查看: 2317|回復(fù): 1
溫度計 在數(shù)碼管顯示
ID:642152 發(fā)表于 2019-11-16 15:10 | 顯示全部樓層 |閱讀模式
/**********************SY-1實驗開發(fā)板例程************************
*  平臺:SY-1+STC89C52
*  名稱:測當(dāng)前溫度,并在數(shù)碼管上顯示
*  晶振:11.0592MHZ
#include <reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit DS=P2^2;           //define interface
uint temp;             // variable of temperature
uchar flag1;            // sign of the result positive or negative
sbit dula=P2^6;
sbit wela=P2^7;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
                        0x87,0xff,0xef};
void delay(uint count)      //delay
  uint i;
  while(count)
    i=200;
    while(i>0)
    i--;
    count--;
void dsreset(void)       //send reset and initialization command
  uint i;
  DS=0;
  i=103;
  while(i>0)i--;
  DS=1;
  i=4;
  while(i>0)i--;
bit tmpreadbit(void)       //read a bit
   uint i;
   bit dat;
   DS=0;i++;          //i++ for delay
   DS=1;i++;i++;
   dat=DS;
   i=8;while(i>0)i--;
   return (dat);
uchar tmpread(void)   //read a byte date
  uchar i,j,dat;
  dat=0;
  for(i=1;i<=8;i++)
    j=tmpreadbit();
    dat=(j<<7)|(dat>>1);   //讀出的數(shù)據(jù)最低位在最前面,這樣剛好一個字節(jié)在DAT里
  return(dat);
void tmpwritebyte(uchar dat)   //write a byte to ds18b20
  uint i;
  uchar j;
  bit testb;
  for(j=1;j<=8;j++)
    testb=dat&0x01;
    dat=dat>>1;
    if(testb)     //write 1
      DS=0;
      i++;i++;
      DS=1;
      i=8;while(i>0)i--;
      DS=0;       //write 0
      i=8;while(i>0)i--;
      DS=1;
      i++;i++;
void tmpchange(void)  //DS18B20 begin change
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);  // address all drivers on bus
  tmpwritebyte(0x44);  //  initiates a single temperature conversion
uint tmp()               //get the temperature
  float tt;
  uchar a,b;
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);
  tmpwritebyte(0xbe);
  a=tmpread();
  b=tmpread();
  temp=b;
  temp<<=8;             //two byte  compose a int variable
  temp=temp|a;
  tt=temp*0.0625;
  temp=tt*10+0.5;
  return temp;
void display(uint temp)                        //顯示程序
   uchar A1,A2,A2t,A3;
   A1=temp/100;
   A2t=temp%100;
   A2=A2t/10;
   A3=A2t%10;
   dula=0;
   P0=table[A1];                //顯示百位
   dula=1;
   dula=0;
   wela=0;
   P0=0x7e;
   wela=1;
   wela=0;
   delay(1);
   dula=0;
   P0=table1[A2];                //顯示十位
   dula=1;
   dula=0;
   wela=0;
   P0=0x7d;
   wela=1;
   wela=0;
   delay(1);
   P0=table[A3];                //顯示個位
   dula=1;
   dula=0;
   P0=0x7b;
   wela=1;
   wela=0;
   delay(1);
uchar a;
  do
    tmpchange();
        for(a=10;a>0;a--)
                  display(tmp());
  } while(1);
ID:1 發(fā)表于 2019-11-20 12:01 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
主站蜘蛛池模板: 国产91丝袜在线播放 | 一级黄片毛片 | 中文字幕一区在线观看 | 天天色天天色 | 日韩在线免费 | 黄色一级视频免费看 | 国产在线观看精品 | 欧美国产日韩在线 | www.夜夜操| 日韩精品久久久久久免费 | 亚洲午夜在线观看 | 久草新视频 | 亚洲欧美视频 | 黄色大片网站 | av看片| 爱福利视频 | 成人免费黄色片 | 欧美日韩成人 | 日本免费网站 | 国产精品免费人成网站酒店 | 黄色一级小说 | 亚洲国产成人精品女人 | 麻豆视频国产 | 国产黄色一区二区 | 精品国产乱码久久久久 | 911看片 | 国产精品99久久久久久久久 | 一级毛片在线 | 日本特黄一级片 | 99精品热| 欧美综合一区二区 | 免费看黄色录像 | 欧美精品久久久久久久多人混战 | 午夜在线视频观看 | 亚洲人精品 | 97av视频| 伊人影院久久 | 国产日韩精品视频 | 日韩精品免费视频 | 91欧美激情一区二区三区成人 | 手机av网站|
