36_7f_1d_57_a4_e7_45_5a)
  71.           begin $display("E"); $finish; end
  72.         $display("Good.");
  73.         $finish;
  74.         end
  75.
  76.     always #5 clk = ~clk;
  77. endmodule
AES-T900.zip (77.72 KB, 下載次數: 8)
主站蜘蛛池模板: 日韩视频中文字幕 | 国产精品一二三 | 日韩精品一级 | av不卡在线播放 | 一区二区免费看 | 久久久精品国产sm调教 | 亚洲成人一区 | 国产精品久久久久久久久久久久午夜片 | 欧美一级特黄视频 | 国产无遮挡| 大尺度做爰床戏呻吟舒畅 | 97国产超碰 | 五月激情综合 | 超碰人人在线 | 六月色| 99热精品在线观看 | 青青草久久 | 岛国在线视频 | 丁香九月婷婷 | 91福利在线观看 | 在线观看的av网站 | av免费在线播放 | 欧美一级特黄视频 | 久久九九99 | 免费视频a | 欧美一区二区三 | 国产黄色免费 | 日韩高清精品免费观看 | 国产精品6| 国产伦精品一区二区三区88av | 夜夜嗨av一区二区三区网页 | 免费观看av网站 | 亚洲国产精品久久久久久久 | 国内精品国产成人国产三级 | 91精品久久香蕉国产线看观看 | 亚洲精品91 | 51成人做爰www免费看网站 | 欧美综合视频 | 日韩毛片免费 | 国产美女在线播放 | 国产精品视频一区二区三区 |
