查看: 5461|回復: 1
FPGA學習板的流水燈Quartus源碼
ID:377015 發表于 2018-7-22 02:06 | 顯示全部樓層 |閱讀模式
自制,功能包括:
開關1、2(17、16)控制流水燈速度,00-1分頻,01-2分頻,10-4分頻,11-8分頻
開關3、4(15、14)控制流水燈花型,00-00010001,每次移動1,01-00110011,每次移動2,10-01110111,每次移動3,11-00001111,每次移動4
開關5(13)控制流水燈移動方向,0-左,1-右
按鈕1(0)復位
LCD屏顯示速度、花型和方向,顯示效果大致為
(有頻閃)
雖然是個智障小程序,不過是FPGA入門課的常見作業……解壓之后直接用Quartus打開就可以了
源程序如下:
  1. module LED(
  2.         input rst_n,
  3.                 input sw1,
  4.                 input sw2,
  5.                 input sw3,
  6.                 input sw4,
  7.                 input sw5,
  8.                 output led0,
  9.                 output led1,
  10.                 output led2,
  11.                 output led3,
  12.                 output led4,
  13.                 output led5,
  14.                 output led6,
  15.                 output led7,
  16. input clk,
  17. output reg [7:0] dat,
  18. output reg rs,
  19. output rw,
  20. output en
  21. );
  22. reg e;
  23. reg  [15:0] counter;
  24. reg [5:0] current,next,next_f;
  25. reg clkr;
  26. reg [1:0] cnt_f,cnt_g;
  27. reg [26:0] cnt;
  28. reg [7:0] led;
  29. reg [3:0] spd;
  30. reg [1:0] knd;
  31. reg drc;
  32. reg [1:0] stt;
  33. reg [4:0] flg;
  34. reg [4:0] flg_f;
  35. reg [5:0] stt_f;
  36. reg [2:0] i;
  37. always @(posedge clk or negedge rst_n) begin
  38.         if(!rst_n) begin
  39.                 cnt <= 27'd0;
  40.                 stt <= 2'd0;
  41.                 next_f <= 6'h0;
  42.                 cnt_g <= 2'h0;
  43.         end
  44.         else begin
  45.                 i <= sw2 * 2'd3;
  46.                 spd <= (sw1 + 1'b1) * (i + 1'b1);
  47.                 knd[0] <= sw3;
  48.                 knd[1] <= sw4;
  49.                 drc <= sw5;
  50.                 cnt <= cnt + 1'b1;
  51.                 if(cnt == 27'h400000 * spd) begin
  52.                         cnt <= 27'd0;
  53.                         stt <= stt + 1'b1 - drc * 2'd2;
  54.                         case(knd * 4 + stt)
  55.                                 4'h0:led <= 8'h11;
  56.                                 4'h1:led <= 8'h22;
  57.                                 4'h2:led <= 8'h44;
  58.                                 4'h3:led <= 8'h88;
  59.                                 4'h4:led <= 8'h33;
  60.                                 4'h5:led <= 8'hCC;
  61.                                 4'h6:led <= 8'h33;
  62.                                 4'h7:led <= 8'hCC;
  63.                                 4'h8:led <= 8'h77;
  64.                                 4'h9:led <= 8'hEE;
  65.                                 4'hA:led <= 8'hDD;
  66.                                 4'hB:led <= 8'hBB;
  67.                                 4'hC:led <= 8'hF;
  68.                                 4'hD:led <= 8'hF0;
  69.                                 4'hE:led <= 8'hF;
  70.                                 4'hF:led <= 8'hF0;
  71.                         endcase
  72.                 end
  73.         end
  74. end
  75. always @(posedge clk)
  76. begin
  77.   counter=counter+1;
  78.   if(counter==16'h000f)
  79.   clkr=~clkr;
  80. end
  81. always @(posedge clkr)
  82. begin
  83. current=next;
  84.   case(current)
  85.     6'h0:   begin  rs<=0; dat<=8'h38; next<=6'h1; end //清屏
  86.     6'h1:   begin  rs<=0; dat<=8'h0c; next<=6'h2; end //設置顯示模式
  87.     6'h2:   begin  rs<=0; dat<=8'h6; next<=6'h3; end //顯示器開、光標不顯示、光標不允許閃爍
