查看: 6191|回復(fù): 1
51單片機(jī)ADC0809的電壓表設(shè)計(jì)(proteus仿真及keil代碼)
電壓表仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)源程序如下:
  1. //程序頭函數(shù)
  2. #include <reg51.h>
  3. //宏定義
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. #define Data_ADC0809 P1
  7. sbit ST=P3^2;
  8. sbit EOC=P3^3;
  9. sbit OE=P3^1;
  10. sbit N=P3^0;
  11. sbit W=P3^4;
  12. sbit DIAN = P0^7;                        //小數(shù)點(diǎn)
  13. /*******************************定義全局變量********************************/
  14. unsigned char dis[3];       //顯示數(shù)值
  15. unsigned char data adtab[8]=0;
  16. unsigned int sum=0;
  17. unsigned int dat=0;
  18. unsigned char  i=0;
  19. unsigned char  n=0;
  20. /*******************************通道選擇表*******************************/
  21. unsigned char code ad[]={0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfe,0xff};
  22. /*******************************共陽(yáng)LED段碼表*******************************/
  23. unsigned char code tab[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
  24. //                          0     1   2    3    4    5    6    7    8    9
  25. /****************************************************************************
  26. 函數(shù)功能:AD轉(zhuǎn)換子程序
  27. ****************************************************************************/
  28. //ADC0809讀取信息
  29. uchar ADC0809()
  30. {
  31.         uchar temp=0x00;
  32.         //初始化高阻太
  33.         OE=0;
  34.         //轉(zhuǎn)化初始化
  35.         ST=0;
  36.         //開(kāi)始轉(zhuǎn)換
  37.         ST=1;
  38.         ST=0;
  39.         //外部中斷等待AD轉(zhuǎn)換結(jié)束
  40.         while(EOC==0)
  41.         //讀取轉(zhuǎn)換的AD值
  42.         OE=1;
  43.         Data_ADC0809=0xff;
  44.         temp=Data_ADC0809;
  45.         OE=0;
  46.         return temp;
  47. }
  48. /****************************************************************************
  49. 函數(shù)功能:延時(shí)子程序
  50. 入口參數(shù):
  51. 出口參數(shù):
  52. ****************************************************************************/
  53. void delay(unsigned int x)
  54. {
  55.     unsigned int i,j;
  56.     for(i=0;i<x;i++)
  57.         for(j=0;j<121;j++);
  58. }
  59. //=====================================================================================
  60. //=====================================================================================
  61. //=====================================================================================
  62. /****************************************************************************
  63. 函數(shù)功能:將0-255級(jí)換算成0.00-5.00的電壓數(shù)值
  64. 入口參數(shù):i
  65. 出口參數(shù):
  66. ****************************************************************************/
  67. void convdata(unsigned char dat1)
  68. {
  69.         unsigned int Vo;
  70.         Vo=dat1*1.96;
  71.     dis[0] = Vo/100;      // 個(gè)位
  72.     dis[1] = Vo%100/10;   // 小數(shù)點(diǎn)后一位
  73.     dis[2] = Vo%100%10;   // 小數(shù)點(diǎn)后兩位
  74. }
  75. /****************************************************************************
  76. 函數(shù)功能:數(shù)碼管顯示子程序
  77. 入口參數(shù):
  78. 出口參數(shù):
  79. ****************************************************************************/
  80. void display(void)
  81. {
  82.         convdata(adtab[n]);
  83.     P0=tab[dis[0]];
  84.     P2=0xfe;
  85.         DIAN=0;
  86.     delay(1);
  87.     P2=0xff;
  88.     P0=tab[dis[1]];
  89.     P2=0xfd;
  90.         DIAN=1;
  91.     delay(1);
  92.     P2=0xff;
  93.     P0=tab[dis[2]];
  94.     P2=0xfb;
  95.         DIAN=1;
  96.     delay(1);
  97.     P2=0xff;
  98.         P0=tab[n];
  99.     P2=0xf7;
  100.         DIAN=1;
  101.     delay(1);
  102.     P2=0xff;
  103. }
  104. /****************************************************************************
  105. 函數(shù)功能:按鍵選擇對(duì)應(yīng)通道輸出
  106. 入口參數(shù):
  107. 出口參數(shù):
  108. ****************************************************************************/
  109. uchar TDN()
  110. {
  111. if(N == 0)
  112.         {
  113.         delay(100);
  114.         if(N == 0)
  115.           {
  116.            n++;
  117.            if(n>7) n=0;
  118.           }
  119.          delay(100);
  120.      }
  121.          return n;
  122. }
  123. /****************************************************************************
  124. 函數(shù)功能:主程序
  125. 入口參數(shù):
  126. 出口參數(shù):
  127. ****************************************************************************/
  128. void main(void)
  129. {
  130.    while(i<8)
  131.         {
  132.                 if(W == 0)
  133.              {
  134.                  delay(100);
  135.                      if(W == 0)
  136.                     {
  137.                                 Data_ADC0809=ad[i];//選定通道
  138.                             adtab[i]=ADC0809();//將轉(zhuǎn)換結(jié)果存入數(shù)組
  139.                      i++;
  140.                      }
  141.                   delay(100);
  142.           }
  143.                  if(N == 0)
  144.               {
  145.                   delay(100);
  146.                     if(N == 0)
  147.                     {
  148.
  149.                      i=9;
  150.                     }
  151.                     delay(100);
  152.            }
  153.          }
  154.   while(1)       //主循環(huán)
  155.   {
  156.
  157.          if(i==9)
  158.            {
  159.
  160.                     Data_ADC0809=ad[0];//選定通道
  161.                     adtab[0]=ADC0809();//將轉(zhuǎn)換結(jié)果存入數(shù)組
  162.                   n=TDN();
  163.           display();
  164.            }
  165.          if(i==8)
  166.           {
  167.
  168.                    n=TDN();
  169.            display();
  170.
  171.           }
  172.   }
  173.
  174.
  175. }
0809電壓表.rar (49.42 KB, 下載次數(shù): 139)
評(píng)分
查看全部評(píng)分
相關(guān)帖子
ID:923532 發(fā)表于 2021-7-27 17:10 | 只看該作者
能調(diào)電壓范圍是多少啊
主站蜘蛛池模板: 天天射天天干天天操 | 欧美又粗又长 | 欧美久久综合 | 丨国产丨调教丨91丨 | 久久99热这里只频精品6学生 | 天堂一区二区三区 | 欧美日韩亚洲一区 | www.麻豆av| 麻豆一区二区三区 | 中文字幕在线免费看 | a级片免费观看 | 成年人免费在线视频 | 高清免费视频日本 | 久久视频这里只有精品 | 亚欧洲精品在线视频免费观看 | 天堂а√在线中文在线新版 | 日韩一级片在线观看 | 欧美日韩成人在线观看 | 欧美日韩少妇 | 天堂在线中文资源 | 国产视频在线观看视频 | 中文字幕日韩视频 | 黄色福利视频 | 亚洲精品网站在线观看 | 精品亚洲国产成人av制服丝袜 | 国产激情网站 | 日韩免费一级片 | 色妞网站| 极品白嫩少妇无套内谢 | 亚洲欧美日本在线 | 成人中文字幕在线观看 | 久久日av| 国产成人福利 | 国产福利91精品一区二区三区 | 日韩av在线免费观看 | 一级黄色网 | 天天综合久久 | 欧美日韩性| 露出调教羞耻91九色 | 欧美日本在线观看 | 国产91热爆ts人妖系列 |
