改這樣樓主試試。
- #include<stc15.h>
- /*共陰數(shù)碼管編碼*/
- unsigned char code tab1[]={
- 0x3f,0x06,0x5b,0x4f,0x66,
- 0x6d,0x7d,0x07,0x7f,0x6f};
- /*共陽數(shù)碼管編碼
- 0xc0,0xf9,0xa4,0xb0,
- 0x99,0x92,0x82,0xf8,
- 0x80,0x90,0x88,0x83,
- 0xc6,0xa1,0x86,0x8e};
- /*位選編碼*/
- unsigned char code tab2[]={
- 0xfe,0xfd,0xfb,0xf7,
- 0xef,0xdf,0xbf,0x7f};
- unsigned char dis_buf[8]={0,0,0x40,0,0,0x40,0,0};
- //sbit duanxuan=P1^0;
- /*按鍵位定義*/
- sbit key0=P1^0;
- sbit key1=P1^1;
- sbit key2=P1^2;
- sbit key3=P1^3;
- sbit key4=P1^4;
- sbit key5=P1^5;
- sbit key6=P1^6;
- sbit key7=P1^7;
- /*秒、分、時的初始化*/
- unsigned int tt=0;
- unsigned char i=0;
- char sec=0,fen=0,shi=12;
- bit sign=1;
- /*延時函數(shù)*/
- void delay(unsigned int n)
- while(n--);
- /*定時器0初始化函數(shù)*/
- void chushihua() //1毫秒@12.000MHz
- AUXR &= 0x7F; //定時器時鐘12T模式
- TMOD &= 0xF0; //設(shè)置定時器16位自動重載模式
- TL0 = 0x18; //設(shè)置定時初值
- TH0 = 0xFC; //設(shè)置定時初值
- TR0 = 1; //定時器0開始計時
- EA=1;
- ET0=1;
- /*按鍵設(shè)定函數(shù)*/
- void sheding()
- if(key0==0)
- delay(3500);
- if(key0==0)
- sign=0;
- if(key1==0)
- delay(3500);
- if(key1==0)
- sec++;
- if(sec>59)
- sec=0;
- while(!key1);
- if(key2==0)
- delay(3500);
- if(key2==0)
- fen++;
- if(fen>59)
- fen=0;
- while(!key2);
- if(key3==0)
- delay(3500);
- if(key3==0)
- shi++;
- if(shi>23)
- shi=0;
- while(!key3);
- if(key5==0)
- delay(3500);
- if(key5==0)
- sec--;
- if(sec<0)
- sec=59;
- while(!key5);
- if(key6==0)
- delay(3500);
- if(key6==0)
- fen--;
- if(fen<0)
- fen=59;
- while(!key6);
- if(key7==0)
- delay(3500);
- if(key7==0)
- shi--;
- if(shi<0)
- shi=23;
- while(!key7);
- if(key4==0)
- delay(3500);
- if(key4==0)
- sign=1;
- /*數(shù)據(jù)分解*/
- void timedeal()
- dis_buf[0]=tab1[sec%10];
- dis_buf[1]=tab1[sec/10];
- dis_buf[3]=tab1[fen%10];
- dis_buf[4]=tab1[fen/10];
- dis_buf[6]=tab1[shi%10];
- dis_buf[7]=tab1[shi/10];
- /*顯示函數(shù)*/
- void display()
- P6=0x00;//消影
- P7=tab2[i];//送位碼
- P6=dis_buf[i];//送段碼
- i++;
- i%=8;
- /*主函數(shù)*/
- void main()
- chushihua();
- while(1)
- sheding();
- timedeal();
- /*定時器0中斷函數(shù)*/
- void time0() interrupt 1
- if(sign)
- tt++;
- if(tt>=1000)
- tt=0;
- sec++;
- if(sec>=60)
- sec=0;
- fen++;
- if(fen>=60)
- fen=0;
- shi++;
- if(shi>=24)
- shi=0;
- display();
復(fù)制代碼 |
