查看: 3222|回復: 0
松翰SN8F5703單片機PWM例程
ID:856645 發(fā)表于 2020-12-8 11:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. //-----------------------------------------------------------------------------
  2. //  FILE:   PWM3_Pulse.c
  3. //-----------------------------------------------------------------------------
  4. //  Copyright 2014 Sonix Technology Corp. All rights reserved.
  5. //
  6. //  AUTHOR:     Sonix
  7. //  DATE:       2014/11/07
  8. //
  9. //  The program is an example of PWM3 one pulse function to implement it.
  10. //
  11. //  PW3 pulse decription:
  12. //      1. when PW3EN = 1 ,
  13. //         PWM3 will output One Pulse PWM and than PW3EN to be 0
  14. //
  15. //  The system clock frequency is IHRC 32MHz
  16. //
  17. //  Device:     SN8F5708
  18. //  Tool chain: KEIL C51 V9.50a
  19. //
  20. //-----------------------------------------------------------------------------
  21. // Includes
  22. //-----------------------------------------------------------------------------
  23. #include <SN8F5703.h>
  24. //-----------------------------------------------------------------------------
  25. // Global Variables
  26. //-----------------------------------------------------------------------------
  27. //-----------------------------------------------------------------------------
  28. // Function Prototypes
  29. //-----------------------------------------------------------------------------
  30. void PWM1PLS_Init(void);
  31. //-----------------------------------------------------------------------------
  32. // Main loop
  33. //-----------------------------------------------------------------------------
  34. void main(void)
  35. {
  36.         CLKSEL = 0x06;        // Fcpu = 32M/2 = 16M
  37.         CLKCMD = 0X69;
  38.         CKCON = 0X10;        // From = 8M
  39.
  40.   WDTR = 0x5A;                                            // clear watchdog if watchdog enable
  41.
  42.         P0 = 0;
  43.         P0M = 0;
  44.         P0UR = 0xFF;
  45.
  46.         P1 = 0;
  47.         P1M = 0xC0;
  48.         P1UR = 0xFF;
  49.
  50.         P2 = 0;
  51.         P2M = 0x3C;
  52.         P2UR = 0xFF;
  53.
  54.         PWM1PLS_Init();                                         // init PWM1
  55.     while (1)
  56.                 {
  57.         WDTR = 0x5A;                                // clear watchdog if watchdog enable
  58.
  59.                 }
  60. }
  61. //-----------------------------------------------------------------------------
  62. //  Function:    void PWM1PLS_Init(void)
  63. //  Description:
  64. //      init PWM1 pulse
  65. //
  66. //-----------------------------------------------------------------------------
  67. void PWM1PLS_Init(void)
  68. {
  69.                 PW1CH = 0x11;
  70.
  71.     PW1M |= 0x70;                                   // PW1 rate is Fhosc/1     PWM輸出頻率危(32/1)/256 = 125KHZ   PWM周期為8uS
  72.     PW1M |= 0x08;                                   // enable PWM11 output (PWCH11)
  73.     PW1M |= 0x04;                                   // enable PWM10 output (PWCH10)
  74. //    PW1M |= 0x01;                                 // enable PW1 pulse output function (PW1PO)
  75.     PW1YH = 0x00;
  76.     PW1YL = 0xFF;                                                // set PW1 cycle control    256
  77.     PW1DH = 0x00;
  78.     PW1DL = 0x3F;                                   // set PWM duty control   64     占空比25%
  79.     // the dead band control : B point > A point (Must)
  80.     PW1BH = PW1DH;
  81.     PW1BL = PW1DL;                                  // B point dead band control
  82.     PW1A = 0x00;                                    // A point dead band control
  83.           PW1M |= 0x80;                                   // Enable PWM output function (PW1EN)
  84. }
5703_PWM_20161103.rar
29.55 KB, 下載次數(shù): 23, 下載積分: 黑幣 -5
主站蜘蛛池模板: 密乳av | 成人免费视频网站 | 欧美色图在线观看 | 成人毛片网 | 欧美国产日韩一区二区 | 亚洲久久久 | jlzzjlzz欧美大全 | 一区二区三区视频在线 | 一级久久| 日韩av在线免费 | 免费av一区二区 | 久久久久久久免费视频 | 天堂视频在线观看 | 美国一级大黄一片免费中文 | 日韩一区中文字幕 | 天天色影院 | 日韩在线小视频 | 青娱乐av | 久久精品视频网站 | 思思在线视频 | 国产一区二区三区免费视频 | 日韩av免费在线播放 | 亚洲成人av在线 | 日韩欧美一级 | 在线观看福利影院 | 色鬼久久 | 91在线精品李宗瑞 | 久久精品伊人 | 国产精品毛片av | 91在线视频播放 | 日本国产在线观看 | 日韩一区二区在线观看视频 | 成人在线a| 久久99精品久久久久久水蜜桃 | 免费在线观看www | 久久亚洲一区二区 | 谁有毛片网址 | 久久久夜 | 国产又色又爽又黄又免费 | 国产免费高清 | 色综合99|