  88.     6'h3:   begin  rs<=0; dat<=8'h1; next<=6'h4; end
  89.     6'h4:   begin  rs<=1; dat<=" "; next<=6'h5; end
  90.     6'h5:   begin  rs<=1; dat<="S"; next<=6'h6; end
  91.     6'h6:   begin  rs<=1; dat<="p"; next<=6'h7; end
  92.     6'h7:   begin  rs<=1; dat<="e"; next<=6'h8; end
  93.     6'h8:   begin  rs<=1; dat<="e"; next<=6'h9; end
  94.     6'h9:   begin  rs<=1; dat<="d"; next<=6'hA; end
  95.     6'hA:   begin  rs<=1; dat<=":"; next<=6'hB; end
  96.     6'hB:   begin  rs<=1; dat<= 8'h30 + spd; next<=6'hC; end
  97.     6'hC:   begin  rs<=1; dat<=" "; next<=6'hD; end
  98.     6'hD:   begin  rs<=1; dat<="K"; next<=6'hE; end
  99.     6'hE:   begin  rs<=1; dat<="i"; next<=6'hF; end
  100.     6'hF:   begin  rs<=1; dat<="n"; next<=6'h10; end
  101.          6'h10:   begin  rs<=1; dat<="d"; next<=6'h11; end
  102.          6'h11:   begin  rs<=1; dat<=":"; next<=6'h12; end
  103.          6'h12:   begin  rs<=1; dat<= 8'h31 + knd; next<=6'h13; end
  104.          6'h13:   begin  rs<=1; dat<=" "; next<=6'h14; end
  105.          6'h14:   begin  rs<=0; dat<=8'hC0; next<=6'h15; end
  106.          6'h15:   begin  rs<=1; dat<=" "; next<=6'h16; end
  107.          6'h16:   begin  rs<=1; dat<=" "; next<=6'h17; end
  108.          6'h17:   begin  rs<=1; dat<="D"; next<=6'h18; end
  109.          6'h18:   begin  rs<=1; dat<="i"; next<=6'h19; end
  110.          6'h19:   begin  rs<=1; dat<="r"; next<=6'h1A; end
  111.          6'h1A:   begin  rs<=1; dat<="e"; next<=6'h1B; end
  112.          6'h1B:   begin  rs<=1; dat<="c"; next<=6'h1C; end
  113.          6'h1C:   begin  rs<=1; dat<="t"; next<=6'h1D; end
  114.          6'h1D:   begin  rs<=1; dat<="i"; next<=6'h1E; end
  115.          6'h1E:   begin  rs<=1; dat<="o"; next<=6'h1F; end
  116.          6'h1F:   begin  rs<=1; dat<="n"; next<=6'h20; end
  117.          6'h20:   begin  rs<=1; dat<=":"; next<=6'h21; end
  118.          6'h21:   begin  rs<=1; dat<= 8'h30 + drc; next<=6'h22; end
  119.          6'h22:   begin  rs<=1; dat<=" "; next<=6'h23; end
  120.          6'h23:   begin  rs<=1; dat<=" "; next<=6'h24; end
  121.          6'h24:   begin  rs<=1; dat<=" "; next<=6'h25; end
  122.     6'h25:   begin rs<=0;  dat<=8'h00;                    //行一遍 然后 把液晶的E 腳 拉高
  123.               if(cnt_f!=2'h2)
  124.                   begin
  125.                        e<=0;next<=6'h0;cnt_f<=cnt_f+1;
  126.                   end
  127.                    else
  128.                      begin next<=6'h25; e<=1; next <= next_f; cnt_f <= cnt_g;
  129.                     end
  130.               end
  131.    default:   next=6'h0;
  132.     endcase
  133. end
  134. assign en=clkr|e;
  135. assign rw=0;
  136. assign led0 = led[0];
  137. assign led1 = led[1];
  138. assign led2 = led[2];
  139. assign led3 = led[3];
  140. assign led4 = led[4];
  141. assign led5 = led[5];
  142. assign led6 = led[6];
  143. assign led7 = led[7];
  144. endmodule
LED.rar (3.29 MB, 下載次數: 35)
ID:191615 發表于 2018-11-22 14:56 | 顯示全部樓層
學習了,我是初學者,有點頭大
主站蜘蛛池模板: 日韩黄色免费视频 | 国产午夜三级 | 91黄色大片 | 天天干夜夜操 | 四虎www| 一区二区三区精品 | 户外少妇对白啪啪野战 | 日韩视频网 | 国产51自产区 | 日皮视频免费看 | 深夜福利网址 | 午夜性视频 | 国产一区二区三区免费 | 手机在线免费看av | 亚洲欧美另类在线 | 五月天黄色网 | 国产高清免费视频 | 免费视频毛片 | 日韩精品在线观看视频 | av网站免费看| 亚洲精品视频在线 | 免费在线观看www | 人人射人人干 | 黄色一级大片在线免费看产 | 欧美a级黄色片 | 国产小视频在线 | 国产高清视频 | 黄色小说网站在线观看 | 午夜精品久久久久久久久久蜜桃 | 日韩一区二区三 | 欧美日韩精品一区二区 | 欧美一区二区在线 | 色综合99 | wwwav在线| 成年人免费看视频 | 色综合激情 | 毛片在线观看网站 | 一区二区三区免费 | 国产农村妇女aaaaa视频 | 欧美日韩一区二区在线观看 | 亚洲高清免费 |
